Retrieving random record set from SQL and also applying an ORDER
Dec 16, 2011 3:31 PM
I need a query that is capable of obtaining X amount of random records from a SQL2008 database, but I also want those results to then order by a numberic field in the same table, camp_priority
I have
SELECT TOP #DisplayAmount#,camp_uid,camp_title,camp_text,camp_image_type
FROM campaigns
WHERE camp_uid IN
etc..etc
then at the bottom I have
ORDER BY newid(),camp_priority
The problem seems to be that I'm getting random records, but it's not ordering by the camp_priority
Anybody have any ideas?
Mark
    Dec 16, 2011 3:54 PM   in reply to ACS LLC
    I have an idea.  Take the newid() out of the order by clause.
    Mind you, that only solves the order by problem.  I don't share your opinion that you are getting random records.  You'll have to give that one some more thought.
    Dec 17, 2011 2:47 AM   in reply to ACS LLC
    I'd wanna check the performance of it before running with it as a solution, but this [sort of thing] should work:
    SELECT *
    FROM (
         -- your actual query here
         ORDER BY NEWID()
    ) subq
    ORDER BY subq.columnYouWantToOrderBy
    Adam
    Dec 17, 2011 4:36 PM   in reply to ACS LLC
    Your first subquery doesn't have a SELECT statement.  That'll be one source of errors.
    As for weighting the significance of your records before returning them "randomly", you could order them on the sum or product of two components:  a weighting and a random part.  A very simple (perhaps overly simple) would be to weight the records between 1-5, and then add a random component between 1-5 (or 1-10, whatever... you'll need to decide the significance of each).
    I can't comment on whether newid() is slow or not... have you got a citation for that (out of interest)?
    Adam
    Dec 18, 2011 1:53 AM   in reply to ACS LLC
    ACS LLC wrote:
    It looks like I must have the syntax wrong, it's throwing an error.
    I've posted the query lower down.
    Are you perhaps aiming for something like this?
    <CFQUERY name="GetCamp" DATASOURCE="#datasource#">
    SELECT *
    FROM
        (    SELECT TOP #DisplayAmount# camp_uid,camp_title,camp_text,camp_image_type
            FROM campaigns
            WHERE camp_uid IN
                (SELECT camptarget_camp_uid FROM CampTarget
                 WHERE camptarget_country = '#session.usercountry#')
            AND camp_UID IN
                (SELECT category_camp_UID FROM category_list
                 WHERE category_cat_uid IN
                        (SELECT aff_cat_uid FROM aff_cat
                         WHERE aff_cat_aff_sub_uid = #val(session.affsub)#))
            AND camp_status = 1
            AND camp_stack = 1
            <CFIF #ListLen(session.servedcamps)# GT "0">
            AND camp_uid NOT IN (#session.ServedCamps#)
            </CFIF>
            ORDER BY newid()
        ) subq
    ORDER BY subq.camp_priority
    </CFQUERY>
    Dec 19, 2011 9:40 AM   in reply to ACS LLC
    > Notice how it goes from 4ms or less, to 329ms.. that seems like a big increase just to add in a NOT IN section
    > The test dbase only has 6 records in it, and camp_UID is the primary key. I even tried to add an extra index but it made no difference
    > What do you think? Normal behaviour?
    I think databases usually come with profiling tools for investigating this sort of thing...
    Adam
    Dec 19, 2011 10:44 AM   in reply to ACS LLC
    Not sure, wouldn't know where to start with that
    Surely the answer to that is the same as with any situation where there's a question of "how do I..."
    Type this into your browser:
    http://www.google.com
    After that, type in a string in the input box that reflects whatyou want to know.  Press "Search"...
    [etc]
    Adam
    Dec 19, 2011 10:48 AM   in reply to ACS LLC
    ACS LLC wrote:
    I did that, and it lead me back to the Adobe Forum ;-)
    You googled for how to do database profiling on whatever DB platform you're using, and the best link was back to these forums?
    [cough]bullsh!t
    Go and do some research.
    Adam
    Dec 19, 2011 5:58 PM   in reply to ACS LLC
    "not in " really slows down queries.  A very unintuitive alternative is to do something like this:
    select etc
    from etc
    where somefield in
    (select somefield
    from etc
    except
    select somefield
    from etc
    where somefield in (that list or subquery)
    If your db does not support the keyword except, it might support the keyword minus.  If you are using mssql, it supports both but they behave differently so test early and test often.
    Dec 20, 2011 6:01 AM   in reply to ACS LLC
    Both sample queries are slow, but it does show the difference.  It's a count of patients who visited yesterday for the first time this year.
    This query takes 43 seconds
    select count(distinct hsc_number)
    from patient join visit_fact using (hsc_number)
    where registration_date = '20111219'
    and hsc_number not in
    (select distinct hsc_number
    from visit_fact where registration_date between '20110101' and '20111218'
    This one takes 9 seconds
    and hsc_number in
    (select distinct hsc_number from patient join visit_fact using (hsc_number)
    except
    They give the same answer.
    Feb 16, 2012 11:52 PM   in reply to ACS LLC
    ACS LLC wrote:
    I have records that have the priority of
    3
    5
    6
    6
    6
    8
    By getting the top 5, random, using priority, I would have expected records with priority
    3
    5
    6
    6
    6
    and 8 would not be present.
    However I just ran it and I get
    3
    5
    6
    6
    8
    That's not the desired result
    From what you've explained, I think your query is behaving as expected.  If you ask someone to choose 5 numbers at random out of the set {3,5,6,6,6,8}, and to sort the result, then there will 4 possible answers:
    {3,5,6,6,6}
    {3,5,6,6,8}
    {3,6,6,6,8}
    {5,6,6,6,8}
    Therefore, what you obtained was just one possibility. If you run the query frequently enough, it will produce each of the 4 possibilities.
