skinned problem
Dec 29, 2011 1:54 AM
I write a vertex shader for skinned animation. But I got an error when I call Program3D::upload( kShader.m_kAGALShaderPair.vertexProgram.byteCode, kShader.m_kAGALShaderPair.fragmentProgram.byteCode ) :
Error: Error #3648: AGAL 验证失败: 对于 vertex 程序的 14 令牌中的 source operand 1,可读取临时寄存器组件,但无法写入。
    at flash.display3D::Program3D/upload()
in english:
Error: Error #3648:AGAL Verify failed: vertex program's 14 token source operand 1, read temporary register component, can not write.
The shader is:
<languageVersion: 1.0;>
vertex kernel TestSkinned3D <namespace: "Pixel Bender 3D examples";
                        vendor: "Adobe";
                        version: 1;>
        parameter float4x4 inp_matSkinWorldViewProject;
        parameter float4 inp_matSkinBone[90];
    input vertex float3 in_vtxPos
    input vertex float4 in_vtxWeight
    input vertex float4 in_vtxBoneIndex
    output float4 out_vtxClipPos;
    void evaluateVertex()
            int4 iIndex = int4(in_vtxBoneIndex);
            //float fWeight4 = 1.0 - in_vtxWeight.x - in_vtxWeight.y - in_vtxWeight.z;
            float4 inPos4 = float4( in_vtxPos.x, in_vtxPos.y, in_vtxPos.z, 1.0 );
            float4 f4BonePos;
        f4BonePos.x = dot( inPos4, inp_matSkinBone[iIndex.x] ) * in_vtxWeight.x ;
        f4BonePos.y = dot( inPos4, inp_matSkinBone[iIndex.x + 1] ) * in_vtxWeight.x;
        f4BonePos.z = dot( inPos4, inp_matSkinBone[iIndex.x + 2] ) * in_vtxWeight.x;
        f4BonePos.x += dot( inPos4, inp_matSkinBone[iIndex.y] ) * in_vtxWeight.y;
        f4BonePos.y += dot( inPos4, inp_matSkinBone[iIndex.y + 1] ) * in_vtxWeight.y;
        f4BonePos.z += dot( inPos4, inp_matSkinBone[iIndex.y + 2] ) * in_vtxWeight.y;
        f4BonePos.x += dot( inPos4, inp_matSkinBone[iIndex.z] ) * in_vtxWeight.z;
        f4BonePos.y += dot( inPos4, inp_matSkinBone[iIndex.z + 1] ) * in_vtxWeight.z;
        f4BonePos.z += dot( inPos4, inp_matSkinBone[iIndex.z + 2] ) * in_vtxWeight.z;
        f4BonePos.x += dot( inPos4, inp_matSkinBone[iIndex.w] ) * in_vtxWeight.w;
        f4BonePos.y += dot( inPos4, inp_matSkinBone[iIndex.w + 1] ) * in_vtxWeight.w;
        f4BonePos.z += dot( inPos4, inp_matSkinBone[iIndex.w + 2] ) * in_vtxWeight.w;
        f4BonePos.w = 1.0;
                out_vtxClipPos = f4BonePos * inp_matSkinWorldViewProject;
    Dec 29, 2011 4:19 AM   in reply to uchemo
    I have the same problem right now, my program is much much simpler.
    I think it relates to the count of temporary registers Agal has to use to compute your program. You can get it by looking at  AGALProgramPair.vertexProgram.temporaryRegisterCount.
    In the doc you can read, that if its over 8, the program.upload() will fail. But that not exactly true. Even some shaders with more than 9 registers are working while my program I have the problem with just uses 4 if I get it right. I just havent found out what exactly makes the change.
    Anyway...
    As soon as Iam using one float4x4 that is not a parameter and maybe one additional float4, its over. Even if I have under 8 temporary registers. Iam stucking for hours on this.
    Dec 30, 2011 2:20 AM   in reply to uchemo
    Ok, thats bad. To be honest, I have no idea how to fix this problem. Im stuck with this for 3 days now, cant getting my shader to work the way I want to.
    I hope someone else has an idea.
    Jan 19, 2012 4:15 PM   in reply to Pak762
    It's almost certainly runninng out of registers. The number of temporary registers available is very very limited and float4x4 fills them up very quickly.
    Bob
