ckunce
How can I generate my own InDesign ePub file without the encryption.xml file?
Dec 30, 2011 2:15 PM
Tags: #indesign_cs5.5 #epub #indesign_epub
My bookstore (B&N) will not accept my ePub file because it doesn't want the file encryption.xml included. How can I generate an InDesign ePub file, for my own books, without it? Is there a check box somewhere? I've searched through the ePub export box and the file info boxes—no luck.
Error message from B&N's PubIt.com:
We have found a file name called encryption.xml within your ePub file container, which means that part of, or all of, your file is encrypted. We do not accept any encryptions within ePub source files. Upon closing this message, please remove the encryption.xml file from your ePub, and you may attempt to upload your ePub file again.
If you wish to apply DRM to your title, go to Section 4, question H and select Yes. PubIt! will apply DRM to your title after you have uploaded your ePub file without encryption.
Thanks for your help…
    Dec 31, 2011 3:49 PM   in reply to ckunce
    Don't include embeddable fonts and in theory ID will not include the encryption.xml file.
    Take care, Mike
    Jan 1, 2012 7:56 AM   in reply to ckunce
    >.. I did limit my typefaces to only Times ...
    But did you try Mike's suggestion of not including them at all? It's a checkbox in the Create Epub dialog.
    Jan 1, 2012 8:09 AM   in reply to MikeWenzloff
    Sorry I wasn't clear. Don't embed fonts at all. Any.
    Take care, Mike
  • rontiara
    Jul 2, 2009
    Jan 2, 2012 3:25 PM   in reply to ckunce
    Mike -- You mentioned that you unpackaged your epub file and deleted the unwanted .xml file.  Which program did you use to do that?  I opened mine in Sigil, but I don't see an .xml file.  I did notice, however, that there is a folder named "fonts".  I wonder if deleting that would solve the problem, or make a worse mess.  I'm scared to try!
    But mostly I'm wondering which program you used to unpack the epub.
    Jan 2, 2012 3:50 PM   in reply to rontiara
    rontiara,
    That was ckunce who unzipped it. I imagine Stuffit will unzip it. Rename the file temporarily from having an epub extension to having a .ZIP extension. That's all an apub file is, is a ZIP compressed archive file.
    Best thing to do if your publisher requires no encryption is to opt not to embed the fonts. Do Google the process.
    Take care, Mike
    Jan 3, 2012 6:02 AM   in reply to MikeWenzloff
    Worth noting here.
    You cannot simply unzip the file on Mac. I’ve also had issues with it on WinXP.
    Works fine on Vista and Win 7, IME.
    Bob
  • rontiara
    Jul 2, 2009
    Jan 3, 2012 5:11 PM   in reply to Bob Levine
    Bob -- You are quite right:  on a PC, you can't simply unzip an epub file and then rezip it.  I wasn't aware it was possible on Vista and Win7, since I'm still using XP.  However, I did find a program that allows you to edit the HTML in an epub:  it's called Sigil.
  • John Hawkinson
    Jun 25, 2009
    Jan 3, 2012 6:38 PM   in reply to rontiara
    Err, you certainly can. Sometimes people have trouble. It's usually because a file browsing utility adds extra files to the unzipped directory that confuses the epub reader. (The Mac Finder can do this, which is why there is trouble over there). You might find it easier, under Windows, to use 7-Zip. But you can certainly unzip them on both platforms...
    Jan 4, 2012 1:40 AM   in reply to rontiara
    Sigil has the nasty habit of editing files & folder structures all of its own. For example, it silently strips out <video> tags that InDesign helpfully inserts. After some initial puzzlement I steered well clear of it and do all of my ePub-After formatting by hand, pending better software.
    Jan 4, 2012 5:53 AM   in reply to [Jongware]
    I use Dreamweaver.
    Bob
  • rontiara
    Jul 2, 2009
    Jan 4, 2012 3:46 PM   in reply to John Hawkinson
    My hunblest apologies, John!  You are quite right about 7zip:  I was able to unzip the file, make changes in plain ol' Notepad2, and rezip the file.  Then I just changed the extension from .zip to .epub.
    I can view it in ADE, so I'm assuming it will work in a Nook, etc., also.
    The last time I tried the unzip-rezip-rename process, I couldn't open the altered file.  But I was obviously using the wrong zip program.
    Lordy, it's hard to keep up!
    Thanks for your tip.
  • John Hawkinson
    Jun 25, 2009
    Jan 4, 2012 10:57 PM   in reply to Bob Levine
    I use Dreamweaver.
    Bob, do you have some way of editing EPUB files in Dreamweaver without uncompressing them? (At first I thought you meant it supported it. Then I listened to Anne-Marie in last week's podcast and tried it and concluded you didn't. Unless...there is a trick?)
    Jan 5, 2012 5:34 AM   in reply to John Hawkinson
    No…sorry for the confusion.
    On Win 7, I unzip the epub, do any touch up to the HTML and/or CSS in Dreamweaver and then rezip everything.
    Bob
    Oct 8, 2012 1:26 PM   in reply to ckunce
    Thanks for the tips everyone.  I ran into the same problem when uploading the knitting pattern I designed into barnes and nobles.  I found this link http://www.howtogeek.com/howto/19268/edit-epub-ebooks-with-your-favori te-html-editor/ very helpful as I couldn't figure out how to convert a file name.  Particular the bit about unchecking "hide extensions".   Then I just opened the zip file, deleted the encryption file and uploaded it no problem.
Bookmarked By (1)
