Active Directory Not Syncing Correctly in ES2
Jun 3, 2010 7:56 AM
Hello,
We had our Active Directory 2003 synced up using Adobe Livecycle ES.  There would be around 30,000 users that would be synced and this would take around 3 - 4 1/2 minutes to run.  This worked perfectly for us for the past half of a year or so.
Last week we upgraded to ES2 and moved all of our processes over.  We removed ES and did a fresh install of ES2.  Everything seems to be working fine now except the Active Directory isn't syncing properly.  When we run the sync, different numbers of users will be fetched.  Sometimes it's around three thousand, sometimes seven thousand, sometimes ten thousand, but it never seems to get through them all.  In the server log it does say that the directory synchronization completed successfully though even though the number fetched is changing.  We made sure the settings are exactly the same as they were before, and we even tried a few different settings, but it still doesn't get all the users.  For testing purposes, we tried changing the search filter to pick specific people that aren't showing up during the normal sync and it will show up fine, so I'm wondering if there is something stopping it from going all the way through?
We also have another enterprise domain connected which has around 2,000 users on it and have not had this problem with it.
Here are some of the sync statistics from the past few syncs: (The active directory name has been stripped for security purposes).  If you need any more information please feel free to ask.  We would like to have this resolved as soon as possible.
2010-05-30 21:02:51,366 INFO  [com.adobe.idp.um.businesslogic.synch.DomainSynchronizer]
========== Synch Statistics for ============
Total User Fetched - 5633
Total Group Fetched - 0
Total Members Fetched - 0
Total time taken is 110 sec
[100.00%] [100.00%]Domain Synchronizer(2 runs) : Total 110,375 ms, Max 110359 ms, Min 16 ms, Avg 55187 ms
--[99.99%] [99.99%]User and group phase(1 runs) : Total 110,359 ms, Max 110359 ms, Min 110359 ms, Avg 110359 ms
----[95.78%] [95.80%]Users synch from (6 runs) : Total 105,719 ms, Max 19141 ms, Min 14281 ms, Avg 17619 ms
------[1.18%] [1.23%]Provider (31 runs) : Total 1,298 ms, Max 109 ms, Min 31 ms, Avg 41 ms
--[0.01%] [0.01%]Memberhsip phase(1 runs) : Total 16 ms, Max 16 ms, Min 16 ms, Avg 16 ms
-------Persistence Statistics-------
Users ->
added = 8
removed = 2568
updated = 5625
unchanged = 0
renamed = 0
failed = 0
UniqueId changed = 0
Groups ->
added = 0
removed = 0
updated = 0
unchanged = 0
failed = 0
Emails ->
added = 8515
removed = 106
unchanged (In changed Principals) = 16784
Group Members ->
added = 0
removed = 0
unchanged = 0
unknown = 0
failed = 0
-------Batch Statistics-------
Successful User Batches = 113
Failed User Batches = 0
Successful Group Batches = 0
Failed Group Batches = 0
Successful Member Batches = 0
Failed Member Batches = 0
2010-06-02 21:03:43,692 INFO  [com.adobe.idp.um.businesslogic.synch.DomainSynchronizer]
Total User Fetched - 7140
Total time taken is 165 sec
[100.00%] [100.00%]Domain Synchronizer(2 runs) : Total 164,781 ms, Max 164750 ms, Min 31 ms, Avg 82390 ms
--[99.98%] [99.98%]User and group phase(1 runs) : Total 164,750 ms, Max 164750 ms, Min 164750 ms, Avg 164750 ms
----[96.78%] [96.79%]Users synch from (8 runs) : Total 159,469 ms, Max 26719 ms, Min 3500 ms, Avg 19933 ms
------[1.01%] [1.05%]Provider (42 runs) : Total 1,667 ms, Max 109 ms, Min 15 ms, Avg 39 ms
--[0.02%] [0.02%]Memberhsip phase(1 runs) : Total 31 ms, Max 31 ms, Min 31 ms, Avg 31 ms
Users ->
added = 8
removed = 5
updated = 7132
unchanged = 0
renamed = 1
failed = 0
Groups ->
added = 0
removed = 0
updated = 0
unchanged = 0
failed = 0
Emails ->
added = 3340
removed = 105
unchanged (In changed Principals) = 33761
Group Members ->
added = 0
removed = 0
unchanged = 0
unknown = 0
failed = 0
Successful User Batches = 142
Failed User Batches = 1
2010-06-03 08:56:43,286 INFO  [com.adobe.idp.um.businesslogic.synch.DomainSynchronizer]
Total User Fetched - 2960
Total time taken is 68 sec
[100.00%] [100.00%]Domain Synchronizer(2 runs) : Total 67,984 ms, Max 67921 ms, Min 63 ms, Avg 33992 ms
--[99.91%] [99.91%]User and group phase(1 runs) : Total 67,921 ms, Max 67921 ms, Min 67921 ms, Avg 67921 ms
----[96.37%] [96.46%]Users synch from (3 runs) : Total 65,516 ms, Max 23016 ms, Min 19766 ms, Avg 21838 ms
------[4.00%] [4.15%]Provider (17 runs) : Total 2,719 ms, Max 844 ms, Min 31 ms, Avg 159 ms
--[0.09%] [0.09%]Memberhsip phase(1 runs) : Total 63 ms, Max 63 ms, Min 63 ms, Avg 63 ms
Users ->
added = 2
removed = 6632
updated = 2958
unchanged = 0
renamed = 0
failed = 0
Groups ->
added = 0
removed = 0
updated = 0
unchanged = 0
failed = 0
Emails ->
added = 3
removed = 1
unchanged (In changed Principals) = 10035
Group Members ->
added = 0
removed = 0
unchanged = 0
unknown = 0
failed = 0
Successful User Batches = 60
    Jun 6, 2010 11:13 PM   in reply to JoelHH
    Hi Joel,
    Few questions
    1. Do you see any entries like "Record [xxx] is missing required attribute xxx [xxx]"
    2. Also an entry like
      Found [yyy] locked users while synching. These users were ignored
    Jun 7, 2010 5:29 AM   in reply to JoelHH
    This is a known issue and a patch is avialable to fix this issue.The issue occurs when the Synch logic encounters 'n' consecutive users who are not persisted due to some missing attribute And n >= batchSize whose default value is 200
    Contact Adobe Support for the QF .17
    Dec 15, 2011 1:34 AM   in reply to Chetan Mehrotra
    Hi
    I am having a simialr problem but not seeing error messages. We are on ES2 service pack 2. Is a patch still required.
    Neil
    Dec 15, 2011 2:13 AM   in reply to Neil-IHE
    Hi Neil,
    Could you please tell what is the exact problem that you are facing while synching.
    Did you happen to upgrade from one Livecycle version to another?
    Do you get messages stated above like,
    1. "Record [xxx] is missing required attribute xxx [xxx]"
    2. Found [yyy] locked users while synching. These users were ignored
    Also let us know what is the server configuration, i.e. LDAP, Appserver and Db.
