NDBrendaH
Captivate 4 scoring in Peoplesoft ELM
Jan 26, 2011 10:15 AM
Hi all--hoping to get some help with our issue:  our Captivate courses are not scoring correctly when taken through our Peoplesoft ELM.  Our Articulate courses ARE scoring correctly.
The Captivate courses are scoring correctly on the ELM/Component piece, but not on the ELM/Activity piece--which is what shows up on all the training records and reports.
Here are the Quiz Preference settings we are using to publish our Captivate courses:
We have tried different combinations of these settings, but none seem to make a difference. Peoplesoft either records the score of the Activity as '80' or '100'...nothing else, no matter what the component/real quiz score is (80, 90 or 100).  The mastery score was set at 80, then we unchecked that, but still no change.
Does anyone have any suggestions?
    Jul 1, 2011 6:26 AM   in reply to NDBrendaH
    NDBrendaH ~
    I know this post is old, but i figured I would try and reach out to you through here.
    We have recently migrated to PeopleSoft ELM 9.1 and I have a course with a post test in Captivate 4 and have followed your recommendations for settings and i can get the score to pass to ELM, but still cannot get it to bookmark.
    Would you have some time to chat live?
    If so, I can first provide you with my email and then provide you with a contact number.
    Chris
    P.S. My email is utterc@gmail.com
    Dec 28, 2011 1:33 PM   in reply to NDBrendaH
    NDBrendaH
    I was just reading your posting from February 3, 2011 concerning the proper settings in Captivate to have scores correctly reported to PeopleSoft ELM and have a question.  If we do not care if they view every slide, do we still need to set Choose Report Data to Quiz results and slide views?  We have been selecting Quiz results only, but if this other setting gets the scores over we will use it.  And I assume for Reporting Level you select Interactions and Score because you selected Choose Report Data to include slides.  If you did Quiz results only, would you need that or could you go with Report score?
    Mary
    Dec 29, 2011 9:19 AM   in reply to NDBrendaH
    Brenda,
    Can I please ask you one more question.  In your setup, do you set the Pass/Fail option to a percent or to points?  We checked Report to LMS as = Percent, but we keep getting back the points (5 questions out of 5 correct, we get a 50, 4 correct we get a 40).  For Pass/Fail we have it set to 100%.  With the 50 or 40 that comes over, the learner is marked as Failed.
    I really appreciate you time.
    Mary Dial
    Emory University Human Resources
    1599 Clifton Road, Room 2-106
    Atlanta, GA 30322-0530
    Voice (404) 727-0861
    Fax (404) 727-4008
    Email mary.dial@emory.edu<mailto:mary.dial@emory.edu
    Dec 30, 2011 6:59 AM   in reply to NDBrendaH
    Mary ~
    Are you trying to just do a quiz or a course and a quiz combined?
    Knowing that, will help me a lot in how I best answer your question.
    Chris
    Dec 30, 2011 1:03 PM   in reply to utterc
    It is actually a program with 11 courses.  9 of the courses have a quiz requiring 100% score.  If we take the courses with quizzes at a fairly slow rate, everything seems to work fine.  But if a learner moves more quickly we seem to lose communication and even though the last screen in Captivate says they scored 100%, we see a lower score in PeopleSoft ELMS.  And instead of getting back a score in percent (even though the course set up says to send Percent) we get the raw score.  We are on 9.1 with bundle 7 applied.
    I appreciate anything you can add.
    Mary Dial
    Fax (404) 727-4008
Bookmarked By (1)
