Photoshop CS4 and Mac OS10.7 Lion
Dec 28, 2011 5:30 PM
Photoshop CS4 is not working with Lion.  How can I fix?
    Dec 28, 2011 5:44 PM   in reply to carxprt
    Details are needed:
    First of all, what kind of Mac?  If it's one of the Macs with the infamous Intel integrated graphics (iMac, Mac Book, Mac Mini), we need not inquire further.  The number of bugs introduced by Lion in these machines is too numerous to go into.
    Otherwise, it would be useful to know whether CS4 is updated to version 11.0.2, Lion to 10.7/2, whether you Repaired Permissions with Apple's Disk Utility before and after every install, upgrade or update of the application and the OS, as well *** what other troubleshooting steps you have taken so far.
    Please read this FAQ for advice on how to ask your questions correctly for quicker and better answers:
    http://forums.adobe.com/thread/419981?tstart=0
    ____________
    Wo Tai Lao Le
    我太老了
    PS— Beyond that, you may want to consider upgrading while you can, as CS4 will be out of the upgrade loop the moment CS6 is announced, and that should/could be in a matte of weeks.  The new Adobe upgrade policy will be one version back only as of CS6.
    Dec 28, 2011 10:24 PM   in reply to carxprt
    Same here. I just upgrade mi iMac 3.06GHz IC2D to OS X Lion 10.7.2 and notice that Photoshop CS4  (CS4 Master collection) refuse to open. it says "You can't open the application Adobe Photoshop CS4 beause PowerPC applications are no longer supported" !?
    Seems all others CS4 Apps have no problem to open (After Effects, Bridge, Contribute, Device Central, Dreamweaver, Encore, Extention Manager, Fireworks, Flash, Illustrator, InDesign, Media Encoder, OnLocation, Premiere Pro, Soundbooth...) which make me think, if there is a bug, the bug is more probably in Photoshop.
    I use Unistall Adobe Photoshop CS4 and re-install it from the DVD, with no better result...
    Dec 29, 2011 6:39 PM   in reply to cldjr
    That sounds like you had CS4 set to open in Rosetta emulation before you upgraded to 10.7 --- and Apple no longer has UI to disable the rosetta emulation.
    Apple has been informed of the problem, and is supposedly working on a fix for it.
    See this article for a workaround:  http://kb2.adobe.com/cps/915/cpsid_91595.html
    Jan 2, 2012 4:02 PM   in reply to carxprt
    CS4 can be MIGRATED from an older disk on which it is working by using the migrate app in the lion utility folder.
    vince
    Jan 2, 2012 7:56 PM   in reply to vinsolo
    Thanks Vinsolo.
    It's what I did: use Lion to migrate my "old" Mac to the new one (in reality 2 disk partition). But Rosetta, which I totally forgot, has not been disable in the new install.
    Now, after Chris Cox remind it me, I solved the problem.
