Script for removing color definitions
Nov 17, 2011 Nov 17, 2011
I'm trying to create a script that will remove color definitions other than the default plus our corporate colors. I'm thinking some kind of "while" loop to go through the doc's color list, matching it to an array of named colors.
I see that there is a Color object and methods such as Delete(), but it's not coming together for me.
Any help would be appreciated.
Scripting
3.0K
Enthusiast , Dec 14, 2011 Dec 14, 2011
Try this as one way to solve the problem. It adds a new contains() method to the Array class.
var doc = app.ActiveDoc,
    col  = doc.FirstColorInDoc
    keepColors = ["Black","White","Red","Green","Blue","Cyan","Magenta","Yellow","Dark Grey","Pale Green","Forest Green","Royal Blue","Olive","Salmon","Mauve","Light Salmon","Custom Color"];
Array.prototype.contains = function (value) {
    var i;
    for (i = 0; i < this.length; i+=1) {
        if (this === value) {
            return true;
I am posting a small snippet which demonstrates how to traverse the color object in doc and delete it. The following sample iterates over all the color present in the doc until it finds a color named “testcolor” and then deletes it. It works on the active document.
doc = app.ActiveDoc //getting the active doc
col = doc.FirstColorInDoc //getting the first color in doc
while (col.ObjectValid() ) //checking if the color object is valid
if (col.Name == "testcolor" ) // matching for testcolor
col.Delete() //deleting the color
break
else {
col = col.NextColorInDoc
Vikash
FrameMaker Engineering team
Dec 13, 2011 Dec 13, 2011
Finally able to get back to this project.
Thanks for this snippet which does work great for removing a single "known" color. What I actually need to do is remove all colors except a specified list.
I've made an attempt (I'm sill relatively new to JS programming), but it only deletes the first instance instead of iterating through all the color definitions:
keepColors = new Array ("Black","White","Red","Green","Blue","Cyan","Magenta","Yellow","Dark Grey","Pale Green","Forest Green","Royal Blue","Olive","Salmon","Mauve","Light Salmon","Custom Color");
    if (col.Name in (keepColors))  //color exists
       break
else {
col.Delete()  //delete color
You are using "break" in the while loop which will terminate the loop whenever the condition is true. Try the following snippet:
while( col.ObjectValid() )
     if (col.Name <not in> (keepColors) )  //Color doesn't exits
          col2 = col.NextColorInDoc
          col.Delete()
          col = col2
     else{
Vikash
Frame Engineering Team
I think I need something more complicated than my solution for "<not in>."
I tried:
     if (!(col.Name in keepColors))
Which successfully eliminated all non-default colors, but it also eliminated the custom colors I designated in keepColors.
Enthusiast ,
The problem is that (col.Name in keepColors) does not work on the string value of the array element. It is checking for the element's name which in an array is its index value. The way to do this is to create a for loop to check each value of the array against each color in the document.
Ian
Okay, I got it to work with the rather sloppy:
     if (!(col.Name in {"Custom1":"", "Custom2":"", "Custom3":""}))
Thankfully we only have three corporate colors so this isn't too ugly. If someone has time, I would like to see a cleaner method of checking against an array (or list) of items as my next project is to clean out variables for which we have tons that are no longer acceptable.
Milo
Enthusiast ,
    var i;
            return true;
while(col.ObjectValid()){
    if (!keepColors.contains(col.Name)) {
        col2 = col.NextColorInDoc;
        col.Delete();
        col = col2;
    else {
        col = col.NextColorInDoc;
Dec 15, 2011 Dec 15, 2011
Well that did the trick! Sadly I only have a vague understanding of the code, but I'll happily copy and paste it for now.
I did find that I only need to list the custom colors in the array as, understandably, the default colors can't be deleted.
Milo
Enthusiast ,
Milo,
In JavaScript it is possible to extend the built-in classes. Normally the Array class has no method for testing if it contains an element with a specific value. The new anonymous function simply checks each element in the array and returns true if it matches the value parameter.
Aother useful way to extend the Array class would be to add an indexOf() method this could return the index number of a given value, or -1 if the value is not found.
Ian
Ah, it's starting to make sense. Thanks for taking the time for writing and explaining the code.
Milo
Apr 14, 2020 Apr 14, 2020
First time posting here...thank you Ian for sharing your expertise. I'm on Frame 2017. I'm working with a book that has a multiplicity of cross-ref formats – so many, in fact, that I can't add more, which I've never encountered before. I adapted this to remove the unwanted ones. In so doing, I found that I had to change this...
to this:
if (this[i] === value) {
Thanks Again,
Les
