Is there a trick to getting whiteSpaceCollapse to work with imported HTML? Here's my current code, where value is HTML text (e.g. "<p>Blah</p>.."):
textFlow = TextConverter.importToFlow( value, TextConverter.TEXT_FIELD_HTML_FORMAT);
textFlow.whiteSpaceCollapse = WhiteSpaceCollapse.COLLAPSE;
I've also set whiteSpaceCollapse on the RichEditableText to "collapse" but I'm still noticing vertical space differences if my external HTML has linebreaks between <p></p> nodes. Many thanks in advance for any suggestions.
-Robert
And so ? How do we set the TextConverter to avoid collapsing white spaces on import now ?
I ve tried many ways but still no way to avoid a WEIRD behavior.
If I set spaces and I want to collapse them, then I can do it with a simple search/replace, there are plenty
of regex out there to do this.
I don't need the framework to behave strangely right ? So why did the flex engineers spend time
on putting together stuff that is totally weird ?
Plus the TextConverter has a lot of tlf_internal methods, just to avoid us to overload its functionnalities...
Hi aliman,
Did you set format string to TextConvertr.PLAIN_TEXT_FORMAT ? That will preserve your spaces I think.
var textFlow:TextFlow = TextConverter.importToFlow(markup, TextConverter.PLAIN_TEXT_FORMAT);
And for tlf_internal, i just find one tlf_internal function in TextConverter. Others are public.
static tlf_internal function setFormatsToDefault():void
this is the way to solve this bug and no need for changing any xml settings , simple and it works
exporting the textflow:
var richTextXML:xml = new XML("<"+"richTextXML"+"/>");
richTextXML.appendChild(getCdataXMl());
private function getCdataXMl():xml{
var textFlowStr:String = TextConverter.export(textFlow,TextConverter.TEXT_FIELD_HTML_FORMAT
, ConversionType.STRING_TYPE).toString();
var textFlowXMl:xml = new XMl("<![CDATA["+textFlowStr+"]]>");
return textFlowXMl;
importing TextFlow from XMl :
var htmlTextInStr:String = richTextXMl.text();
var importtedTextFlow:TextFlow = TextConverter.importToFlow(htmlTextInStr,TextConverter.TEXT_FIELD_HTM L_FORMAT);
textArea.textFlow = importtedTextFlow;
