hi. I'm editing a job in premiere/windows and the final output will be to DVD Pal. I have 3 formats of footage. What would be the best way to edit this?
The footage I'm using is:
59 fps 1280 x 720 shot with Canon 7D
50 fps 1280 x 720 shot with Canon 7D
25 fps 1440 x 1080 shot with Canon XHa1
So far, I'm editng in a sequence with settings:
frame size: 1440 1080
25fps timecode
Thank you to both of you. I've done a little research and it says that I'm best to convert NTSC to PAL in After Effects. I will be creating a PAL After Effects composition with the setting I want, then adding the NTSC footage to the composition, and then tell it to fit the composition width as well as add frame blending/pixel motion, and then I will add to render queue. Does this sound right?
