AES 256 Revision 6 (PDF 2.0) Encryption
Sep 19, 2011 4:06 PM
I am trying to implement decryption of AES 256 Revision 6 (PDF 2.0) as described in the ISO 32000-2 spec and having some success but getting some peculiar results that I cannot resolve and would appreciate some suggestions.
Using Acrobat X on a PC and encrypting using password encryption compatible with Acrobat X, I created a set of about 20 Acrobat X encrypted PDF tests. When I ran these through our implementation to decrypt as following ISO 32000-2 particularly Algorithms 2.A and 2.B most decrypted successfully and produced correct output. However a few failed either in the authentication phase or in the intermediate key computation stage, with the latter showing an error by an invalid decryption of the first stream of PDF encountered. Next I tried another set of different tests and also got a similar pass rate. Finally I took one unencrypted PDF test and chose the same security settings of compatible with Acrobat X, restrict editing, and printing, and allowed print and used the same password for 15 generated versions of this PDF test. 13 of these 15 resultant encrypted tests ran successfully with our implementation of the Revision 6 decryption algorithm. Two failed, with one failing a match on both user and owner key and the other failing computing the intermediate owner key.
In the past when we have implemented earlier Revision 5 256 AES, or even older compatibility versions it always was the case that you either had the software working or you didn’t. And the new PDF 2.0 2B algorithm with 64+ hashes and 64+ aes encryptions of data along with 16 byte mod 3 math computations leaves little room for error.
  I believe that Acrobat when encrypting is choosing a random AES IV and all data including input /U /O /UE, and /OE strings differ. Even for the case described above of the same input test, same password, and same Acrobat encryption options. Thus the input into Algorithm 2-B will differ but the output should for authentication match the first 32 bytes of the O or U key or should result in a correct final result for intermediate owner or user key if the corresponding match occurred above.
However for the few exceptions that fail the above decryption it is not easy to determine what went wrong. Just about any change to the implementation of Algorithm 2.B breaks all working test cases instead of giving a clue as to what the issue is. The possible suspects are the new SHA-384 and SHA-512 and the encrypt code. We have used SHA-256 and the AES decrypt portion in earlier implementation of revision 5 and had no problems. The AES and hash code we are using is from Gladman1. I was wondering what others are using? It looks like Acrobat X is using RSA BSAFE Crypto – C2 at least for FIPS. Could Leonard or somebody else at Adobe tell me if this RSA software is also used in general with Acrobat X?
And I think that it would be very beneficial to have and publish a set of test vectors given input into algorithm 2.B along with correct intermediate results for each step. For each hash – including which method used per step show hash results, and also encryption step results, number of steps beyond 64 minimum, as well as final result. For the 80% of tests I have working I could produce this info. For those tests I cannot get working I would need help. Perhaps someone at Adobe or elsewhere who has had greater success than I have can help? I can provide input for the problematic tests either through this forum or privately at David.Lincoln@csr.com.
1) http://www.gladman.me.uk/
2) http://blogs.adobe.com/security/2011/05/update-fips-validation-certifi cates-for-acrobat-and-reader-x.html
    Dec 14, 2011 12:43 PM   in reply to Dave Lincoln
    I create a simple file called 256encrypt.pdf and encrypted with aes256
    I am using "Algorithm 2.B: Computing a hash" from ISO32000-2 to verify the user password
    user password: password
    User string from the PDF test file : f4 65 f1 69 9a e2 ea 71 ba e7 6b 48 bb 12 8f 1f 18 74 e3 d3 e2 97 7e b8 d6 fe 9f 7f 86 b0 6d 89 c9 38 40 c5 64 dc 5a 32 04 4d 9c 6f 28 d2 98 d0
    User string hash value:  f4 65 f1 69 9a e2 ea 71 ba e7 6b 48 bb 12 8f 1f 18 74 e3 d3 e2 97 7e b8 d6 fe 9f 7f 86 b0 6d 89
    User Validatiaon salt: c9 38 40 c5 64 dc 5a 32
    User Key salt:04 4d 9c 6f 28 d2 98 d0
    The input for the "Algorithm 2.B: Computing a hash" is as follows:
    user Validation Salt: c9 38 40 c5 64 dc 5a 32
    password: 70 61 73 73 77 6f 72 64 (password)
    step 1: SHA256(password+user Validation Salt)
    the result is  K = 9d 47 2d 4e f0 96 cd dd 7a 8c 04 8d b4 d2 b8 ee be fe b9 9f 7f cc e1 29 ea 63 ad f2 a3 d5 11 5b
    step 2: Make a new string K1 with 64 repetitions of the input password and K
    K1= 70 61 73 73 77 6f 72 64 9d 47 2d 4e f0 96 cd dd 7a 8c 04 8d b4 d2 b8 ee be fe b9 9f 7f cc e1 29 ea 63 ad f2 a3 d5 11 5b
    Total 64 times , total length = 0xa00
    step3: Encrypt K1 with AES_128(CBC)
    AES_CBC_128_NOPADDING:
    Key = 9d 47 2d 4e f0 96 cd dd 7a 8c 04 8d b4 d2 b8 ee
    IV =   be fe b9 9f 7f cc e1 29 ea 63 ad f2 a3 d5 11 5b
    K1 64 repeat of the 70 61 73 73 77 6f 72 64 9d 47 2d 4e f0 96 cd dd 7a 8c 04 8d b4 d2 b8 ee be fe b9 9f 7f cc e1 29 ea 63 ad f2 a3 d5 11 5b
    Result : Total length is 0xa00. The beginning part of the E is
    E =
    47 df 2a 7f 90 8a c4 d9 f2 8b a0 f1 49 f0 8e 09 51 c4 a3 ce fd 28 48 f3 d7 c1 04 76 1b 6b 5b f2 6d 3d 2c 3f 03 26 76 06 d5 67 44 c8 2a b6
    10 02 a5 8d a7 93 4f 94 02 b9 bf 93 b5 2d 17 82 02 3b f7 8e 8a 07 0f 18 ed 19 b3 ba 55 8b 14 b7 45 16 80 47 4f 6e c3 b6 20 d2 72 cd d1 46
    2c d3 88 f7 c4 f7 e3 3a 04 3d 72 4f e0 d2 66 63 c4 9c 77 7c c5 53 fd 69 81 f6 3b 3d f5 8e b2 bd 66 4e 0f c6 1e 96 5e 91 e2 3d 60 5c 60 75
    a3 13 49 58 85 e8 bb 37 93 91 4c 4f 79 a5 80 f2 13 be 44 22 aa e5 ee 6c 29 2c 76 50 a3 15 85 69 5e e9 c5 29 13 2a f6 67 51 8e 1e 7f 23 8a
    90 a7 fe 93 c7 ff 45 ee 2a f0 c0 70 f1 78 2e 80 bd be 06 4f ad 69 4d 47 e6 3f ae e2 6a 76 ef 3e 56 8f 2d f5 c9 49 26 f3 7e 6e 61 8b 5e e6
    e6 2d dd 76 cd 30 33 1d fe bf 11 60 ce 33 35 43 da b7 33 9b b9 6a 86 cd 35 a0 ca 84 99 0c ca 71 28 b3 01 b9 23 b4 a0 87 4e fb ff af b6 bd
    step4:
    The result of the first 16 bytes of E mod 3 is 1
    step5:
    Using SHA384 to get 48 bytes K
    K = 29 de 28 c1 f0 17 c9 37 bd 93 97 e3 b5 51 b0 86 b9 0c 96 e0 77 28 87 1c 11 7b 41 ce 64 bf a8 7f f2 8b a2 7b 52 58 79 a9 63 c0 b2 31 f8 4e e4 6e
    This is the end of round 1 and go back to step 2 using this new K
    When round is equal or bigger than 64, check E[last byte], if E[last byte] > round -32, go back to step 2
    The final round is 69. and the final result is
    K = ab 7c c6 03 bc da 85 51 3f 3d 22 fb 58 8c 42 1d 45 67 55 92 9f 4f d2 41 b3 93 07 04 7d b1 30 6d
    But this K does not match with the first 32 byte of the user string.
    Dec 14, 2011 2:16 PM   in reply to junq@yahoo.com
    Please attach your encryption file. I already make this work. it will be easier for us to help if we have your test file. My guess is that you should have more rounds after you check K.
    Mark Jin
    Dec 14, 2011 2:19 PM   in reply to mark.jin
    Thanks you very much for your help. The file is attached.
    Dec 14, 2011 2:22 PM   in reply to mark.jin
    I am new to this forum. How do I attach the file? I already had 69 round.
    Jun
    Dec 15, 2011 12:45 PM   in reply to junq@yahoo.com
    Jun,
    Is this the only file you tried. I check your steps and most of them are correct. The only missing part is the last step. I made the same mistake  the first time since PDF specification is vague on this. After several experiement, from my experience, the last step should be when round is equal or bigger than 63, check E[last byte], if E[last byte] > round -31, go back to step 2. The index start at 0.
    If you tried several encryption file, the pass rate should be close to 90%, the rest 10% should be covered by above last step change. If you still has probelm with the file, then my guess will be the mod 3 calculation part.
    Let me know if you have more trouble. Send me the data if needed and I will run more checking for you.
    Mark Jin
    Dec 15, 2011 1:57 PM   in reply to mark.jin
    Mark,
    Can you help me check the round 63 data?
    In round 63, UTSHA384 is used, and the E and K are as the following:
    K:
    ec 25 99 9c 6a 0d 1b c0 a9 70 78 39 7d 11 bd b8 ff ee 66 9c 82 70 cd 18 50 ba 33 95 05 16 0c 7b 20 de 09 12 90 37 76 43 7d 2a 78 60 db 36 20 ea
    E: Total bytes is 2560
    6e 0a c9 51 18 83 6b 67 e0 eb 27 f0 a4 9e 37 57 e9 1c 70 71 b3 61 cd 2b b8 dd f1 23 64 1e 6d 9b f8 67 49 48 93 3a 28 3a 96 e0 e1 77 04 8c 7c 22 99 0e 1b 4a 41 e7 bc 4b b3 c8 dd ee 00 74 72 92 ec 9d 0b b2 e6 7f 6d 9a a6 ea 9c b0 5d 73 07 36 21 f4 02 50 50 39 76 01 24 66 bd 2b..
    The last byte of E = 0xc0
    Thanks.
    Dec 16, 2011 7:50 AM   in reply to junq@yahoo.com
    Jun,
    I run your encryption file, the round 63(round start from 0) data(E and K) is different from what you told me.
    The data from your original post(step1-step5, round 0) are all correct. I suggest you to take a look at your implementation of AES128(cbc). probably the IV and chainning mode does not set up properly.
    Mark
    Dec 16, 2011 1:22 PM   in reply to mark.jin
    Mark,
    Thank you very much for your help.
    Can you post the first few bytes of the E for the round 0 and round 1?
    For example
    round  = 0;
    loop 1: AES128(cbc) result of E
    loop 2: AES128(cbc). result of E
    until loop 64: AES128(cbc) result E
    round = 1loop 1: AES128(cbc) result of E
    Or can you send me the data in each loop and round and I can compare with mime?
    Jun
    To: "junq@yahoo.com" <junq@yahoo.com>
    Sent: Friday, December 16, 2011 9:50 AM
    Subject: Re: AES 256 Revision 6 (PDF 2.0) Encryption AES 256 Revision 6 (PDF 2.0) Encryption
    Re: AES 256 Revision 6 (PDF 2.0) Encryption created by mark.jin in PDF Language and Specifications - View the full discussion
    Jun,
    Mark
    Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: AES 256 Revision 6 (PDF 2.0) Encryption
    To unsubscribe from this thread, please visit the message page at Re: AES 256 Revision 6 (PDF 2.0) Encryption. In the Actions box on the right, click the Stop Email Notifications link.
    Start a new discussion in PDF Language and Specifications by email or at Adobe Forums
    For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
    Dec 19, 2011 9:07 AM   in reply to junq@yahoo.com
    round 0
    E:47 df 2a 7f 90 8a c4 d9
    K:29 de 28 c1 f0 17 c9 37
    round 1
    E:b7 1c b5 38 81 24 81 d9
    K:b9 35 c6 d4 54 f3 77 ad
    round 2
    E:61 7b 7b 0b 81 e4 f2 40
    K:e4 b5 4d 2c 97 1d f3 56
    Dec 19, 2011 9:51 AM   in reply to mark.jin
    I got the exactly same result as your.
    But for my understand, all those three are in the round 0
    round = 0;
    while((round < 64) || (E[LastByte] > (round - 32)))
        for (j = 0; j < 64; j++)
            step3: Encrypt K1 with AES_128(CBC) to get E
            step4: Calculate first 16 bytes of E mod 3
            step5:Using SHA256, SHA384 or SHA512 to HASH E get bytes K, then go back to step 2
        round ++;
    For the round = 0;
    j = 0; I got the same result as yours.
    j = 1; I got the same result as yours.
    j = 2; I got the same result as yours.
    j = 63; I got the match.
    E: 8a bc c6 cf 64 cf be
    K: f4 65 f1 69 9a e2 ea which match the user string
    Is this means that I do not need the for (j = 0; j < 64; j++)? Is there any problem with my loop control?
    Thanks.
    Dec 19, 2011 10:22 AM   in reply to junq@yahoo.com
    Hi Jun,
    Check out my post on Dec 15. PDF soecification is vague on this, I did some experiemnt to find this out. After you change your while loop control, you will be fine.
    Mark
    Dec 19, 2011 11:56 AM   in reply to mark.jin
    We just made some improvements in the latest draft of ISO 32000-2 in this area to improve things.  Those of you who are part of that process (which would be where you obtained this information to begin with, since it's not documented anywhere else at this time) should review the DIS when it becomes available.
    From: Adobe Forums <forums@adobe.com<mailto:forums@adobe.com>>
    Reply-To: "jive-850561111-8igo-2-2fqo0@mail.forums.adobe.com<mailto:jive-850561111-8igo-2-2fqo0@mail.forums.adobe.com>" <jive-850561111-8igo-2-2fqo0@mail.forums.adobe.com<mailto:jive-850561111-8igo-2-2fqo0@mail.forums.adobe.com>>
    Date: Mon, 19 Dec 2011 10:22:21 -0800
    To: Leonard Rosenthol <lrosenth@adobe.com<mailto:lrosenth@adobe.com>>
    created by mark.jin<http://forums.adobe.com/people/mark.jin> in PDF Language and Specifications - View the full discussion<http://forums.adobe.com/message/4093632#4093632
    Dec 19, 2011 1:32 PM   in reply to mark.jin
    Mark,
    You are absolutely right. The problem is in the while loop control. I can get the file works without any problem. Thank you very much.
    Dec 19, 2011 1:37 PM   in reply to junq@yahoo.com
    Glad I can help. Good luck.
    Dec 20, 2011 8:14 AM   in reply to Dave Lincoln
    Not yet – but there will be shortly!
    Reply-To: "jive-156860415-8igo-2-2fs8i@mail.forums.adobe.com<mailto:jive-156860415-8igo-2-2fs8i@mail.forums.adobe.com>" <jive-156860415-8igo-2-2fs8i@mail.forums.adobe.com<mailto:jive-156860415-8igo-2-2fs8i@mail.forums.adobe.com>>
    Date: Tue, 20 Dec 2011 08:08:39 -0800
    created by Dave Lincoln<http://forums.adobe.com/people/Dave+Lincoln> in PDF Language and Specifications - View the full discussion<http://forums.adobe.com/message/4095666#4095666
    Nov 28, 2012 2:48 AM   in reply to junq@yahoo.com
    Can you tell me whats exactly you changed in your while loop to get it worked. I am facing a similar problem.
    Thanks in advance.
    Nov 28, 2012 7:51 AM   in reply to Dharins
    view my previous post. The only missing part is the last step. I made the same mistake  the first time since PDF specification is vague on this. After several experiement, from my experience, the last step should be when round is equal or bigger than 63, check E[last byte], if E[last byte] > round -31, go back to step 2. The index start at 0.
    Nov 29, 2012 1:08 AM   in reply to mark_jin
    I tried changing my loop as you mentioned. But it is still not working.
    Here is a outlook of the logic in my code,
    K = Sha256Hash(Userpassword + User validation salt);
    round=0;
    for(int c=0;c<64;c++)
         Step 1: K1 = 64 repetitions of userPwd and K
         Step 2: E= Encrypt K1 with AES128 CBC No padding
         Step 3: i = Int(16bytes of E) MOD 3
         Step 4: Based on i the hash is taken and is set as new K.
         round++;
         if(round>=63)
               if(E[Last byte] > round - 31) // I tried with round-32 also
                        Goto Step1;
    Please let me know if i am doing anything wrong in any of the steps above.
    Thanks a lot.
    Dec 3, 2012 4:05 AM   in reply to Dharins
    Any input?
    Dec 4, 2012 1:28 PM   in reply to Dharins
    try this
    if(round>=63)&&E[Last byte] <= round - 31)
         exit;
    Dec 5, 2012 3:18 AM   in reply to mark_jin
    Thanks Mark,
    After adding the condition, the for loop is breaking after the 63rd iteration itself. And the result not matching U string.
    Do you suggest adding a outer while loop along with the for loop? [Pls look into the code in my previous post]
    I tried with an infinite loop repeating the all the steps, but the K bytes never matched U string bytes and the loop just kept running.
    So i think the problem could be with my AES128 encrytion code.. as all other steps seems quite straight.
    Dec 5, 2012 8:14 AM   in reply to Dharins
    Dharins, you are right. From your description, if a infinite loop can not get a match, the problem could be
    1AESCBC
    2computation of E as big endian
    3 SHA algorithm.
    You may use Jun's previous post as your data input to debug the problem.
    Good luck.
    Dec 6, 2012 12:59 AM   in reply to mark_jin
    You are right Mark, the problem was with the big-endian conversion. After fixing,  it is working with the same loop structure.
    Thanks a lot.
