Miss Caroline
Field count
Dec 20, 2011 5:09 AM
Tags: #count #javascript #table #format #rows #pdf_forms #syntax #livecycle_es2
I need to track the number of Yes, No, and Checkbox selections made in a multiple page form. These need to be counted individually and summed for a total count to be displayed on the final page of the document. In other words, Yes was selected 10 times; No was selected 5 times; Checkbox was selected 4 times. 19 total selections were made. Can someone please help me with the javascript syntax to access the fields to insert these figures on the final page? The final form will be a .PDF created using Adobe LiveCycle Designer ES2.
This is the form hierarchy:
form1
Tables_P1
tblStatP1
Row1
Yes
No
RadioButtonList1
Checkbox1
    Dec 20, 2011 6:46 AM   in reply to Miss Caroline
    Does each page have its own table (Tables_P2, etc) or is it all one big table?
    Dec 20, 2011 1:42 PM   in reply to Miss Caroline
    You can use a loop to check all check button objects (check box and radio buttons) within your form.
    Here's an example.
    function countChk(vNode) {
              if (vNode.className === "field") {
                        if (vNode.ui.oneOfChild.className === "checkButton") {
                                  if (vNode.items.nodes.length > 1) {
                                            if (vNode.value.oneOfChild.value == 1) {
                                                      nChk++;
                                  } else {
                                                      nYes++;
                                            } else if (vNode.value.oneOfChild.value == 2) {
                                                      nNo++;
                                            } else {
                                                      nNone++;
              for (var i = 0; i < vNode.nodes.length; i++) {
            countChk(vNode.nodes.item(i));
    var nYes = 0;
    var nNo = 0;
    var nNone = 0;
    var nChk = 0;
    countChk(xfa.form);
    Textfield1.rawValue = nYes + " | " + nNo + " | " + Math.floor(nNone / 2) + " | " + nChk;
    Dec 23, 2011 5:51 AM   in reply to Miss Caroline
    Your script will not work, as you cannot use a variable in JavaScript to resolve a node.
    Use the resolveNode method to use variables in the expression.
    Also, to campare a value you have to use "===" or "==" instead of "=".
    //initialize counts
    var nYes = 0;
    var nNo = 0;
    var nChk = 0;
    var nTotal = 0;
    for (i=1; i<27; i++)
               if (xfa.resolveNode("RadioButtonList[" + i + "]").rawValue === "Yes")
                nYes++;
               else if (("RadioButtonList[" + i + "]").rawValue === "No")
                nNo++;
               else if (("CheckBox[" + i + "]").rawValue === 1)
                nChk++;
    nTotal = nYes + nNo + nChk;
    this.rawValue = nTotal;
    Did you test the script I posted before? It will look for all checkButton objects in the whole form, no matter if in tables or subforms.
