I installed 10.1 today and any time I play a flash video on hulu on youtube all it shows is a green screen, the sound works fine. I'm using firefox and windows 7 x64, video card is an ATI 4870. If i disable hardware acceleration it works but the video stutters a bit (not surprising), I was under the impression that with 10.1 hardware acceleration would work now.
I have the 10.2 version of ATI Catalyst drivers installed.
Hi, the following thread may be helpful to you:
http://forums.adobe.com/message/2706243#2706243
Hope it helps.
eidnolb
Hi, I should have read the entire thread. Well that doesn't sound good, if the beta was the fix, and now you have Installed the final release and have the green screen. Hmmmm.
Someone today had that issue and there was a response and it wasn't the beta. Ok, I found it. This user had a flashing green screen, but take a look.
http://forums.adobe.com/thread/657387?tstart=0
If this is a common issue, then we'll be receiving more threads and hopefully have a solution. I have never seen that, so don't have anything to suggest.
eidnolb
Hi, well so much for that. So back to square one. Do you think this is due to the 10.1? Did you ever experience this with the 10.0.45.2 version? I would just guess no. Until today I had not heard of anything like you describe nor those other threads.
You do have the Shockwave Flash Object Enabled in the IE add ons don't you? Check all add ons for it.
Then using FF, find the plug-in SWF and it should be Enabled as well.
Then you can also use this Adobe test site, first Using IE, then Using FF:
http://www.adobe.com/software/flash/about/
Let me know.
eidnolb
In my case, the browser hung on the 'green screen', so there was no ability to right-click in the video area to disable hardware acceleration. There's no option to disable hardward acceleration prior to playing the video. This problem occurred with all latest version of all browser and standalone flash players (i.e. Sothink FLV player). The only way I was able to disable hardware acceleration was to go to this site: http://kb2.adobe.com/cps/839/cpsid_83952.html and then right-click on the Flash logo block.
Flash and ATI's Catalyst drivers used to work and play well together, but obviously, that's no longer the case. After today's announcement from Adobe (conceding defeat of Flash to Apple/HTML5), it's probably hopeless to think that any more resources will be devoted to fix any more problems with it. ![]()
The fix is however simple and its not ur catalyst driver or adobe. While you are on a video page, right click anywhere inside the Flash Player and choose settings. Now click the first tab that says Display (look for the monitor icon) and uncheck “Enable Hardware Acceleration.” Then hit F5 or refresh..
Please read my 11/9 message above - there's no option to right-click inside the Flash Player because the browser (all of them FF, IE, Chrome) has locked up and hung. I just downloaded and installed another update to the Catalyst driver and the problem still exists, so I still believe it's the Catalyst driver that's to blame. I've reported the problem to ATI/AMD, but since it's been at least 6 weeks without a response or fix, I assume that they've ignored it.
Ok it's been a year and a half and I figured out why I was having problems now, I had to replace my motherboard for unrelated issues and when I did that Flash started working normally, I didn't reinstall windows when I did that so it must have been that. I think there may have been a voltage issue accross the PCI-e slot as I was having some other video issues at the end as well.
