I have question after installed WB 10 in Windows 7 x64 and can't open/new process in new/get application. it showed blank screen that process.
and i checked log in D:\Users\Songvit\Workbench 10\.metadata\.log
!SESSION 2011-11-22 10:15:59.625 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_26
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: #Product Runtime Configuration File
Command-line arguments: -os win32 -ws win32 -arch x86 #Product Runtime Configuration File
It loaded with JRE x86
i install JDK 1.6 update 29 x64 (jdk-6u29-windows-x64.exe from ORACLE) and already set environment path of WB_JRE_Home to C:\Program Files\Java\jre6
but in my ADEP server has installed in Windows 2003 Server (x86) and install WB too. It worked.
i typed mistake "or". It mean "to"
i'm administrator of windows 7 x64 and right click to open WB with administrator and can login to workbench with admin of ADEP but when i open process or create new process, in process design not have everything tools for design workflow.
I am having this issue also on my Windows 7 64 bit machine. When I try to open Workbench it takes forever, slips into a non-responsive state, and then when it finally does open I can't actually see anything in the design palette. On my old XP machine ADEP Workbench opened just fine. And on the same Windows 7 machine ES2 Workbench opens just fine.
Any ideas?
I am pasting in the Workbench log message.
!SESSION 2011-12-22 13:29:12.136 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 1 2011-12-22 13:29:13.586
!MESSAGE NLS missing message: Product_ReleaseVersion in: com.adobe.livecycle.workbench.core.messages.messages
!ENTRY com.adobe.lcide.rcp 1 0 2011-12-22 13:29:16.766
!MESSAGE Workbench started at: Thu Dec 22 13:29:16 EST 2011
!ENTRY com.adobe.ide.singlesignon 1 0 2011-12-22 13:29:17.696
!MESSAGE Workbench version '10.0.0.v201107102105'
!ENTRY org.eclipse.jface 2 0 2011-12-22 13:29:19.906
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2011-12-22 13:29:19.906
!MESSAGE A conflict occurred for F2:
Binding(F2,
ParameterizedCommand(Command(com.adobe.livecycle.workbench.applicatio nview.renameCommand,Rename...,
Category(com.adobe.livecycle.workbench.applicationview.category,%appl icationview.commands.category.name,%applicationview.commands.category. desc,true),
com.adobe.livecycle.workbench.applicationview.handlers.RenameHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(F2,
ParameterizedCommand(Command(org.eclipse.ui.edit.rename,Rename,
Rename the selected item,
Category(org.eclipse.ui.category.file,File,null,true),
,,true),null),
!ENTRY com.adobe.ape.core 2 1 2011-12-22 13:29:22.097
!MESSAGE Still waiting for DestinationService after 2 seconds
I got this in Workbench 9.5 after installing Workbench 10.0. The two do NOT like to cohabitate on Windows 7 x64. You could try downgrading your version of Flash Player back to 10.x. I think that fixed one of ours here.
I get non-responsive processes quite frequently, but I just restart Workbench and it seems happy again.
