CS5.5 Extended - problem with importing audio .mov files
Dec 22, 2011 7:52 AM
I would like to import an audio file to my PS5.5 Extended. It supports .mov files, so I tried to File->Place a mov file exported from Audition CS5.5. But Photoshop says: "Could not place the document xxx.mov because the movie file could not be opened."
The mov file doesn't open in Windows Media Player either and the message is that the codec is unknown. But it opens without problems in QuickTime, as audio.
I am not sure if this is Audition or Photoshop problem, but the format, or codec which is used should be common to both programs, as they are from the same CS5.5 suite. By the way, I have all settings set to default in Audition. No idea what codec it is using.
My purpose is to import sound, and because PS Ext does not support sound files as such, I found a workaround in the internet to import a mov file. But it does not work for me..
    Dec 22, 2011 9:56 AM   in reply to Bluefix
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainfo.massanti.com/
    Do you have Quicktime installed?
    Dec 23, 2011 1:41 AM   in reply to Bluefix
    You're assuming too much. PS is, after all, primarily an image editor. It does not do any such thing as share code with Audition. Anyway, since you have that particular program and it saves audio to a ton of formats, why not simply make use of that facility and convert the file to something PS can actualyl swallow like a MOV with uncomporessed audio?
    Mylenium
