I have a several LCES process that are called from an ajax app. All works well except when the user's session expires/timesout.
After that when the user tries to invoke one of the processes, jboss returns a http 401 error as it's Basic Authentication. I cannot always handel this correctly in ajax as browsers will intercept this 401 error and offer an authentication challenge.
I guess I need something like the remoting end point 'Custom Authentication' but for the REST end point.
1) Could I configure jboss to issue a redirect to a custom html page when a 401 exception accurs?
2) Could I configure jboss to return a 403 or 500 error when there is a 'not Authorized' exception, instead of the 401?
3) If I set "Require callers to authenticate:No" and 'Run as System" for the service is there any way I could then check within my process to see if the current user is actually authenticated?
Any other suggestions?
Thanks in advance,
Michael
Total Likes
Total Likes
Ans : Yes you can handle it in front end in ajax by having a seperate exception handler in the server side which redirects the page when 401 exception is thrown from adobe
No.
No you can not since you set "Require callers to authenticate:No" . You can track your session in adobe side only when the user authentication is set to yes
Jaison
Total Likes
