How can all mime types for Office 2007 be included in accepting file types. This is what I have:
...accept="application/vnd.openxmlformats-officedocument.spreadsheetml.sheet, etc.".
...accept="application/vnd.openxmlformats-officedocument.spreadsheetml .sheet, etc.".
I would do it as follows, the way El Dombo would. Get hold of all the Office 2007 MIME types. Then shove them all in the accept attribute.
<cfset OFFICE2007MimeTypes = "application/vnd.openxmlformats-officedocument.wordprocessingml.document,application/vnd.ms-word.document.macroEnabled.12,application/vnd.openxmlformats-officedocument.wordprocessingml.template,application/vnd.ms-word.template.macroEnabled.12,application/vnd.openxmlformats-officedocument.spreadsheetml.sheet,application/vnd.ms-excel.sheet.macroEnabled.12,application/vnd.openxmlformats-officedocument.spreadsheetml.template,application/vnd.ms-excel.template.macroEnabled.12,application/vnd.ms-excel.sheet.binary.macroEnabled.12,application/vnd.ms-excel.addin.macroEnabled.12,application/vnd.openxmlformats-officedocument.presentationml.presentation,application/vnd.ms-powerpoint.presentation.macroEnabled.12,application/vnd.openxmlformats-officedocument.presentationml.slideshow,application/vnd.ms-powerpoint.slideshow.macroEnabled.12,application/vnd.openxmlformats-officedocument.presentationml.template,application/vnd.ms-powerpoint.template.macroEnabled.12,application/vnd.ms-powerpoint.addin.macroEnabled.12,application/vnd.openxmlformats-officedocument.presentationml.slide,application/vnd.ms-powerpoint.slide.macroEnabled.12,application/onenote,application/vnd.ms-officetheme">
<cfif isdefined("form.sbmt")>
<cffile action = "upload"
fileField = "myFile"
destination = "c:\test"
accept = "#OFFICE2007MimeTypes#"
nameConflict = "MakeUnique">
</cfif>
<cfform method="post" enctype="multipart/form-data">
<cfinput name="myFile" type="file">
<cfinput name="sbmt" type="submit" value="upload">
</cfform>
It takes all formats except for the spreadsheets. Any ideas?
What's the file extension of the spreadsheets?
xls, and xlsx
What MIME type is your computer sending when you attempt to upload one of these files? You can view that using Firebug, or something similar.
Dave Watts, CTO, Fig Leaf Software
jenn wrote:
xls, and xlsx
Xls? I suspected something like that. You said Office 2007!
MIME type for XLS: application/vnd.ms-excel
MIME type for XLS: application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
Oh, and watch out when you copy-and-paste. For example, you would have encountered a problem if you copied the list OFFICE2007MimeTypes that I used above. The software of this forum adds arbitrary spaces to the list.
Yes, I thought it was having an issue with xlsx, so I tried using an older version of the same document in xls. Both failed to upload. It is only the spreadsheet format that does not get uploaded. Do you think it could be a server issue?
There could be a problem with the binary content of that particular document. Repeat the procedure with a different XLSX file.
