archive playback suddenly not working
Dec 20, 2011 4:39 PM
i've been working all day and playing back the same archives successfully.  suddenly, they're not loading and i'm not getting any kind of error messages.  the archives do exist on my webdav server, new archives are being stored there successfully. i just can't play them back now, and i have no information on why they're not playing back.
the trace (with my account details redacted) is as follows.  i can send a private message to an adobe employee with my account details if tha'ts required to look into this.
first i need to find out why this is happening, then i need to know if there's a way an error message can be reported back to my app.
one thing i did do was modify a node through the LCCS Air app.  it was a simple custom node where i changed persistItems from true to false.
19:27:29 GMT-0500    #TicketService# ticket received: 8bnh0sd8nx3k
19:27:29 GMT-0500    Getting FMS at https://na2.collaboration.adobelivecycle.com/fms?ticket=8bnh0sd8nx3k&p layback=adam_roxanne_3&proto=rtmfp, attempt #1/3
19:27:29 GMT-0500    result: <fms>
  <origin>fms7.acrobat.com</origin>
  <proto_ports>rtmfp:1935,rtmps:443</proto_ports>
  <retry_attempts>2</retry_attempts>
</fms>
19:27:29 GMT-0500    protocols: [object ProtocolPortPair],[object ProtocolPortPair]
19:27:29 GMT-0500    [attempt 1 of 2] Connecting to 0/1: rtmfp://fms7.acrobat.com/playback/na2-sdk-3073a7e4-fa08-4353-a662-e05 f0e45cf15/[REDACTED]/[REDACTED] #startProtosConnect#
19:27:29 GMT-0500    tempNetStatusHandler 0/2,NetConnection.Connect.Success
19:27:29 GMT-0500    isTunneling? false
19:27:29 GMT-0500    is using RTMPS? false
19:27:29 GMT-0500    #SessionManagerPlayback 889 fms connected: [Event type="connected" bubbles=false cancelable=false eventPhase=2]
nothing happens after this point.
    Dec 20, 2011 5:21 PM   in reply to adam+k
    Congratulations! You found a bug
    Basically a process that manages playbacks on one of the FMS server has died and I suspect the FMS itself doesn't realize that and keeps pretending that can server your playback.
    I will need to restart the service on that machine but it may take a while (don't want to disrupt other meetings). One suggestion is to try to wait 10 / 15 minutes for the service to "forget" that your playback was running on fms7 and hopefully when you retry you'll get reassigned to another server.
    Again, the solution is for me to restart the service: that would clear up the problem but we may wait until later tonight to do it.
    Sorry for the inconvenience
    Dec 20, 2011 6:24 PM   in reply to adam+k
    once a year
    again, this is a strange case where a bug caused one particular process to fail. We'll have to fix the problem and add an extra monitoring for this case. It just went under the radar...
    Dec 21, 2011 9:36 AM   in reply to Raff.
    ok, I found the problem and it's affecting both recording and server to server API. I am working on a fix and we'll restart the servers as soon as possible (but it may be a few hours away).
    sorry for the inconvenience.
    Dec 21, 2011 5:53 PM   in reply to Raff.
    The problem has been solved. Sorry it tooks longer than expected but we wanted to fix the root cause instead of spending the day restarting servers (and of course got caught into a bunch of unrelated problems)
