uncle bobo
Adjustments/hue/saturation
Dec 31, 2011 9:42 AM
Tags: #photoshop_cs5
Using Mac Snow Leopard--when I click hue/saturation I don't get a dialog box, only the eye dropper appears, then I have to CMD/return to get out. Other Adjustments work fine. This is a new development, it worked fine recently.
    Dec 31, 2011 9:55 AM   in reply to uncle bobo
    Sounds like you moved the dialog onto another display, or are trying to use Spaces and ran into one of it's bugs.
    Dec 31, 2011 3:13 PM   in reply to uncle bobo
    No, it's not a bug.  It's user error.
    At one time you either had a secondary monitor attached which is now disconnected or you had a larger display screen resolution (more pixels wide by more pixels high) which you have since changed.  In either case the modal dialog box is now off screen.  You have no chance of finding it without first trashing your preferences.
    To re-create the preferences files for Photoshop, start the application while holding down Command+Option+Shift (Mac OS). Then, click Yes to the message, "Delete the Adobe Photoshop Settings file?"
    ____________
    Wo Tai Lao Le
    我太老了
    Dec 31, 2011 7:22 PM   in reply to uncle bobo
    The cursor changed as it normally does when that dialog is up, and the menus and tabs are disabled because the dialog is up somewhere.  I bet that pressing escape or return would get you back to a working state (because they dismiss the dialog).
    As Tai said: resetting your preferences will also reset the dialog location.
    Dec 31, 2011 8:32 PM   in reply to uncle bobo
    If your dock is visible and you have a display near the minimum required by Photoshop, then the HDRPro dialog may get clipped.  Hiding the dock should solve that, or you can use escape (cancel) and return or enter (ok) to close the dialog.
