Dan Rodney 46 posts
Jan 18, 2010
[JS] Menu Added via Scripting Moves
Dec 16, 2011 8:44 AM
Tags: #cs5 #javascript #submenus #indesign_cs5.5 #indesign_cs5 #scripting #extendscript #menus
I've been able to sucessfully add items to the InDesign menu thanks in part to Marijan Tompa's (tomaxxi) blog post http://indisnip.wordpress.com/2010/08/08/create-customized-menu/
My test code (below) creates a new menu, and sucessfully adds two menu items plus a submenu. The submenu is causing me problems. When you first launch InDesign it's created in the proper place (in the middle of the menu). But when you relaunch InDesign, the submenu moves to the top of the menu and never goes back to it's proper position farther down in the menu where it was the first time InDesign was launched.
I've searched high and low in this forum, the web and InDesign's documentation and can't figure out how to keep it from moving (I want the menu to be farther down the menu, not at the top). I hope one of you kind souls will help me to control the position of the submenu (and have it stay there across launches).
Thanks in advance!
Dan
Here's the code I'm working with. This is saved as testMenu.jsx in the Scripts > startup scripts folder.
P.S. I'm testing this in CS5.5 currently, but ideally this solution should work in CS3 and later.
#targetengine "myTestMenu"
var myFolder = Folder(app.activeScript.path);
myFolder = myFolder.parent + '/Scripts Panel/';
var menuItem1Handler = function( /*onInvoke*/ ){
  app.doScript(File(myFolder + 'MyTest1.jsx'));
var menuItem2Handler = function( /*onInvoke*/ ){
  app.doScript(File(myFolder + 'MyTest2.jsx'));
menuInstaller()
function menuInstaller() {
  var menuItem1T = "My Menu Item 1",
       menuItem2T = "My Menu Item 2",
       menuT = "MyTestMenu",
             subT = "Sub Menu",
       subs = app.menus.item("$ID/Main").submenus, sma, mnu;
  var refItem = app.menus.item("$ID/Main").submenus.item("$ID/&Layout");
  subMenu1 = app.scriptMenuActions.item(menuItem1T);
  if( subMenu1 == null ) {
          subMenu2 = app.scriptMenuActions.add(menuItem1T);
  subMenu2 = app.scriptMenuActions.item(menuItem2T);
  if( subMenu2 == null ) {
          subMenu2 = app.scriptMenuActions.add(menuItem2T);
  subMenu2.eventListeners.add("onInvoke", menuItem2Handler);
  mnu = subs.item(menuT);
  if( mnu == null ) {
            mnu = subs.add(menuT, LocationOptions.after, refItem);
  mnu.menuItems.add(subMenu1);
  mnu.menuSeparators.add();
  subsSubs = app.menus.item( '$ID/Main' ).submenus.item( menuT ).submenus;
  mnuSubMenu = subsSubs.item( subT );
  if( mnuSubMenu == null ) {
          mnuSubMenu = subsSubs.add( subT);
  mnu.menuItems.add(subMenu2);
Replies 1 2 Previous Next
  • John Hawkinson
    Jun 25, 2009
    Dec 16, 2011 9:13 AM   in reply to Dan Rodney
    Dan, I haven't gone and tested this in your example, so this is speculative but:
    This isn't really advisable. In CS5 and later, if you don't check .isValid, you can have problems (I think).
    But also, in JavaScript, in general, you should not write
    if (varname == null)
    because it is usually sufficient to simply write
    if (varname)
    or
    if (!varname)
    and you should also never use the == operator when you can use the === operator, because it coerces to truthiness. So you should rather instead use
    if (varname===null)
    if you truly needed to check for null as opposed to undefined or zero.
    Perhaps more significnatly, shouldn't you be setting submenu1 inside that if, rather than submenu2?
  • John Hawkinson
    Jun 25, 2009
    Dec 16, 2011 10:03 AM   in reply to Dan Rodney
    If I run your script twice in a single session, I get errors.
    It also looks like it's not designed to work from the ESTK (depending on app.activeScript.path), which suggest you're not debugging this very efficiently...
    This error is undoubtedly due to your script not accounting for menu items that may already exist, and that's the case across a restart of InDesign -- menus persist.
    You might want to add some $.writeln()s that run as it is looking for existing menus and reference points and whatnot.
    Good luck!
  • John Hawkinson
    Jun 25, 2009
    Dec 16, 2011 9:54 PM   in reply to Dan Rodney
    As far as I can tell, the problems are related to testing for existing menu items, because they are being created again. But I still don't know how to properly test for them and only add them if needed. I feel like I'm so close, but yet so far away! Any help is greatly appreciated.
    So, you're saying that .submenus.item("whatever").isValid and menus.item("whatever").isValid do not correctly tell you whether the menus exist? They should!
    Dec 16, 2011 10:49 PM   in reply to John Hawkinson
    Hi Dan,
    Add the piece of code in before adding the menus to the main menu.
    try {
                        app.menus.item("$ID/Main").submenus.item(menuTitleMain).remove();
                    }catch(e){}
    I Hope this helps to you..
  • John Hawkinson
    Jun 25, 2009
    Dec 16, 2011 10:52 PM   in reply to கற்பனை (Imagine)
    Imagine:
    try { app.menus.item("$ID/Main").submenus.item(menuTitleMain).remove();
    But that's wrong! It means you'll reset the menu item every time. Among other things, that means if your user assigns a KBSC, it will be lost.
    Dec 16, 2011 11:11 PM   in reply to John Hawkinson
    is it possible to assaign a KBSC for our Created Menus?
  • John Hawkinson
    Jun 25, 2009
    Dec 16, 2011 11:12 PM   in reply to கற்பனை (Imagine)
    Well, for menu items, yes. They appear in the Scripts area.
    Dec 16, 2011 11:22 PM   in reply to John Hawkinson
    Hey Dan it has few side effect with my code,  try John suggested.  Thanks John.
    Dec 17, 2011 12:50 PM   in reply to John Hawkinson
    [I removed my nonsensical post. See my response below...]
    Harbs
    Dec 17, 2011 10:11 AM   in reply to Dan Rodney
    Hi Dan,
    There would be much to say about your code (variable scope, etc.) but the two most important, I think, are:
    — Custom menus and submenus are application-persistent while script menu actions are (usually) session-persistent
    In the specific case where an action directly relies on a script file, you don't need to deal w/ session-persistence and you can directly address the script file (no need of app.doScript() stuff and so on).
    Here is a possible approach (provided that the featured script files are located in the parent folder of the Startup scripts folder):
    #targetengine "DanRodneyMenu"
    // This script is a 'startup script', it runs each time ID starts
    // and shouldn't be rerun during the session. We don't really need
    // it to be session-persistent. However we use a #targetengine to
    // save a 'done' flag which prevents the script from being rerun.
    (function(/*obj|undefined*/HOST)
    // Install and/or update the menu/submenu
    // and connect the menu actions
        // HOST can be your framework container, if needed (default: $.global)
        HOST || (HOST=$.global);
        // Prevent the current (startup) script from being uselessly rerun
        if( HOST[$.engineName] )
            alert( "This script is automatically executed at startup. You shouldn't run it manually." );
            return;
        HOST[$.engineName] = true;
        // Settings and constants
        var MENU_NAME = "My Test Menu",
            FEATURES = [
                { caption: "My Menu Item 1", fileName: 'File-One.jsx', subName: "" },
                { caption: "My Menu Item 2", fileName: 'File-Two.jsx', subName: "My Sub Menu" }
            LO_END = LocationOptions.atEnd,
            INDESIGN_ROOT_MENU = app.menus.item( '$ID/Main' ),
            FEATURE_LOCATION_PATH = (function()
                var f;
                try{ f=app.activeScript; }
                catch(_){ f=File(_.fileName); }
                return f.parent.parent + '/';
        // (Re)set the actions
        // Note: checks also whether script files are available
        var    t, f, i = FEATURES.length;
        while( i-- )
            t = FEATURES[i];
            if( (f=File(FEATURE_LOCATION_PATH + t.fileName)).exists )
                // The script file exists => create the corresponding action
                // and directly attach the event listener to the file
                // (no need to use app.doScript(...) here)
                (t.action = app.scriptMenuActions.add( t.caption )).
                    addEventListener('onInvoke', f);
            else
                // The script file does not exist => remove that feature
                FEATURES.splice(i,1);
        // Create/reset the custom menu container *if necessary*
        // Note:  menus/submenus are application-persistent
        var    mnu = INDESIGN_ROOT_MENU.submenus.itemByName( MENU_NAME );
        if( !mnu.isValid )
            // Our custom menu hasn't been created yet
            if( !FEATURES.length ) return;
            mnu = INDESIGN_ROOT_MENU.submenus.add(
                MENU_NAME,
                INDESIGN_ROOT_MENU.submenus.item( '$ID/&Window' )
        else
            // Our custom menu already exists, but we must clear
            // any sub element in order to rebuild a fresh structure
            mnu.menuElements.everyItem().remove();
            // If FEATURES is empty, remove the menu itself
            if( !FEATURES.length ){ mnu.remove(); return; }
        // Now, let's fill mnu with respect to FEATURES' order
        // (Possible submenus are specified in .subName and created on the fly)
        var s,
            n = FEATURES.length,
            subs = {},
            sub = null;
        for( i=0 ; i < n ; ++i )
            t = FEATURES[i];
            // Target the desired submenu
            sub = (s=t.subName) ?
                ( subs[s] || (subs[s]=mnu.submenus.add( s, LO_END )) ) :
                mnu;
            // Connect the related action
            sub.menuItems.add( t.action );
    Marc
    Dec 17, 2011 12:47 PM   in reply to Harbs.
    Note to self: Don't respond to the forum before your brain is engaged...
    Ignore what I wrote above. It made no sense on a lot of levels...
    The issue at hand is caused by the following:
    Submenus do not go away until you remove them. When restart InDesign, the submenu still exists, so you are creating the meni tems below it.
    You need to create the submneu first and specify LocationOptions. Something like this:
                 subT = "Sub Menu",
              subMenu1 = app.scriptMenuActions.add(menuItem1T);
      subMenu1.eventListeners.add("onInvoke", menuItem1Handler);
      if( mnu == null ) {
      mnu.menuItems.add(subMenu1,LocationOptions.BEFORE,mnuSubMenu);
      mnu.menuSeparators.add(LocationOptions.BEFORE,mnuSubMenu);
      mnu.menuItems.add(subMenu2,LocationOptions.AFTER,mnuSubMenu);
    Harbs
    Dec 18, 2011 6:10 AM   in reply to Dan Rodney
    Great.
    I infer that my code did not work for you (although I don't know why).
    OK, considering the final "Correct Answer," I just would like to point out that your event handlers (menuItem1Handler, menuItem2Handler...) are all unnecessary. You can directly supply a script File as second argument in the eventListeners.add() method. In addition, your code does not check whether the corresponding files actually exist, so it does not accordingly update the menu items if some feature is missing.
    Marc
    Dec 18, 2011 6:35 AM   in reply to Marc Autret
    Hi Marc,
    I wouldn't infer any such thing. Looking at your code, it probably works fine.
    Chances are, my code was probably easier to read...
    Dec 18, 2011 7:13 AM   in reply to Harbs.
    Well, in this area, I think "all is relative" but I'm not going to argue this specific point.
    Now, let's suppose that someone wants to use your menu loader in another project having a different number of menu items and submenus. Say he wants to obtain the following hierarchy:
    MyMenu
       MyFeature1
       MyFeature2
       MySubmenuA
          MyFeatureA1
          MyFeatureA2
          MyFeatureA3
       MySubmenuB
          MyFeatureB1
          MyFeatureB2
    etc.
    Do you see how many changes he needs to do in your code?
    In the solution I suggest, he only has  to update the FEATURES array this way:
    FEATURES = [
       { caption: "MyFeature1", fileName: "File-One.jsx", subName: "" },
       { caption: "MyFeature2", fileName: "File-Two.jsx", subName: "" },
       { caption: "MyFeatureA1", fileName: "File-A-One.jsx", subName: "MySubmenuA" },
       { caption: "MyFeatureA2", fileName: "File-A-Two.jsx", subName: "MySubmenuA" },
       { caption: "MyFeatureA3", fileName: "File-A-Three.jsx", subName: "MySubmenuA" },
       { caption: "MyFeatureB1", fileName: "File-B-One.jsx", subName: "MySubmenuB" },
       { caption: "MyFeatureB2", fileName: "File-B-Two.jsx", subName: "MySubmenuB" }
    Is this less readable?
    Marc
    Dec 18, 2011 7:37 AM   in reply to Marc Autret
    Like you said, it's relative. I personally find your code a pleasure to read, but my natural style is a bit different.
    It really depends on your background.
    If you have a strong OOP background, your code is pure poetry!
    If you don't have an OOP background, it takes a lot of mental overhead to follow how the code is supposed to work.
    Harbs
    Dec 18, 2011 7:41 AM   in reply to Marc Autret
    When I answer questions, I try to stick as closely to the coding style of the OP as I can, to help answer the question at hand. (It helps clarify the answer in few words -- and I don't enjoy excessive writing...)
    Chances are I'm not going to change anyone's coding style in a single forum post...
  • John Hawkinson
    Jun 25, 2009
    Hey, Marc: I'm going to be sort of blunt. Your code is hard for most people to read because it uses Javascript idioms they are entirely unfamiliar with, which don't make a lot of sense to people not really familiar with the language. And that's what most people here are. Let's take a walk through it:
    The comment itself is confusing. Actually, it's even confusing to me.
    Tbe || idiom is confusing. Most people don't know what it means offhand.
    Well, this isn't confusing, but I think it's bad. One of the important things to do is to test what happens when the menus already exist, and that's easiest to do by rerunning the script.
    All caps for a function-local variable? Even using all caps for a globally scoped variable (Crockford) is confusing, but for a function-scope variable? That confuses me!
            FEATURES = [
    Use of Objects is justified here, but they are probably confusing.
    Anonymous functions...definitely confusing! I'm also not sure what the point of this function heere is. Why not execute the code directly
    on the next line?
    Variables named "_"? Confusing!
    And this is why anonymous functions are confusing! Not much to be done about it, but why use one where you don't need to. It's not like we're polluting the global namespace here.
        while( i-- )
    Use of a while loop is a totally legitimate style choice, but I think it's typically less readable than a for loop. YMMV, of course!
            t = FEATURES[i];
    I'm horribly guilty of this, but single-letter variable names are not the most readable.
    More parentheses imply more mental gymnastics to understand. Breaking this into two lines,
    with t.action=addEventListener... would help readability.
      var s,
            subs = {},
            sub = null;
    Wait, a mid-function var block? Gasp! What's up with that? Crockford's right on this. One var statement and all at the top.
    I am not sure why we're initializing sub to null -- what's wrong with the good old undefined? This probably doesn't qualify as confusing.
    Caching FEATURES.length in n is good for performance, but it probably doesn't matter here, and makes it more confusing to read. Not by much, but let's say half a confusion point. I would also say that "++i" is harder to read than "i++", maybe to the tune of 0.1 confusion-points, but maybe that's just me. YMMV Extremely.
                mnu;
    The ternary conditional operator, ?:, is pretty much always hard to read. And it's worse with short-circuit or-ing, ||, or three close-parens in rapid succession. Of course ?: tends to promote extra () as it almost always becomes ()?(): so...
    And then it's worth re-emphasizing, basically nobody understands the anonymous function paradigm .
    So there we have it, that's why I think your code is confusing to most readers.
    (On the other hand Dan's final code ignores my recommendation and still has those abysmal ==null tests in there. What's up with that? )
    Dec 18, 2011 7:50 AM   in reply to Dan Rodney
    That's odd. John's post seems to exist, but doesn't show up...
    Dec 18, 2011 7:51 AM   in reply to Harbs.
    That seemed to do it... Weird...
  • John Hawkinson
    Jun 25, 2009
    Dec 18, 2011 8:11 AM   in reply to Harbs.
    It's worse than that. Cache corruption.
    Viewing from adobe-vm-wa06.sgvm2hosted.jiveland.com
    I see my post but not your replies. Dumping cookies and reloading
    fixes it, because I get another server.
    I'll start a thread in Forum Comments.
    Dec 18, 2011 8:17 AM   in reply to John Hawkinson
    OK guys. Once again I admit my coding style has many faults and I really do not claim it is better than any other. It's just my way. I use it because I understand it better, I make it more easily evolve and I identify more easily the internal logic. But it's only because I used to do like that, and what is right for someone may definitely be wrong for someone else.
    Anyway, my point is not about style. I'm just talking about factorization and reusability. Let down my code in itself, just consider the approach I suggest. What I mean is that the response considered correct has some issues and can be improved clearing useless event handlers, adding file checking, removing global vars and, why not, supporting reusability.
    Marc
    Dec 18, 2011 8:58 AM   in reply to Dan Rodney
    Dan Rodney wrote:
    Marc. Is it possible to insert menu dividers in your example? And if so, how?
    You mean menuSeparators, right?
    I slightly expanded the code to support the following syntax:
    FEATURES = [
       { separator: true, subName: "" },
       { caption: "My Menu Item 2", fileName: 'File-Two.jsx', subName: "My Sub Menu" },
       { separator: true, subName: "My Sub Menu" },
       { caption: "My Menu Item 3", fileName: 'File-Three.jsx', subName: "My Sub Menu" }
    Also, I removed the #targetengine stuf and the HOST argument. As John said, this is uselessly complicated for such a project. Note that this startup script does not need to run in a persistent engine.
    Here is a possible implementation:
    // MenuLoader
    // (#targetengine is not required)
    (function()
    // Install and/or update the menu/submenu and connect
    // the corresponding menu actions if script files are available
            FEATURES = [
                { caption: "My Menu Item 1", fileName: "File-One.jsx", subName: "" },
                { caption: "My Menu Item 2", fileName: "File-Two.jsx", subName: "My Sub Menu" },
                { caption: "My Menu Item 3", fileName: "File-Three.jsx", subName: "My Sub Menu" }
                var f;
        var    t, f,
        while( i-- )
            t = FEATURES[i];
            if( t.separator ) continue;
            else
        if( !mnu.isValid )
                MENU_NAME,
        else
        var s,
            subs = {},
            sub = null;
            t = FEATURES[i];
                mnu;
            // Connect the related action OR create a separator
            if( t.separator )
                sub.menuSeparators.add( LO_END);
            else
                sub.menuItems.add( t.action, LO_END );
    Marc
    Dec 18, 2011 10:50 AM   in reply to Dan Rodney
    About isValid missing in CS3, you could try sth like this:
    // Declare isValid() at the beginning of the current scope/script
    var isValid = ( parseFloat(app.version) >= 6 ) ?
        function(o)
            return o.isValid;
        function(o)
            var r = false;
            try    {
                ('id' in o && o.id) ||
                ('index' in o && o.index);
                r = true;
            catch(_){}
            return r;
    Then replace myObj.isValid by isValid(myObj) in the entire code.
    Marc
    Dec 18, 2011 11:13 AM   in reply to Marc Autret
    null works perfectly well for menu actions. I'm not sure why we're making a deal of this...
    FWIW, here's the IsValid function that I use:
    IsValid = function (obj){
        try{
            if(!obj){return false}
            if(kAppVersion>=6){
                return obj.isValid;
            var test = obj.parent;
            return true;
        catch(err){return false;}
    kAppVersion is a constant I have defined like so:
    kAppVersion = parseFloat(app.version);
    (Every valid object in InDesign has a parent.)
    Harbs
    ( P.S. The test variable name is extraneous, but it makes it obvious what it's doing...)
  • John Hawkinson
    Jun 25, 2009
    Dec 18, 2011 11:20 AM   in reply to Dan Rodney
    John, as for the ==null tests, they work in CS3 and later. If I switch to isValid that only works in CS5 (from what I understand). What cross-version compatible code do you think is better?
    Oh, I wasn't referring to .isValid! I didn't mean that at all. I meant what I said in post #1, after I mentioned it. Replace if (var==null) with if (!var). === is almost always better than ==, because truthiness of == causes confusion and problems. But in ifs, you might as well use the implicit truthiness and not test explicitly, and write for clarity. (Someone is going to say this argument is defective ).
    By the way, there's some sample Adobe script that creates menus. Maybe it's hidden in the Bridge SDK or something. I can't remember, something to do with some font. I haven't looked at the code though, so who knows. I suspect it is rather different than any of the examples so far...
    Marc's absolutely right, your code should not be using global variables! What a nightmare those are. Remember anything in a function without an explicit 'var' on it somewhere is global. "Oops." That's what happens when you design a language in 10 days (Javascript).
    Dec 18, 2011 11:38 AM   in reply to John Hawkinson
    Is this what you're talking about? It's distributed in the InDesign SDK...
    XHTMLExportMenuItem.install = function()
        if(app.name == "Adobe InDesign") {
            // set up our script preferences
            var currDOMVersion = app.scriptPreferences.version;
            if (currDOMVersion != XHTMLExportMenuItem.requiredDOMVersion)
                app.scriptPreferences.version = XHTMLExportMenuItem.requiredDOMVersion;
            // determine and store the path from were we load our scripts from
            XHTMLExportMenuItem.storeScriptsFolderPath();
            // load XHTMLExporter for the strings
            var xhtmlExporterScript = XHTMLExportMenuItem.loadScript('XHTMLExport.jsxbin');
            if ( !xhtmlExporterScript.exists )
                xhtmlExporterScript = XHTMLExportMenuItem.loadScript('XHTMLExport.jsx');
            assert( xhtmlExporterScript.exists, "XHTMLExport.jsx* missing; load failed" ) ;
            if ( xhtmlExporterScript.exists )
                var cacheCurrent = Folder.current ;
                try
                    Folder.current = XHTMLExportMenuItem.scriptsFolder ;
                    app.doScript( xhtmlExporterScript ) ;
                finally
                    Folder.current = cacheCurrent ;
                if ($.locale != 'en_US')
                    // try to load localized strings
                    var localizationScript = XHTMLExportMenuItem.loadScript('Resources/XHTMLStrings-' + $.locale + '.jsxbin');
                    if ( !localizationScript.exists )
                        localizationScript = XHTMLExportMenuItem.loadScript('Resources/XHTMLStrings-' + $.locale + '.jsx');
                    assert( localizationScript.exists, 'Resources/XHTMLStrings-' + $.locale + '.jsx* missing; load failed' ) ;
                    if ( localizationScript.exists )
                        try
                            Folder.current = Folder( XHTMLExportMenuItem.scriptsFolder + '/Resources' ) ;
                            app.doScript( localizationScript ) ;
                        finally
                // menu action for the File:Export for menu
                var actionname = localize(xhtmlExportStrings.FORDREAMWEAVERACTIONNAME);
                var action = app.scriptMenuActions.item(actionname);
                if(action == null) {
                    // first launch:
                    // we need to create the menu action
                    var action = app.scriptMenuActions.add(actionname);
                    action.area = app.translateKeyString('$ID/KBSCE File menu: ExportForSubMenu');
                    action.checked = false;
                    action.enabled = true;
                // install event listeners for our action
                action.addEventListener("onInvoke", XHTMLExportMenuItem.exportSelectedItems);
                action.addEventListener("beforeDisplay", XHTMLExportMenuItem.enableDisable);
                action.addEventListener("afterInvoke", XHTMLExportMenuItem.cleanup);
                // install the menu item
                var exportForMenu = app.menus.item(app.translateKeyString('$ID/Main')).submenus.item(app.translateKeyString('$ID/&File')).submenus.item(app.translateKeyString('$ID/ExportForSubMenu')) ;
                exportForMenu.menuItems.add(action);
                // store the action in a class variable
                XHTMLExportMenuItem.action = action;
            if(currDOMVersion != XHTMLExportMenuItem.requiredDOMVersion)
                app.scriptPreferences.version = currDOMVersion;
    Harbs
    Dec 18, 2011 11:45 AM   in reply to Harbs.
    Because—I totally agree with John— using ==null is both a bad practice and semantically irrelevant.
    Marc
    Dec 18, 2011 11:48 AM   in reply to John Hawkinson
    In my opinion, discussions about == vs. === vs implicit resolutions is kind of silly. I have no issue using ==. Just make sure you understand what it means.
    Personally, I only use === when I really need it. That way it's clear what I'm testing for... When I'm testing for bull or boolean values, I usually skip the "==" altogether.
    I don't take everything Crawford says as if it's the bible. They're only his opinions after all...
    Harbs
  • John Hawkinson
    Jun 25, 2009
    Dec 18, 2011 11:49 AM   in reply to Harbs.
    *cry*
    No. Normally I'd say you should include the filename when you make such references, but in this case... please don't.
    There's some script that adds a toplevel menu for a Font. I guess I am just not excited enough (afraid?) to go looking for it. Especially after that snippet you posted.
    Dec 18, 2011 11:50 AM   in reply to Marc Autret
    Tell that to Jonathan Brown who designed it in the first place!
    (See the code I pasted above.)
  • John Hawkinson
    Jun 25, 2009
    Dec 18, 2011 11:52 AM   in reply to Harbs.
    The problem is that it is often fairly subtle "when you really need it," and you don't notice until you've been bitten by it.
    Everyone is pretty much always better off with ===.
    Crockford.
    And yes, his opinions are actually increasingly problematic. I can't even use JSLint anymore, he's added so many inappropriate checks that really boil down to style. The jslint_com yahoo group is kind of unpleasant. Oh well.
    Dec 18, 2011 11:53 AM   in reply to John Hawkinson
    (I love making grown men cry...)
    The snippet I posted above was written by Jonathan Brown. It's pretty obvious where it came from (HTML export).
    The font snippet is in the InDesign Scripting Guide pdf.
1 2 Previous Next
