Hi All
We have a word 2007 document mail merged template which we want to create a number of PDF documents from. We have manged to use the "Merge to PDF" option to create the requird PDF files but for some reason a number of embedded fonts are not being embedded.
If we choose the option to save to pdf from the Word toolbar this works fine apart from the fact we now have one massive PDF document rather than individual files as required.
Within the Adobe Distiller printer driver options we are choosing the following standard for the output file as this is a requirement for our local printers to be able to print the produced PDF files correctly. We cannot understand what in different in the output process in Adobe to be creating this problem.
Any help or ideas to why this happening would be appreciated
Please confirm a couple things.
You are Printing to the Adobe PDF Printer and not using the Acrobat button in Word?
You are using the PDF/X-1a preset shown. (This can be set as the default in the PDF Printer properties (from control panel) and/or be selected from the Properties tab in the print dialog).
The Standard preset option dictates that some fonts are never embedded, the PDF/X-1a preset dictates that all fonts be embedded. (From the edit button next to the preset, you could dig down to the fonts tab and see the fonts handling for the presets) Exception, some fonts prohibit font embedding, typically those obtained from Internet Free Font sites.
Can you post a shot of the pdf properties dialog showing the fonts tab?
Hi
To confirm
I'm using the Merge to PDF option within the Word 2007 Mailing Tab on the Word 2007 toolbar(see screen shot). I understand this works in conjunction with Adobe PDF printer
Yes I'm using the PDF/X-1a preset as per my screen shot
Please see screen shot of the font properties for the PDF file in question
Word Menu option used to create PDF files
Hope this helps
Advanced > Document Processing > Batch Processing
New sequence {enter name}
Select Commands > Preflight > Preflight > Add
Highlight Preflight in the Righthand Pane > Edit
From that resultant Preflight Batch Sequence Setup - Run Preflight Check Using drop down menu > Embed Fonts > Save
Ok, Ok, Ok >
The Batch Sequence dialog should still be open, choose your new embed fonts fixup > Run Sequence
HTH
Just a couple of thoughts on the problem.
Using the "Merge to PDF" button evokes PDFMaker not the Adobe Printer.
(Open a new Word document, From "Mailings", click the Merge button. Not being set up for a mail merge will evoke a dialog. Last item in this dialog identifies use of PDFMaker.)
So the Preference configuration of PDFMaker is were the desired Distiller job option needs to be set.
The font set associated with characters coming from the data source may be a variable.
Is it a font set that can be embedded?
Be well...
