help in AS3 code of 24 hour countdown timer
Jan 2, 2012 8:57 PM
hello,
i  just wanna ask if someone can help me,
i created a 24 hour flash countdown timer here http://allofmyworks.weebly.com/flash.html
the problem is when it reaches the desired time, the time still counts and became negative,
what i want is to make it only 24hour countdown clock and when it reaches the time it will only stay in 00:00:00
thanks
here is the code i used
var endDate:Date = new Date(2012,0,4);
var countdownTimer:Timer = new Timer(1000);
countdownTimer.addEventListener(TimerEvent.TIMER, updateTime);
countdownTimer.start();
function updateTime(e:TimerEvent):void
          var now:Date = new Date();
          var timeLeft:Number = endDate.getTime() - now.getTime();
          var seconds:Number = Math.floor(timeLeft / 1000);
          var minutes:Number = Math.floor(seconds / 60);
          var hours:Number = Math.floor(minutes / 60);
          seconds %= 60;
          minutes %= 60;
          var sec:String = seconds.toString();
          var min:String = minutes.toString();
          var hrs:String = hours.toString();
          if (sec.length < 2) {
                    sec = "0" + sec;
          if (min.length < 2) {
                    min = "0" + min;
          if (hrs.length < 2) {
                    hrs = "0" + hrs;
          var time:String = hrs + ":" + min + ":" + sec;
          time_txt.text = time;
  • kglad
    Jul 21, 2002
    Jan 2, 2012 9:06 PM   in reply to probag123
    if(now.getTime()>endDate.getTime()){
         time_txt.text = "00:00:00";
    countdownTimer.stop();
    return
              seconds %= 60;
              minutes %= 60;
                        sec = "0" + sec;
                        min = "0" + min;
                        hrs = "0" + hrs;
  • kglad
    Jul 21, 2002
    Jan 3, 2012 6:55 AM   in reply to probag123
    to end on that date at 0800, use:
    var endDate:Date = new Date(2012,0,4,8);
    to use a 24hr countdown:
    var endDate:Date = new Date(new Date().getTime()+24*60*60*1000);
  • kglad
    Jul 21, 2002
    Jan 3, 2012 9:48 PM   in reply to probag123
    you're welcome.
  • kglad
    Jul 21, 2002
    Jan 5, 2012 6:42 AM   in reply to probag123
    copy and paste your code.
  • kglad
    Jul 21, 2002
    Jan 5, 2012 5:35 PM   in reply to probag123
    use the code i suggested:
    return
              seconds %= 60;
              minutes %= 60;
                        sec = "0" + sec;
                        min = "0" + min;
                        hrs = "0" + hrs;
  • kglad
    Jul 21, 2002
    Jan 7, 2012 8:07 AM   in reply to probag123
    it starts 1 day in advance of the current day.  ie, it's a 24 hour countdown.
  • kglad
    Jul 21, 2002
    Jan 9, 2012 8:18 AM   in reply to probag123
    you're welcome.
    Jun 20, 2012 11:39 PM   in reply to kglad
    Hello Doctor,
    How to make it Recurring ?
    if(time_txt.text == "00:00:00")
    countdownTimer.reset();
    Thank You.
  • kglad
    Jul 21, 2002
    Jun 21, 2012 1:14 PM   in reply to kglad
    var endDate:Date;
    startF();
    function startF():void{
    // if you want to restart:
    startF();
    return
              seconds %= 60;
              minutes %= 60;
                        sec = "0" + sec;
                        min = "0" + min;
                        hrs = "0" + hrs;
    Jun 21, 2012 4:11 PM   in reply to kglad
    Hello Doctor,
    Thank you for your prompt reply
    But I get this error:
    TypeError: Error #1009: Cannot access a property or method of a null object reference.
        at Untitled_fla::MainTimeline/updateTime()
        at flash.utils::Timer/_timerDispatch()
        at flash.utils::Timer/tick()
  • kglad
    Jul 21, 2002
    Jun 21, 2012 4:41 PM   in reply to KH000
    should be
    endDate=new Date(new Date().getTime()+24*60*60*1000);
    Jun 22, 2012 1:01 AM   in reply to kglad
    Thank You Doctor,
    You Truly Are Inspirational.
    A Vital Part of This Community.
    Thanks Again.
  • kglad
    Jul 21, 2002
    Jun 22, 2012 6:02 AM   in reply to KH000
    you're welcome.
