Media Always Pending...
Dec 15, 2011 8:54 AM
Hope you can help me.  I have 1 month into a project and now that I'm ready to send it out to the TV networks, I keep getting this error when opening the project:
Then 95% of my footage never loads (even though the status thing in the bottom left says all media is loaded).  My completed timeline looks like this now, and I can't see any of my video in the playback monitor:
And the one sequence that DOES show I have some video, only half of the clips are available.  This is what one of my multicam sequences looks like:
All my audio is intact and is playable, but I can't see the video in my program monitor.
Hmm... Just noticed this.  Is this a clue?  I cannot get playback through my program monitor, but if I turn the multicam monitor panel on, even if MC is NOT enabled, I can watch it in the MC window.  Here's two shots of the same place in time (CTI) with 1) the MC monitor, and 2) the program monitor.
Premiere crashed before this happened and gave me the chance to save a backup copy, if I remember right.  When I reopened it, then this is when everythign went pending.
Any suggestions would be appreciated.  I've already tried importing the project into a new project without any luck.
  • joe bloe premiere
    Dec 6, 2009
    Dec 15, 2011 9:15 AM   in reply to Toomany3
    Were I in a similar situation, I would be tempted to try unlinking all of the original media
    in the project then deleting all of the media cache and database files (via explorer),
    opening the project, relinking all media and allowing the cache and database to re-generate.
  • joe bloe premiere
    Dec 6, 2009
    Dec 16, 2011 11:39 AM   in reply to Toomany3
    Next, I would try relocating the cache and database to a different physical drive...
    eliminate the possibility of a corrupted disk.
    Jan 6, 2012 4:03 PM   in reply to Toomany3
    Were you ever able to solve this problem? I'm getting the same error message and seeing the same symptoms, and I'm also working in multicam sequences. It appeared for me one day after I imported a previous version of a sequence from an old version of my project file into the current project file. If I fix it, it only lasts for that session, and then I'm back in the same place the next day. I can fix it temporarily by importing the sequence into a new project file, but from there I can't use the Project Manager to make a new version of it. I just get that same error message ending in -2892.
    Jan 14, 2012 2:57 PM   in reply to Toomany3
    I found that just relinking all the media solved the problem just fine. (CS5.5)
    Jan 15, 2012 8:27 PM   in reply to Toomany3
    Thaks for the update. I had to give up too. I only lost one sequence, and it was only a couple days worth of work, so it wasn't nearly as bad as your situation. I'd be interested to hear about it if anyone finds a solution to this error.
    Apr 10, 2012 1:08 AM   in reply to Zach Powers
    Here's another thread with the same error, I think.
    http://forums.adobe.com/message/3775353
    I found that I just have to disable, then enable, the "media pending" stuff, and it comes right back.  And the problem comes back everytime the project is closed.  So you can set all your enabled clips to a group, or a color label, if you want, to make it easy to select them all and enable/disable it everytime you open...
    What a bug.  Hope this is addressed soon!
    http://images3.wikia.nocookie.net/__cb20080519135510/uncyclopedia/images/archive/8/8d/20081210171539!Gollum.jpg
    "We hates it!"
    ___________
    - wb
    May 23, 2012 7:17 PM   in reply to westonwoodbury
    Did you ever find a solution?
    I have all of the media visible and playable (I can hear it) but it still says Media Pending and won't let me export!!!! Help!!!premiere-pro-media-pending.jpg
    And It's happening in multiple projects.
    This second project won't even load the little previews, but like you said with multi-cam - when in multi-cam mode it plays and views fine!
    have a project (well multiple I need to work on) but one in particular I need for tomorrow and NO WHERE does it seem people have an answer posted!
    What's the solution?
    Neither AME or PP can export footage and I
