Cannot download any pdf file
Dec 22, 2011 10:51 PM
I cannot download any pdf file onto my computer.  I can view the file, but cannot download. When I try download the usual screen comes up asking whether I want to run or save the file.  I always click run and the download starts, but then the message comes up saying access denied.  I cannot print in the view mode or save onto my computer.  I used to be able to do this, but not I'm not able to with any pdf file, so there is no one corrupted file.  I receive many pdf files, so this is very irritating.  There is something wrong with my computer, but I have no idea.  Any help would be greatly appreciated
    Dec 23, 2011 7:41 AM   in reply to gsshaw59
    Have you tried right clicking on the url on the browser you are using and saving directly to the disk?
    Dec 24, 2011 6:48 PM   in reply to gsshaw59
    Does that only happen with PDF files?  Other downloads are ok?
    What is your operating system, b.t.w.?
    Dec 24, 2011 7:48 PM   in reply to gsshaw59
    Ok, let's try something...
    Go to http://forums.adobe.com/community/flashplayer?view=documents and download the top document.  On Windows 7 it should automatically go to %userprofile%\Downloads - the file name will be DOC-1451.
    Now open Windows Explorer and try to open the document; still the same error message?
    If yes, right-click on the saved document and select Properties.
    • what is the file size?  (It should be 98,084 bytes.)
    • on the Security tab, what are the permissions for your userid?  (It shouls at least have Read, Write, Modify.)
    • on the Details tab, what are the Attributes?  (It should just have an A.)
    See the corrected instructions two posts down.
    Message was edited by: ʇɐb ɹəuəllıʍ
    Dec 24, 2011 7:44 PM   in reply to gsshaw59
    Wait - I think I made a mistake with my above instructions!  I will write new instructions shortly; sorry for that!
    Dec 24, 2011 7:52 PM   in reply to gsshaw59
    Ok, let's try this again...
    Go to http://forums.adobe.com/docs/DOC-1451 and download the PDF document.  On Windows 7 it should automatically go to %userprofile%\Downloads - the file name will be flp_local_settings_manager.pdf
    • what is the file size?  (It should be 222,664 bytes.)
    • on the Security tab, what are the permissions for your userid?  (It should at least have Read, Write, Modify.)
    Dec 24, 2011 7:59 PM   in reply to gsshaw59
    Take your time; I also have to go away now (getting a haircut).
    Dec 25, 2011 4:59 PM   in reply to gsshaw59
    Can you open Adobe Reader by itself?
    If yes, can you try to open that downloaded document from within the running Reader?
    If you still get the same error, can you try to open that document with another application, e.g. Notepad?  (Just to see if it results in the same error; you won't see anything useful in Notepad.)
