An Unexpected and Unrecoverable problem...(Mac OS Lion 10.7.2)
Jan 1, 2012 10:41 AM
Tags: #photoshop #cs3 #launch #lion #application #exit #unexpected #unrecoverable
Ran into an issue where I had the licensing error problem (failed to read about it here in the forums) so I thought I had to reinstall CS3 completely on my iMac. So I uninstalled it and performed the reinstallation. All the applications launch without issue and seem to be running fine with the exception of PhotoShop CS3. I get the following warning when launching it:
I have played around with plugins (because I read somewhere that this could be the cause). All of the plugins within the Photoshop app folder seem to be Adobe plugins. Is there a different location where I can find third party plugins that is NOT within the app folder? I should add that I also ran the fix permissions from Apple's Disk Utility and all comes up fine there.
I would like to get it running (currently, I have installed it as a stand alone on my MacBookPro and it is running fine there) with the rest of the CS suite. Any ideas on how to resolve?
Much appreciated for anyone's time if they have run into this or know how to resolve. Might be a quick fix, but at the moment it elludes me.
Cheers!
William
    Jan 1, 2012 12:16 PM   in reply to n8vdudeSF
    That's not a plugin problem - that's a problem with the permissions on the application, OS, or important support files.
    Areas to check:  ~/Library, /Library/Application Support, the Photoshop applicaiton itself.
    Jan 1, 2012 6:45 PM   in reply to n8vdudeSF
    Sounds like there's still something off. Have you tried creating a new user account and running from the new user?
    Jan 2, 2012 11:26 AM   in reply to n8vdudeSF
    Conversely: you coudn't get that error unless the OS was reporting a permissions problem.
    Jan 3, 2012 11:14 AM   in reply to n8vdudeSF
    try to install the application by activating the root admin account on mac
    try
    :-http://support.apple.com/kb/ht1528
