I honestly don't know if this can be fixed within Cp, or if its soley an issue with the browser, but either way, if anyone knows or can direct me to the answer, I would be infinitely grateful...
I am publishing my Cp project and putting it online (Blackboard.com, if that matters), which works fine. The problem is that depending on what resolution the students' monitors are, the video may turn out to be too big or too small. The temporary (but bad) solution I thought of is to post two or three links on Blackboard (Bb), each with a different resolution that the student can choose based on their screen resolution. Here's the key thing that's driving me: A couple months ago, we had it so that when the browser was resized, it resized the Cp video with it. As a result of this, when the browser was full-screen, the Cp video was full-screen within the browser, i.e., no matter what resolution the student had, the Cp video would adjust to it. Here's the problem: For some reason, that stopped happening, and now, the video can't be resized at all within the browser. I know a lot about Cp, but practically nothing about integrating it with websites and stuff, so I'm yet to find out how to reproduce my past success. This is the only major problem with our system so far, and needs to be solved before we can launch, so if anyone can point me in the right direction, it would make me (and my boss) very happy.
Thanks.
Are you putting the SWF on BB or do you upload a package that contains not only the SWF but also the companion JS and HTML-files?
In the last case, you can change the HTML-file and replace the fixed width/height by 100%. Beware: resizing to another size than the original always results in quality loss.
Lilybiri
I upload all three files. Here is what the first frame of the video normally looks like, for reference:
Based on what you said, I opened the HTML file in Notepad and changed...
var so = new SWFObject("Unit 2.swf", "Captivate", "1281", "985", "10", "#CCCCCC");
to...
var so = new SWFObject("Unit 2.swf", "Captivate", "100%", "100%", "10", "#CCCCCC");
When I did that, the first slide looked like this:
...and changing the size of the window doesn't affect the size of the video. Any idea why this is happening?
Disregard the last message. I followed these instructions, written by Jim:
http://captivatedev.com/2011/08/28/scaling-adobe-captivate-content-acr oss-browsers/
...and now the results all look like the first pic above, but they still don't resize at all. Here's the entire new HTML script:
<!-- Copyright [2008] Adobe Systems Incorporated. All rights reserved -->
<!-- saved from url=(0013)about:internet -->
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title></title>
<script src="standard.js" type="text/javascript"></script>
<style type="text/css"> html, body, #CaptivateContent { height:100%; }
body { text-align:center; margin:0; padding:0; overflow:hidden; }
</style>
</head>
<body bgcolor="#f5f4f1">
<div id="CaptivateContent">
</div>
<script type="text/javascript">
so.addParam("quality", "high");
so.addParam("name", "Captivate");
so.addParam("id", "Captivate");
so.addParam("wmode", "window");
so.addParam("bgcolor","#f5f4f1");
so.addParam("menu", "false");
so.addVariable("variable1", "value1");
so.setAttribute("redirectUrl", "http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=S hockwaveFlash");
so.write("CaptivateContent");
</script>
document.getElementById('Captivate').focus();
document.Captivate.focus();
</script>
</body>
</html>
Also, you may want to give this widget a try...
http://www.cpguru.com/2010/10/15/captivate-stage-scale-mode-and-widget s/
Jim
Thanks for sending that link. I haven't read the whole thing, but it seems really complicated so I'm gonna save it for once I know what I'm working with.
Also, do widgets not show up in the library? I know they're in the timeline, but I don't see them in the library at all. I wanted to make sure I got them all...
Okay, so luckily none of my Flash animations were causing it. The culprits were the Cp Notepad widget, as well as a widget that I had custom-made a while ago, both by Flash-Factor. Yves won't give me the .fla file for his Cp Notepad, so I don't have access to the code to change it, and he gave me the files for the custom widget, but they're for Flash 5.5, so I can't open them, since I'm using 5.0.
So basically, I'm out of luck unless I can get him to change it for me? Or is there another work-around?
Thanks.
That is strange. I wonder why they would do it that way. I also wonder why the question slides are practically impossible to use... but that's another issue.
Good idea about getting the trial version, but that wouldn't help me with the notepad widget, since I don't have the file. I wonder why anyone would design a widget without including that functionality?
Anyway, it sounds like I'm just out of options. If anyone has any more ideas, I would love to hear them. Thank you very much for your help, Jim, as usual.
Just two more forum posts to get answered, and I can finally be done with my unit... Yay.
Thanks again.
