bunbunhead
differences between Browserlab ie7 & ie developer tools browsermode: ie7 + onion skin problem
Dec 16, 2011 6:48 AM
Tags: #problem #developer #ie #skin #vs #browserlab #tools #onion #again #ie_positioning #+
I've just noticed display differences between what I see in browserlab for ie7 and what I see using ie9, but in browsermode:ie7.  I would have thought they would show the same as both are supposed to represent what the webpage would look like in ie 7.  Please can someone explain:
a) why they should be different,
b) which is the correct one.
Basically the Menu is perfect in BLab, but is floated left in browsermode:ie7.
There is nothing out of the ordinary in the code for this page, just html, css, a tiny bit of javascript & some php.
I am using windows 7 on a PC and the problem occurs if I use BLab through Firebug or directly from Dreamweaver.
The url is my old site that I am in the middle of updating, but I still get the same error with the new site that I am testing locally:
http://www.laughingrabbit.co.uk/
Kind regards
I am also having a problem with the onion skin feature, which I had about 2 months ago, but which then went when I deleted the cache and rebooted - no such luck this time.
When I try and show 2 browser views over each other, only one will show when I slide the slider bar making direct comparison impossible - both views stay the same as the one on the left.
eg try http://www.laughingrabbit.co.uk/contact.html  The corners of the form should be rounded only in later versions of ie, as it isn't supported in earlier version.
It is the same either through the main BL interface or Dreamweaver.
I have tried closing down BL, deleting cache etc (the usual stuff), but it doesn't make any difference.  I work on a PC.
Has anyone else had issue with this and if so, how did you solve it.
AND YES, I AM SLIDING THE SLIDER FROM LEFT TO RIGHT and all over, but ti makes no difference
regards
Bek
    Dec 16, 2011 10:10 AM   in reply to bunbunhead
    Hi bunbunhead,
    I can confirm that this is not a BrowserLab issue, and might have a clue as to why you're seeing something different. We tested your page in BrowserLab and in IE7 at 1024x768 resolution and the menu appears the same in both. When our QE upped the resolution to 1280x1024 and looked at the page in IE7, the menu was shifted left to the point where it was touching the Laughing Rabbit logo image. That sounds like the issue you're seeing, so I assume when you're testing in IE9 you're testing at a resolution greater than 1024x768.
    Hope this helps,
    Mark
    Dec 16, 2011 10:15 AM   in reply to bunbunhead
    Can you provide one or more screenshots to demonstrate the issue you're seeing with Onion skin mode?
    Dec 16, 2011 10:37 AM   in reply to bunbunhead
    Well, I'm a bit stumped. I can't think of any reason for this to happen.
    1. When you're seeing this and you press the "2" key to move to Two-up view, do the screenshots have the proper rounded and unrounded corners?
    2. It looks like you're testing in Firefox, what version do you have installed?
    3. Can you try using BrowserLab in another browser (IE or Chrome) and see if you get the same issue there?
    4. What version of Flash Player is installed in Firefox? You can check here: http://www.adobe.com/software/flash/about/
    Dec 16, 2011 10:55 AM   in reply to bunbunhead
    Thanks for the update. We'll see if we can repro the same issue, and will log a bug if we can, but for now it sounds like you have a workaround
