Soundbooth CS5 crashes on start, possible plugin incompatibility?
Sep 16, 2010 1:27 PM
When I start Soundbooth CS 5, in Mac OS X 10.6.4, it starts to boot and when it gets to loading Looks3_AE.plugin (which is the Magic Bullet Looks plugin for After Effects) I get the following error:
Soundbooth has encountered an error.
[/Roadrunner/main/MediaCore/MediaLayer/VideoFilterHost/Make/Mac/../../ Src/AEPluginVideoFilterModule.cpp-107]
I have already tried starting Soundbooth while holding the shift key in order to reset the preferences. Is there a way to get Soundbooth to ignore the After Effects plugins?
The OS X Problem Report follows:
Process: Adobe Soundbooth CS5 [3434]
Path: /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/MacOS/Adobe Soundbooth CS5
Identifier: com.adobe.Soundbooth
Version: 20100319.0305 (3.0)
Code Type: X86 (Native)
Parent Process: launchd [122]
Date/Time: 2010-09-16 16:25:16.016 -0400
OS Version: Mac OS X 10.6.4 (10F569)
Report Version: 6
Interval Since Last Report: 183040 sec
Crashes Since Last Report: 5
Per-App Interval Since Last Report: 614 sec
Per-App Crashes Since Last Report: 4
Anonymous UUID: 3886C837-D1C5-446B-B75D-FBC2761C0012
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x98ea1ef6 __kill + 10
1 libSystem.B.dylib 0x98ea1ee8 kill$UNIX2003 + 32
2 libSystem.B.dylib 0x98f3462d raise + 26
3 libSystem.B.dylib 0x98f4a6e4 abort + 93
4 libstdc++.6.dylib 0x943e4fda __gnu_cxx::__verbose_terminate_handler() + 433
5 libstdc++.6.dylib 0x943e317a __cxxabiv1::__terminate(void (*)()) + 10
6 libstdc++.6.dylib 0x943e31ba __cxxabiv1::__unexpected(void (*)()) + 0
7 libstdc++.6.dylib 0x943e32b8 __gxx_exception_cleanup(_Unwind_Reason_Code, _Unwind_Exception*) + 0
8 com.adobe.frontend.framework 0x071cbb0b fe::ErrorManager::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) const + 183
9 dvacore 0x0027e3a3 dvacore::config::ThrowError(dvacore::config::ErrorLevel, char const*, unsigned int, int, bool, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&, dvacore::config::ReplacementValue const&) + 89
10 ....Frameworks.VideoFilterHost 0x048ab317 ML::AEPluginVideoFilterModule::GetEntryPoint() + 935
11 ....Frameworks.VideoFilterHost 0x048c8632 ML::AEVideoFilterModule::CallModule(long, PF_InData*, PF_OutData*, PF_ParamDef**, PF_LayerDef*, void*, bool) + 58
12 ....Frameworks.VideoFilterHost 0x048c9ec2 ML::AEVideoFilterModule::GlobalSetup(bool) + 366
13 ....Frameworks.VideoFilterHost 0x048cafb5 ML::AEVideoFilterModule::SetupFilter() + 51
14 ....Frameworks.VideoFilterHost 0x048c76fc ML::AEVideoFilterFactory::CreateUnknownImpl(ASL::InterfaceRef<ML::IPl ugin, ML::IPlugin>, long, long&) + 758
15 ....Frameworks.VideoFilterHost 0x048c816f ML::AEVideoFilterFactory::CreateUnknown(ASL::InterfaceRef<ML::IPlugin , ML::IPlugin>, long, long&) + 81
16 ...re.Frameworks.PluginSupport 0x034edc48 ML::(anonymous namespace)::AddPlugin(ML::PluginEntry const&) + 1674
17 ...re.Frameworks.PluginSupport 0x034f1651 ML::(anonymous namespace)::LoadPluginList(ML::PluginNameList const&) + 829
18 ...re.Frameworks.PluginSupport 0x034f39bf ML::LoadPlugins(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 3121
19 ...re.Frameworks.PluginSupport 0x0350ba36 ML::PluginSupport::LoadAllPlugins(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 2300
20 ...dobe.AUDMezzanine.framework 0x05e3c12f audmz::Initializer::FullInitializer::FullInitializer(bool) + 119
21 ...dobe.AUDMezzanine.framework 0x05a4d8d7 audmz::Initializer::Initializer(bool) + 83
22 com.adobe.frontend.framework 0x071b427c fe::Application::InitApplication(exo::app::AppInitArgs&) + 1330
23 com.adobe.exo.framework 0x0132c5ea exo::app::AppBase::Initialize(exo::app::AppInitArgs&) + 712
24 com.adobe.frontend.framework 0x071ac75d fe::Application::Initialize(exo::app::AppInitArgs&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 2055
25 com.adobe.frontend.framework 0x071de03b AudMacMain(int, char**) + 577
26 com.adobe.Soundbooth 0x00004684 main + 202
27 com.adobe.Soundbooth 0x00003ece _start + 216
28 com.adobe.Soundbooth 0x00003df5 start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x98e67942 kevent + 10
1 libSystem.B.dylib 0x98e6805c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x98e67519 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x98e672be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x98e66d41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x98e66b86 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x98e6f066 __semwait_signal + 10
1 libSystem.B.dylib 0x98e6ed22 _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x98e709b8 pthread_cond_wait$UNIX2003 + 73
3 ...ple.CoreServices.CarbonCore 0x982c6a3a TSWaitOnCondition + 126
4 ...ple.CoreServices.CarbonCore 0x982b238d TSWaitOnConditionTimedRelative + 202
5 ...ple.CoreServices.CarbonCore 0x982add67 MPWaitOnQueue + 250
6 ...e.Frameworks.ASL.Foundation 0x005d26c6 ASL::(anonymous namespace)::TaskProc(void*) + 98
7 ...ple.CoreServices.CarbonCore 0x98291dee PrivateMPEntryPoint + 68
8 libSystem.B.dylib 0x98e6e81d _pthread_start + 345
9 libSystem.B.dylib 0x98e6e6a2 thread_start + 34
Thread 3:
0 libSystem.B.dylib 0x98e4120e mach_wait_until + 10
1 libSystem.B.dylib 0x98ec85a9 nanosleep + 345
2 ...obe.AUDFoundation.framework 0x009de7d1 ScObjects::Thread::sleep(unsigned int) + 143
3 ...obe.AUDFoundation.framework 0x009de831 ScObjects::Thread::wait(unsigned int) + 23
4 ...obe.AUDFoundation.framework 0x009cdf8e ScObjects::BridgeTalkThread::run() + 332
5 ...obe.AUDFoundation.framework 0x009dec57 ScObjects::Thread::go(void*) + 239
6 libSystem.B.dylib 0x98e6e81d _pthread_start + 345
7 libSystem.B.dylib 0x98e6e6a2 thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x98e41142 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x98e6ecbc _pthread_cond_wait + 1089
2 libSystem.B.dylib 0x98eb7203 pthread_cond_wait + 48
3 com.adobe.amt.services 0x0cfa3126 AMTConditionLock::LockWhenCondition(int) + 46
4 com.adobe.amt.services 0x0cf9bdb0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
5 com.adobe.amt.services 0x0cfa318c AMTThread::Worker(void*) + 24
Thread 5:
0 libSystem.B.dylib 0x98e4115a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x98e6eca5 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x98e9d848 pthread_cond_timedwait_relative_np + 47
3 ...ple.CoreServices.CarbonCore 0x982b23b5 TSWaitOnConditionTimedRelative + 242
4 ...ple.CoreServices.CarbonCore 0x982add67 MPWaitOnQueue + 250
5 dvacore 0x0035bf11 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, dvacore::threads::ThreadPriority, boost::shared_ptr<dvacore::threads::Gate> const&) + 217
6 dvacore 0x00355711 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, dvacore::threads::ThreadPriority, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list3<boost::_bi::value<boost::shared_ptr<dvacore::thread s::ThreadSafeDelayQueue> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 33
7 dvacore 0x00350448 boost::detail::function::void_function_obj_invoker0<boost::function<v oid ()(), std::allocator<void> >, void>::invoke(boost::detail::function::function_buffer&) + 36
8 dvacore 0x0035be36 dvacore::threads::(anonymous namespace)::ThreadGroup::LaunchThread(std::string const&, boost::function0<void, std::allocator<boost::function_base> > const&) + 26
9 dvacore 0x00359904 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(std::string const&, boost::function0<void, std::allocator<boost::function_base> > const&), boost::_bi::list2<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()(), std::allocator<void> > > > >, void>::invoke(boost::detail::function::function_buffer&) + 184
10 dvacore 0x0034d016 boost::function0<void, std::allocator<boost::function_base> >::operator()() const + 34
11 dvacore 0x002c709d thread_proxy + 99
12 libSystem.B.dylib 0x98e6e81d _pthread_start + 345
13 libSystem.B.dylib 0x98e6e6a2 thread_start + 34
Thread 6:
6 dvacore 0x0035bf11 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, dvacore::threads::ThreadPriority, boost::shared_ptr<dvacore::threads::Gate> const&) + 217
7 dvacore 0x00355711 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, dvacore::threads::ThreadPriority, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list3<boost::_bi::value<boost::shared_ptr<dvacore::thread s::ThreadSafeDelayQueue> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 33
8 dvacore 0x00350448 boost::detail::function::void_function_obj_invoker0<boost::function<v oid ()(), std::allocator<void> >, void>::invoke(boost::detail::function::function_buffer&) + 36
9 dvacore 0x0035be36 dvacore::threads::(anonymous namespace)::ThreadGroup::LaunchThread(std::string const&, boost::function0<void, std::allocator<boost::function_base> > const&) + 26
10 dvacore 0x00359904 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(std::string const&, boost::function0<void, std::allocator<boost::function_base> > const&), boost::_bi::list2<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()(), std::allocator<void> > > > >, void>::invoke(boost::detail::function::function_buffer&) + 184
11 dvacore 0x0034d016 boost::function0<void, std::allocator<boost::function_base> >::operator()() const + 34
12 dvacore 0x002c709d thread_proxy + 99
13 libSystem.B.dylib 0x98e6e81d _pthread_start + 345
14 libSystem.B.dylib 0x98e6e6a2 thread_start + 34
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
0 libSystem.B.dylib 0x98e410fa mach_msg_trap + 10
1 libSystem.B.dylib 0x98e41867 mach_msg + 68
2 com.apple.CoreFoundation 0x95b52faf __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x95b52094 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x95b57fd4 CFRunLoopRun + 84
5 com.apple.DVCPROHDMuxer 0x1eed598f AVS::DestroyAVCDeviceController(AVS::AVCDeviceController*) + 317
Thread 16:
4 com.apple.CoreFoundation 0x95b51ec1 CFRunLoopRunInMode + 97
5 com.apple.audio.CoreAudio 0x917dad7a HALRunLoop::OwnThread(void*) + 162
6 com.apple.audio.CoreAudio 0x917c68e2 CAPThread::Entry(CAPThread*) + 140
7 libSystem.B.dylib 0x98e6e81d _pthread_start + 345
8 libSystem.B.dylib 0x98e6e6a2 thread_start + 34
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
5 dvacore 0x003535d7 dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain() + 727
6 dvacore 0x002c9754 dvacore::threads::LaunchThread(std::string const&, boost::function0<void, std::allocator<boost::function_base> > const&) + 26
7 dvacore 0x00360de2 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_ t<void, void (*)(std::string const&, boost::function0<void, std::allocator<boost::function_base> > const&), boost::_bi::list2<boost::_bi::value<std::string>, boost::_bi::value<boost::function0<void, std::allocator<boost::function_base> > > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
8 dvacore 0x0034d016 boost::function0<void, std::allocator<boost::function_base> >::operator()() const + 34
9 dvacore 0x002c709d thread_proxy + 99
10 libSystem.B.dylib 0x98e6e81d _pthread_start + 345
11 libSystem.B.dylib 0x98e6e6a2 thread_start + 34
Thread 22:
6 AdobeACE 0x0506c421 0x503b000 + 201761
7 AdobeACE 0x0506be19 0x503b000 + 200217
8 ...ple.CoreServices.CarbonCore 0x98291dee PrivateMPEntryPoint + 68
9 libSystem.B.dylib 0x98e6e81d _pthread_start + 345
10 libSystem.B.dylib 0x98e6e6a2 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x98f4a693 ecx: 0xbfffe4bc edx: 0x98ea1ef6
edi: 0xa0b73b30 esi: 0x943e7f73 ebp: 0xbfffe4d8 esp: 0xbfffe4bc
ss: 0x0000001f efl: 0x00000286 eip: 0x98ea1ef6 cs: 0x00000007
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00008010
Binary Images:
0x1000 - 0x8ffe +com.adobe.Soundbooth 20100319.0305 (3.0) <75B23274-8A2C-48D0-95E0-06FC462A802E> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/MacOS/Adobe Soundbooth CS5
0x18000 - 0x1cffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
0x23000 - 0x10bccb +iZBase ??? (???) <773F066F-8FBE-4947-BA51-D3A1BC62D2E1> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/iZBase.framework/Versions/A/iZBase
0x188000 - 0x1ece48 +iZDSPBase ??? (???) <C1575F2E-CE46-43AD-8F48-D15B7097F082> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/iZDSPBase.framework/Versions/A/iZDSPBase
0x205000 - 0x243bf6 +iZotope_Radius ??? (???) <0FAB94C5-143F-4F64-ACDF-FECB40637544> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/iZotope_Radius.framework/Versions/A/iZoto pe_Radius
0x25e000 - 0x3ebff8 +dvacore ??? (???) <EF5A7092-5A76-4E23-9AB1-53C8CF432EFB> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x59c000 - 0x59dfff +PRM ??? (???) <CF26642A-79C6-48DA-9052-C8E8E95B092A> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
0x5a2000 - 0x60900f +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <A7082C2C-4613-4D40-909E-60AB84E30038> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFou ndation
0x6d8000 - 0x6ebfef +ASLMessaging ??? (???) <DB1CECD0-F947-419F-AF1F-B6CE874333B8> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMess aging
0x70a000 - 0x71afff +ASLUnitTesting ??? (???) <E2BFD276-3047-497D-97B2-3EF14C761DCA> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUn itTesting
0x73a000 - 0x808fef +AdobeExtendScript 3.7.0 (compatibility 3.7.0) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
0x87f000 - 0x921fd7 +AdobeScCore 3.7.0 (compatibility 3.7.0) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
0x97d000 - 0xa27fc7 +com.adobe.AUDFoundation.framework 1.0 (1.0) <CA7EDC8F-3FD3-44D2-9036-EB8F161F3E85> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AppFoundation.framework/Versions/A/AppFou ndation
0xaba000 - 0xd13fc7 +dvaui ??? (???) <A511070A-9935-4593-8542-21566755968F> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0xfdb000 - 0x10bffef +com.adobe.dvaeve.framework dvaeve version 1.0 (1.0) <D21C3272-BCE8-472B-B06E-A7E76478E627> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x119d000 - 0x124afff +dvaworkspace ??? (???) <AAE84BD5-F58D-4F1B-858A-6A617155F8A3> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvawork space
0x1329000 - 0x13ccfff +com.adobe.exo.framework 1.0 (1.0) <572E740D-3B4B-4B0A-A4E0-D4C3DF284949> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x14d1000 - 0x14d2fff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <17D12291-A216-481A-B81C-D02FFCA92187> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
0x14d9000 - 0x14dcfff +com.adobe.processcoordinationsupport.framework 1.0 (1.0) <98BE2ECE-0764-4538-B656-5306AA60787B> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/processcoordinationsupport.framework/Vers ions/A/processcoordinationsupport
0x14e3000 - 0x1505ffc +com.adobe.processcoordinationclient.framework 1.0 (1.0) <40BE56AD-D8C9-47AE-9468-AE3D85C58DEE> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/processcoordinationclient.framework/Versi ons/A/processcoordinationclient
0x153b000 - 0x1560fe7 +com.adobe.MediaFoundation ??? (1.0) <4E24FD7C-C2BB-4502-916C-C335A3F06906> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/Medi aFoundation
0x1591000 - 0x1601ff7 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <A46D745E-5928-48F4-9915-DF8768BF8C78> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioR enderer
0x16a7000 - 0x2354fcf +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <613610D6-C5C3-40E4-903A-A31782BEF348> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
0x3130000 - 0x32f0fdf +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <B0AE214C-E207-4123-83C8-0EADD9CBBE21> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageR enderer
0x33f4000 - 0x3422ffb +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <A68C23AF-AB16-45F3-9EDD-F27AD24D91AE> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFound ation
0x346d000 - 0x34acff7 +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <A0789244-B10C-47BB-A92E-3DB897DF81B3> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFram e
0x34e7000 - 0x351cfff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <74BDC924-C87D-442B-9387-9B2FCC13F535> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/Plugin Support
0x3557000 - 0x357bfff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <B91EE1C5-2B9D-47BA-B044-0964AA347832> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/Swee tPeaSupport
0x35ff000 - 0x364600f +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <23F80D3A-5355-4558-B9AE-9EC4FFA6C4F3> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSu pport
0x368d000 - 0x3691fff +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <44E2410E-EA37-423C-B702-0BA830A4D148> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtil s
0x3698000 - 0x36b4ffb +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <E8C7513A-EC02-4829-A8D8-9D1AF48EB55A> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/Audi oFilterHost
0x36e1000 - 0x3741fc7 +AdobeXMP ??? (???) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x3750000 - 0x37d2fd7 +AdobeXMPFiles ??? (???) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeX MPFiles
0x37e9000 - 0x37eafff +com.adobe.MediaCore.QTMutex 1.0 (1.0) <D0E463CD-C36F-4072-B054-29598887937A> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/QTMutex.framework/Versions/A/QTMutex
0x37ee000 - 0x3929fef +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <A04332F0-ABD6-4655-A1A4-E9F2FC6FA39C> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/Importe rHost
0x3a6c000 - 0x3b28fff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <9F9AB66C-CEBA-4C26-8517-7E8B84DE3515> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoR enderer
0x3c27000 - 0x3f75fd7 +AMEWrapper ??? (???) <B220703E-B448-4F2D-B380-AE19146A7D6A> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrappe r
0x426d000 - 0x429afef com.apple.carbonframeworktemplate 1.0 (1.0) <BE39F487-1949-4F3C-8875-5DCB2FA7F156> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefou ndation
0x42ca000 - 0x42f4fff +ameproperties ??? (???) <F801B9AE-ECA8-4917-AD9B-C4809723EB20> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/amepro perties
0x4329000 - 0x4343fff +AdobeBIB ??? (???) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x434e000 - 0x4423fdd +FileInfo ??? (???) <72E78CD5-408E-477E-AA47-2571017DC2F9> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
0x4454000 - 0x4478ff6 +AdobeAXE8SharedExpat ??? (???) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
0x448b000 - 0x4685fcf +AdobeOwl ??? (???) <F209A9B2-9606-4182-93D8-84B349CFBE48> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x4700000 - 0x47adff7 +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <2A8DA2A6-B011-4D18-A113-0E6C507AEDA8> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/Exporte rHost
0x48a8000 - 0x4968fff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <1726777A-9732-437D-8737-20D2679409DD> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/Vide oFilterHost
0x4a32000 - 0x4a91ff7 +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <D9F34D6F-5CEE-4007-BE0D-F9BEC5493F3D> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHos t
0x4b0e000 - 0x4b7bfff +com.adobe.MediaCore.Frameworks.RecorderHost 1.0 (1.0) <F0F7B162-1B01-4EC8-89FF-E8BD820482F6> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/RecorderHost.framework/Versions/A/Recorde rHost
0x4c05000 - 0x4c8dfff +dynamiclink ??? (???) <C7619634-BBEC-449F-981C-3CF0C17AFED7> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamicl ink
0x4d27000 - 0x4d50ff7 +com.adobe.MediaCore.Frameworks.DynamicLinkClient 1.0 (1.0) <77989AC3-2D54-402F-9DFA-EBED4F6B1C84> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/DynamicLinkClient.framework/Versions/A/Dy namicLinkClient
0x4d8f000 - 0x4d9bfff +com.adobe.MediaCore.Frameworks.ProjectConverterHost 1.0 (1.0) <93189AD0-8868-4D1A-B7DB-2EBDA170543C> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A /ProjectConverterHost
0x4daf000 - 0x4de3ff7 +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <2854E671-FF90-4F42-99D7-D2F31FBFE9FD> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFi lters
0x4e4b000 - 0x4e93fc7 +dvametadata ??? (???) <C522C9D5-BC88-4140-9DFE-37F842E6549F> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametad ata
0x4f05000 - 0x4f46feb +com.adobe.dvatemporalxmp.framework 1.0 (1.0) <4F71893B-6E9D-444D-9DC6-F7B4BC8B79A7> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvate mporalxmp
0x4f62000 - 0x4f68ff7 +com.adobe.MediaCore.Frameworks.AudioTimeScalerIZotope ??? (1.0) <8A15C79B-F45F-4268-9838-128003C7CB34> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AudioTimeScalerIZotope.framework/Versions /A/AudioTimeScalerIZotope
0x4f73000 - 0x4fc1ffc +com.adobe.MediaCore.Frameworks.BravoInitializer 1.0 (1.0) <B9A5EB96-19CA-45A5-9979-237CB5575FFB> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/Bra voInitializer
0x503b000 - 0x514905f +AdobeACE ??? (???) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x5167000 - 0x546dfd7 +AdobeAGM ??? (???) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x5532000 - 0x57cdfef +AdobeCoolType ??? (???) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
0x5858000 - 0x592dff7 +com.adobe.AutoComposer 1.0 (1.0) <8B7CC08D-C8CD-4023-9E59-2E4A7CB9BB6E> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AutoComposer.framework/Versions/A/AutoCom poser
0x5a1e000 - 0x6058fc3 +com.adobe.AUDMezzanine.framework 1.0 (1.0) <AB46BD11-A034-45A7-AA81-20F5961D4020> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AUDMezzanine.framework/Versions/A/AUDMezz anine
0x661c000 - 0x66b7fef +com.uitoolkit.framework ??? (1.0) <30E1A97F-9564-41AB-85B4-F364323774ED> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/uitoolkit.framework/Versions/A/uitoolkit
0x675c000 - 0x67aafef +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <B47EDA19-5177-4634-B1C9-48F992176E02> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCor eUI
0x67e6000 - 0x6866fe7 +dvametadataUI ??? (???) <45A512C5-51AF-45E6-A843-B97DFB37BE70> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvamet adataUI
0x68f5000 - 0x68f7fff +dvaflashview ??? (???) <AC37820C-6CD5-4DB2-BA34-FBAFCF732370> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflas hview
0x68ff000 - 0x6913fef +com.adobe.AMEAppFoundation.framework ??? (1.0) <F6467927-510D-4B0F-9660-EA835A4E7B73> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AME AppFoundation
0x6928000 - 0x694bffd +com.adobe.PostEncodeHost.framework ??? (1.0) <83959E83-9B1D-4499-8414-3AA978E07D59> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostE ncodeHost
0x696c000 - 0x6c50ffb +com.adobe.EncoderHost.framework ??? (1.0) <CAA83654-B212-4C7F-B373-0F5F0DF0F4BD> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderH ost
0x6ebd000 - 0x7050ff7 +com.adobe.SettingsUI.framework ??? (1.0) <60106E0F-9113-45AE-8A34-6EBDFB291295> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsU I
0x71a3000 - 0x7516ff7 +com.adobe.frontend.framework 1.0 (1.0) <E52892FC-2761-4A00-A577-7D99B6002EFD> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/FrontEnd.framework/Versions/A/FrontEnd
0x78fc000 - 0x7962ffb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <DD471011-9120-1BC2-F1B5-D6FF09D0859F> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x7992000 - 0x79d2ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutil s
0x79eb000 - 0x79ebff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
0x79ee000 - 0x7aa3fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
0x7f08000 - 0x7f0cfff +com.adobe.MediaCore.ImporterAiff 1.0 (1.0) <C898F0CB-C547-4180-A548-2C6AF6747D40> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ImporterAiff.bundle/Contents/MacOS/I mporterAiff
0x7f13000 - 0x7f17ff7 com.apple.iokit.IOQTComponents 1.6 (1.6) <D7338C6A-AC06-536F-FFB5-A79C033B8C89> /System/Library/Components/IOQTComponents.component/Contents/MacOS/IO QTComponents
0x7f1c000 - 0x7f1dfff com.apple.DVCPROHDVideoOutputCodec 1.3.2 (1.3.2) <90A0E4C7-B028-3A36-347A-42FFD411C97C> /Library/QuickTime/DVCPROHDVideoOutputCodec.component/Contents/MacOS/ DVCPROHDVideoOutputCodec
0x7fdf000 - 0x7fe7fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
0xcf00000 - 0xcf70feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
0xcf7e000 - 0xcfe5fea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <EE468E2C-A6BD-E2EE-7ABE-69168B143B44> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservi ces
0xd024000 - 0xd349fe7 +com.adobe.WaveformEditor.bundle 1.0 (1.0) <3E0DE2D6-8034-4D67-9D7A-6E2D5555ED11> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Modules/WaveformEditor.bundle/Contents/MacOS/Wavefor mEditor
0xd6bb000 - 0xd830ff9 +com.adobe.AutoComposerFE.bundle 1.0 (1.0) <BCC6580E-F849-4C05-803C-B8874C37A68C> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Modules/AutoComposerFE.bundle/Contents/MacOS/AutoCom poserFE
0xd9b3000 - 0xd9e0fff +com.adobe.DynamicLinkFE.bundle 1.0 (1.0) <1553FFD2-ECBE-476D-96E8-4BEA5B6A0325> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Modules/DynamicLinkFE.bundle/Contents/MacOS/DynamicL inkFE
0xda23000 - 0xda3ffff +com.adobe.dynamiclinkui.framework 1.0 (1.0) <8AFA2516-E7C5-4453-B327-8D00685642DB> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynami clinkui
0xda63000 - 0xdc22ff7 +com.adobe.Multitrack.bundle 1.0 (1.0) <FF082834-89DE-451E-AEAB-9D90B3E52D51> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Modules/Multitrack.bundle/Contents/MacOS/Multitrack
0xde3e000 - 0xdf19fff +com.adobe.MultitrackMZ.bundle 1.0 (1.0) <3E4AC428-6551-4FEE-BBEE-5729CF29CFF2> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/MultitrackMZ.framework/Versions/A/Multitr ackMZ
0x1e73a000 - 0x1e73bff7 com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1ea24000 - 0x1eb979d8 +com.mainconcept.mcdvd_32 4.2.12198.0 (4.2.12198.0) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcdvd_32.framework/mcdvd_32
0x1ebf0000 - 0x1ebf4ff3 com.apple.audio.AudioIPCPlugIn 1.1.2 (1.1.2) <5570694E-039D-7970-6083-1C8A7B7C937B> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x1ebf9000 - 0x1ebffffb com.apple.audio.AppleHDAHALPlugIn 1.8.7 (1.8.7f1) <0FE8B697-6D19-69C6-FA94-E18064ACFAEC> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1ec04000 - 0x1ec59fe2 com.apple.DVCPROHDAudio 1.3.2 (1.3.2) <2E0A9883-4EA5-706F-78F6-4C1F105A4D30> /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPR OHDAudio
0x1ecaa000 - 0x1ecbafff com.apple.carbonframeworktemplate 1.0 (1.0) <951EE9FB-8895-4D51-BE5D-C54661677AFB> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/AMR.framework/AMR
0x1ecc8000 - 0x1eccaff7 com.apple.PDFImporter 2.1 (???) <C78368B0-3712-067C-9467-55932890C979> /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFIm porter
0x1ed01000 - 0x1ed03ff3 com.apple.LiveType.component 2.1.4 (2.1.4) <D60E2537-3B47-EA99-0077-6CE394378D07> /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x1ed09000 - 0x1ed6dfe2 com.apple.LiveType.framework 2.1.4 (2.1.4) <7AABA687-4323-E5B9-BA04-8F61C217E6FD> /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/Live Type
0x1ed8d000 - 0x1edd3ffb com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x1edd9000 - 0x1eddbff7 Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x1ede1000 - 0x1ee7eff8 com.apple.procore.framework 4.0.2 (757) <D3146F1E-F86D-F2A2-509B-E3F9640CBE40> /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCo re
0x1eebe000 - 0x1ef23fe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) <483DD62C-46C4-36AA-6A1C-2DEA6F062863> /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMux er
0x1ef3d000 - 0x1f17aff7 com.apple.carbonframeworktemplate 1.0 (1.0) <12C363CB-D3A4-47F0-B622-19A049EE2F61> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/VXMLPresetReader.framework/vxmlpresetread er
0x1f377000 - 0x1f3e1003 com.apple.carbonframeworktemplate 1.0 (1.0) <AE6E42A2-D359-46C2-B6BA-D8E0068A2A4C> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/aacaudio.framework/aacaudio
0x1f403000 - 0x1f43ffef +com.mainconcept.mcamrenc 7.3 (7.3.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcamrenc.framework/Versions/7.3/mcamrenc
0x1f445000 - 0x1f46cff4 com.apple.carbonframeworktemplate 1.0 (1.0) <EA8F441C-3413-4E47-894A-2570061320DC> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/FLVVCodec.framework/FLVVCodec
0x1f484000 - 0x1f493ff7 com.apple.carbonframeworktemplate 1.0 (1.0) <B4EFD61C-DF84-4634-BF25-A47A39646CC5> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/H264VideoCodecH264.framework/H264VideoCodecH26 4
0x1f49c000 - 0x1f4adfff com.apple.carbonframeworktemplate 1.0 (1.0) <3F20C8C7-6A7B-4665-BFD6-191EF2D63D39> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/H264VideoCodecH264Bluray.framework/H264VideoCo decH264Bluray
0x1f4b7000 - 0x1f4d9ff3 com.apple.carbonframeworktemplate 1.0 (1.0) <0A409AB9-D525-470C-820F-26B4D9FE60CC> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/MCMHH264VideoCodec.framework/MCMHH264VideoCode c
0x1f600000 - 0x1f7e6ffe +com.mainconcept.mch264vout.001 7.4 (7.4.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mch264vout.001.framework/mch264vout.001
0x1f809000 - 0x1f82cffb com.apple.carbonframeworktemplate 1.0 (1.0) <C5978D3F-C56E-473E-87AD-218771A102C3> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/MCMHMPEGVideoCodec.framework/MCMHMPEGVideoCode c
0x1f847000 - 0x1f9ecfef +com.mainconcept.mcmpgvout.004 7.7 (7.7.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcmpgvout.004.framework/mcmpgvout.004
0x1fa22000 - 0x1fa41ff7 com.apple.carbonframeworktemplate 1.0 (1.0) <C3E48820-FF25-4863-BEDB-B297ABA16A18> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/MPEGVideoCodecMPEG2.framework/MPEGVideoCodecMP EG2
0x1fa4e000 - 0x1fa5bfe7 com.apple.carbonframeworktemplate 1.0 (1.0) <9073C708-E309-47AC-89E7-144C72178AE5> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/MPEGVideoCodecMPEG2DVD.framework/MPEGVideoCode cMPEG2DVD
0x1fa63000 - 0x1fa74ff7 com.apple.carbonframeworktemplate 1.0 (1.0) <3C1379C4-39D3-4C51-8843-A4EAA4D0CEBB> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/MPEGVideoCodecMPEG2BD.framework/MPEGVideoCodec MPEG2BD
0x1fa7d000 - 0x1fa9d02f com.apple.carbonframeworktemplate 1.0 (1.0) <1C51A281-5CE1-434C-9530-A3ED0EFF6CD0> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/MCMPEG4VideoCodec.framework/MCMPEG4VideoCodec
0x1fab7000 - 0x1fc1efeb +com.mainconcept.mcmpeg4vout 7.32 (7.32.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcmpeg4vout.framework/mcmpeg4vout
0x1fc4f000 - 0x1fc5cff7 com.apple.carbonframeworktemplate 1.0 (1.0) <EC16A9D1-BB59-4E45-89F9-DA70F49C62B1> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/MPEG4VideoCodecMPEG4.framework/MPEG4VideoCodec MPEG4
0x1fc65000 - 0x1fc80fe4 com.apple.carbonframeworktemplate 1.0 (1.0) <0D96C787-34A2-464C-8036-42693A74AC11> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/MCmpgACodec.framework/mcmpgacodec
0x1fc92000 - 0x1fca2fff com.apple.carbonframeworktemplate 1.0 (1.0) <F3AA18A2-39E6-4AC3-9F42-3E850FB7F39F> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/codecs/PCMAudio.framework/pcmaudio
0x1fcb0000 - 0x1fcc6ff7 com.apple.carbonframeworktemplate 1.0 (1.0) <0C6EDD94-3510-4A43-8DC3-D4724546B5FC> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/writers/AudioWriter.framework/audiowriter
0x1fce1000 - 0x2000dfe8 com.apple.carbonframeworktemplate 1.0 (1.0) <6D47B33D-B560-4C63-BE6D-9D5C8663617C> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/writers/FLVNativeWriter.framework/FLVNativeWriter
0x203db000 - 0x20498fe2 com.apple.DesktopVideoOut 1.2.7 (1.2.7) <7959538F-2A96-F2BB-EEC3-0718A326C152> /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVi deoOut
0x204b7000 - 0x204c3fff com.apple.FinalCutPro.iChatTheaterPreview 1.0 (195) <C8965C94-63DD-F9B0-BA40-E79194ED6391> /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChat TheaterPreview
0x204d0000 - 0x20537ffa com.apple.carbonframeworktemplate 1.0 (1.0) <4A997D90-1478-4786-8BAB-BF92C2A19572> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/writers/MCMHH264Writer.framework/MCMHH264Writer
0x20566000 - 0x20616ff6 +com.mainconcept.mcmp4mux 7.4 (7.4.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcmp4mux.framework/mcmp4mux
0x2063b000 - 0x2068eff6 com.apple.carbonframeworktemplate 1.0 (1.0) <918E0887-E72D-4DFB-8194-B96ACEA43E3C> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/writers/MCMHMPEG4Writer.framework/MCMHMPEG4Writer
0x206b9000 - 0x20720ffa com.apple.carbonframeworktemplate 1.0 (1.0) <59208BC6-8CED-4A6E-8D22-8EABBDE4A262> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/MediaIO/writers/MCMHMPEGWriter.framework/MCMHMPEGWriter
0x2074e000 - 0x20753fff +com.adobe.MediaCore.ExporterAIFF 1.0 (1.0) <7CD8271E-BC0F-4F5E-AFF4-D8BB67EA86CD> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ExporterAIFF.bundle/Contents/MacOS/E xporterAIFF
0x2075b000 - 0x20760feb +com.adobe.MediaCore.ExporterCoreAudio 1.0 (1.0) <5C2B1385-D4F0-4310-8914-A47F375749F3> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ExporterCoreAudio.bundle/Contents/Ma cOS/ExporterCoreAudio
0x20768000 - 0x20777fe3 +com.adobe.MediaCore.Frameworks.AudioConverter 1.0 (1.0) <7D1B540C-5960-48F9-B372-BDFDBEBFA2D2> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/Audio Converter
0x2078b000 - 0x209abfeb com.apple.audio.codecs.Components 2.0.1 (2.0.1) <3B1071C3-1AB4-0F6A-2CFC-7A258A0C2C46> /System/Library/Components/AudioCodecs.component/Contents/MacOS/Audio Codecs
0x209fa000 - 0x20a49fff +com.adobe.MediaCore.ExporterMP3 1.0 (1.0) <7F093585-EB89-4576-B132-74A42B7C712B> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ExporterMP3.bundle/Contents/MacOS/Ex porterMP3
0x20a83000 - 0x20aaefd3 +com.adobe.MediaCore.ExporterQuickTime 1.0 (1.0) <F0B04DC1-1EC6-4B2A-845C-5601ECF426F7> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ExporterQuickTime.bundle/Contents/Ma cOS/ExporterQuickTime
0x20ad8000 - 0x20ae9fe7 com.apple.FCP Uncompressed 422.component 1.6.1 (1.6.1) <62C290FB-2735-60C4-CE88-7ECB0DE6EDB3> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x20af0000 - 0x20b5dfe7 com.apple.AppleProResCodec 2.0 (224) <B7A79FF2-9C32-5554-A3C3-BE91F9B89419> /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/ApplePro ResCodec
0x20baa000 - 0x20f90fe3 QuickTimeH264.scalar ??? (???) <1FEDD99E-F12F-281F-F5D4-57AD431C6973> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/ QuickTimeH264.scalar
0x20fec000 - 0x21023fe7 com.apple.DVCPROHDCodec 1.5 (237) <5BA42205-5AEE-73BB-A7DE-5417EF028D5B> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCod ec
0x21033000 - 0x210e2fe3 com.apple.AppleHDVCodec 1.6 (229) <C45D37E1-3CE0-1FBE-17DE-91D5B65FD940> /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCod ec
0x2110a000 - 0x21124ffb com.apple.AppleIntermediateCodec 1.3.1 (152) <D9F7038D-87B0-9F80-3AC2-3C7624D464AE> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/Ap pleIntermediateCodec
0x2112a000 - 0x2113dfe3 com.apple.IMXCodec 1.4 (155) <B7A1514F-1A2B-EC3E-719D-B8BB25016A05> /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x2114f000 - 0x21168fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/A pplePixletVideo
0x22401000 - 0x22442fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) <AD66647C-03A9-EBAF-6FFC-E5A631F4D6BE> /System/Library/Components/SoundManagerComponents.component/Contents/ MacOS/SoundManagerComponents
0x2358d000 - 0x23594fef +com.adobe.MediaCore.ImporterWave 1.0 (1.0) <865436F4-BECB-4EA5-9693-FD34130A56F7> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ImporterWave.bundle/Contents/MacOS/I mporterWave
0x23811000 - 0x238acffb +com.adobe.MediaCore.ExporterSpeech 1.0 (1.0) <7FFEF8AE-C2AB-45C6-BD42-B299EC75074E> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ExporterSpeech.bundle/Contents/MacOS /ExporterSpeech
0x238e2000 - 0x23900fe7 +com.adobe.MediaCore.ImporterFastMPEG 1.0 (1.0) <9EA918EF-3F32-4D95-B6F4-40D9AFFE1EC4> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ImporterFastMPEG.bundle/Contents/Mac OS/ImporterFastMPEG
0x2391f000 - 0x239dbfef +com.adobe.MediaCore.IPPMPEGDecoder 1.0 (1.0) <2B2F76AE-E1AF-4363-9107-601475E7B62B> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMP EGDecoder
0x23a1d000 - 0x23a84fdb +com.adobe.MediaCore.ImporterFLV 1.0 (1.0) <13E0F6B2-FEC6-4A9C-9F5F-FD143C0215B7> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ImporterFLV.bundle/Contents/MacOS/Im porterFLV
0x23d15000 - 0x23d4cff7 +com.adobe.MediaCore.ImporterMp3 1.0 (1.0) <9A3031F7-6C10-4A1F-AE6F-7744A3CB3EED> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ImporterMp3.bundle/Contents/MacOS/Im porterMp3
0x23d75000 - 0x23d7f02f +com.adobe.MediaCore.ImporterMPEG 1.0 (1.0) <906EC396-1310-46B2-A035-71916E6E03B6> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ImporterMPEG.bundle/Contents/MacOS/I mporterMPEG
0x23d8b000 - 0x23dbcfe7 +com.adobe.MediaCore.ImporterQT 1.0 (1.0) <DEEACE8A-B906-45E4-AD50-C28E555391F9> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/ImporterQT.bundle/Contents/MacOS/Imp orterQT
0x23de9000 - 0x2407effb +org.perian.Perian 1.2.1 (1.2.1) <7FBFA9CD-68D1-DFB5-6296-A11B06B62B37> /Users/daniel/Library/QuickTime/Perian.component/Contents/MacOS/Peria n
0x244c9000 - 0x246bbfe2 +net.telestream.wmv.import 2.3.4.1 (2.3.4.1) <6F008770-6AD3-E6C9-347C-A235876196E0> /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
0x246f0000 - 0x246fdff3 +net.telestream.license 1.0.7.2 (1.0.7.2) <1566955C-9806-2F1B-CEB2-7C86249A6917> /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
0x24762000 - 0x24923ff2 +net.telestream.wmv.advanced 2.3.4.1 (2.3.4.1) <CB95FDB7-C531-22A3-6D36-1C96D5A5679D> /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
0x24967000 - 0x2498bff7 com.apple.AppleAVCIntraCodec 1.0 (16) <8A1A4CEE-1610-EECE-74DA-D2AF42825E6D> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleA VCIntraCodec
0x24996000 - 0x24a0ffe7 com.apple.AppleVAH264HW.component 2.0 (1.0) <4FD6FDD7-8791-CEA2-9E5A-1628492A98B2> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/Appl eVAH264HW
0x24ad2000 - 0x24b74ff3 com.apple.QuickTimeVR.component 7.6.6 (1742) <8A866FA4-0E94-C014-DDB1-895936E87F0E> /System/Library/QuickTime/QuickTimeVR.component/Contents/MacOS/QuickT imeVR
0x24b9b000 - 0x24bd7fe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1742) <1FFC5B3D-78E8-4902-7886-7EC84B574481> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacO S/QuickTimeFireWireDV
0x24be3000 - 0x24c33fff +com.adobe.MediaCore.PlayerMediaCore 1.0 (1.0) <6B10A560-43F5-476D-92D3-DBED7B8921BD> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Plug-ins/Common/PlayerMediaCore.bundle/Contents/MacO S/PlayerMediaCore
0x24c84000 - 0x24cb9feb com.apple.AVCVideoServices 1.0 (42) <CF858CF3-E3B3-4DC0-A52E-A8F0F8EF7A52> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVC VideoServices
0x24cef000 - 0x24d71fe7 +com.adobe.MediaCore.Frameworks.Display ??? (1.0) <A4654285-F62E-4226-905B-24CC3BF6B31B> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/Display.framework/Versions/A/Display
0x24e3d000 - 0x24e97fcf +aif_core ??? (???) <81330C6C-46A5-4E20-854F-1D9A982D7F97> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
0x24ecf000 - 0x250afffe +aif_ogl ??? (???) <443E516B-D9EB-413B-87E3-5E5D8EFA9056> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
0x25250000 - 0x2525ffff +image_runtime ??? (???) <07455D8A-847A-4764-99A6-515FC48E82A8> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_ runtime
0x2527e000 - 0x25327fef +image_flow ??? (???) <781342FA-407C-4EDC-AF68-91102F56A813> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flo w
0x253e9000 - 0x25404ffd +data_flow ??? (???) <D204E4D6-BE62-449B-ADA6-9A630F40E50C> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
0x25435000 - 0x25458fcf +com.adobe.MediaCore.AudioVideoIO 1.0 (1.0) <C0E94D8E-F218-4D20-B8CB-01383259714A> /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/AudioVi deoIO
0x2548b000 - 0x25602fe7 GLEngine ??? (???) <0FC1F7CA-5C84-A7F6-105B-169383B50A94> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
0x25634000 - 0x25a39fe7 libclh.dylib 3.1.1 C (3.1.1) <4A445142-1AD3-2F3C-FF95-E835B49B33DE> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libc lh.dylib
0x25ab1000 - 0x25ad4fe7 GLRendererFloat ??? (???) <D71788AA-645A-02CF-201F-E44F073F98D7> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
0x3e000000 - 0x3e046ff7 com.apple.glut 3.4.4 (GLUT-3.4.4) <DF15FD36-E1F5-D745-1BF6-DD3AEA2897E4> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x70000000 - 0x700caffb com.apple.audio.units.Components 1.6.1 (1.6.1) <AEC44B68-A209-4093-36B0-7B740361249B> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAud io
0x8f050000 - 0x8f711fef com.apple.GeForceGLDriver 1.6.18 (6.1.8) <2E4BD283-8E9B-6AB7-2945-F92F5015DA02> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeFo rceGLDriver
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
0x90003000 - 0x904bcffb com.apple.VideoToolbox 0.484.11 (484.11) <6AB58081-F7C4-46F9-2C05-CFED9E38F0A0> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
0x9057b000 - 0x905bffe7 com.apple.Metadata 10.6.3 (507.10) <630494FA-3BB3-EDD3-E10B-8DAAF4831E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
0x90604000 - 0x9065fff7 com.apple.framework.IOKit 2.0 (???) <A013B850-6ECB-594A-CBD6-DB156B11871B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9070e000 - 0x9097effb com.apple.Foundation 6.6.3 (751.29) <E77D3906-99F4-FEF4-FBB0-86FB3C94073E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x90cdd000 - 0x90ce8ff7 libGL.dylib ??? (???) <B87E0676-F5EF-8DA3-6DEE-13C43B3832A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
0x90ce9000 - 0x90d0dff7 libJPEG.dylib ??? (???) <5CE96981-6B2A-D15B-4A17-E7BD329095B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x90d27000 - 0x90d34ff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x90d35000 - 0x90d65ff7 com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKi t
0x90dbd000 - 0x90e13ff7 com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
0x90e14000 - 0x90e1bff7 com.apple.iChat.IMUtils 5.0.4 (746) <B2060317-610E-0D77-C602-D331FC0F4D82> /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framew ork/Versions/A/IMUtils
0x90e1c000 - 0x90e93ff3 com.apple.backup.framework 1.2.2 (1.2.2) <FE4C6311-EA63-15F4-2CF7-04CF7734F434> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x90e94000 - 0x90e98ff7 libGIF.dylib ??? (???) <3ECD4D2C-40FE-E9A0-A2D2-E36D1C00D3A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x90ef2000 - 0x91074fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <2314BD12-0821-75BB-F3BC-98D324CFD30A> /usr/lib/libicucore.A.dylib
0x91075000 - 0x910f7ffb SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
0x910f8000 - 0x91193ff7 com.apple.ApplicationServices.ATS 275.11.1 (???) <5FF65EC7-F512-530A-7771-3DE240EE6E43> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
0x91194000 - 0x91272fef com.apple.QuickTimeMPEG4.component 7.6.6 (1742) <DB28919F-EE94-BA3C-3287-E5530BA1C07F> /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/Qui ckTimeMPEG4
0x91273000 - 0x91283ff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A /DSObjCWrappers
0x91286000 - 0x912c6ff3 com.apple.securityinterface 4.0.1 (37214) <BBC88C96-8827-91DC-0CF6-7CB639183395> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
0x912c7000 - 0x916ddff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
0x916de000 - 0x9177bfe3 com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
0x9177c000 - 0x9179dfe7 com.apple.opencl 12.1 (12.1) <DA2AC3FA-ED11-2D10-21E9-7BDF4778B228> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x9179e000 - 0x917a5ff3 com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
0x917a6000 - 0x91821fe7 com.apple.audio.CoreAudio 3.2.2 (3.2.2) <51D0E2DC-B15F-AF6C-70D8-026DDAD4E2A5> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x92483000 - 0x924abff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x924ac000 - 0x924aeff7 com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
0x924af000 - 0x927d3fef com.apple.HIToolbox 1.6.3 (???) <0A5F56E2-9AF3-728D-70AE-429522AEAD8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
0x927d4000 - 0x927e1fe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) <6008C8AC-8DB1-B38B-52A9-9133533B0DA2> /usr/lib/libbz2.1.0.dylib
0x927e2000 - 0x92fd1557 com.apple.CoreGraphics 1.545.0 (???) <DCED8E1A-7504-C31A-B6EF-98BFF1A61060> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x932c9000 - 0x932d2ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
0x932d3000 - 0x932d3ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x93310000 - 0x93348ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <76C02F5C-98FD-BD64-B5FB-C698FB76EA25> /usr/lib/libcups.2.dylib
0x93349000 - 0x93365fe3 com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
0x93366000 - 0x933fefe7 edu.mit.Kerberos 6.5.10 (6.5.10) <8B83AFF3-C074-E47C-4BD0-4546EED0D1BC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x93448000 - 0x94398fe3 com.apple.QuickTimeComponents.component 7.6.6 (1742) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
0x94399000 - 0x94403fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x9442f000 - 0x944e8fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x944e9000 - 0x944faff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x944fb000 - 0x94531fff libtidy.A.dylib ??? (???) <DDFAB560-3883-A6A2-7BDD-D91730982B48> /usr/lib/libtidy.A.dylib
0x94532000 - 0x9489aff7 com.apple.QuartzCore 1.6.2 (227.22) <4288F0D2-0C87-F054-C372-8764B44DE024> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9489b000 - 0x948b0fff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
0x948d4000 - 0x9491aff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x94955000 - 0x94992ff7 com.apple.CoreMedia 0.484.11 (484.11) <0346F9E5-AEFE-B751-7D85-88D156C01385> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/Core Media
0x949a1000 - 0x949b5ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x949b6000 - 0x94caffef com.apple.QuickTime 7.6.6 (1742) <89720F2A-F33B-FF09-3D81-F9F25A99F3EB> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94cb0000 - 0x94cc5ff7 com.apple.iChat.InstantMessage 5.0.4 (746) <E2F51B36-EFB1-5ACC-4188-A02B81AC056D> /System/Library/Frameworks/InstantMessage.framework/Versions/A/Instan tMessage
0x94d08000 - 0x94d88feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
0x94d89000 - 0x94e31ffb com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
0x94e32000 - 0x94e82ff7 com.apple.framework.familycontrols 2.0.1 (2010) <B9762E20-543D-13B9-F6BF-E8585F04CA01> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
0x94f04000 - 0x950fbfeb com.apple.JavaScriptCore 6533.18 (6533.18.1) <EE3897A8-E1C0-DE28-A631-4B0C32DF737B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
0x950fe000 - 0x95241fef com.apple.QTKit 7.6.6 (1742) <98ECA8E3-73F0-D21B-8B7E-8FE651E29A7F> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x95242000 - 0x9541dff3 libType1Scaler.dylib ??? (???) <6FBA8250-3271-6ED4-052D-E27C2136E38F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x95453000 - 0x95888ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
0x95889000 - 0x958a1ff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x959db000 - 0x95a4aff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
0x95a4b000 - 0x95b15fef com.apple.CoreServices.OSServices 357 (357) <CF9530AD-F581-B831-09B6-16D9F9283BFA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
0x95b16000 - 0x95c90fe3 com.apple.CoreFoundation 6.6.3 (550.29) <00373783-3744-F47D-2191-BEEA658F0C3D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
0x95c91000 - 0x95cd7ffb com.apple.CoreMediaIOServices 130.0 (1035) <F5E6F93D-6844-9FD7-8769-44503DFD5363> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versi ons/A/CoreMediaIOServices
0x95cea000 - 0x95d05ff7 libPng.dylib ??? (???) <36A3D75E-5178-4358-7F02-444E276D61AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x95d06000 - 0x95d67fe7 com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
0x95d68000 - 0x95e94fff com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
0x95e95000 - 0x95edefe7 libTIFF.dylib ??? (???) <9CFF48CC-4852-4D06-17AC-3C947C824159> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x95edf000 - 0x95ee5fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
0x95ff6000 - 0x96043feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A /PasswordServer
0x96044000 - 0x9604fff7 libCSync.A.dylib 543.50.0 (compatibility 64.0.0) <4FA0CE4A-BDE5-0E3D-37F0-03B41F0C2637> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x96050000 - 0x96930ff7 com.apple.AppKit 6.6.6 (1038.29) <6F28C335-6DC2-AE0E-B79A-F256DBD0BB45> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x96931000 - 0x96a3dff7 libGLProgrammability.dylib ??? (???) <1B315838-F477-5416-7504-67EC3433AD4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
0x96a3e000 - 0x96ae7ff7 com.apple.CFNetwork 454.9.8 (454.9.8) <DB2A5C33-E833-1B3A-4DE0-5FF172B2048B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
0x96afc000 - 0x96b30ff7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <0B900F26-51C1-7639-346F-24B080AEDAF3> /usr/lib/libssl.0.9.8.dylib
0x96b31000 - 0x96cebfe3 com.apple.ImageIO.framework 3.0.3 (3.0.3) <A93A514B-C1BF-21D0-FB03-CB775DE4FFAA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
0x96cec000 - 0x96d7efe3 com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
0x96d7f000 - 0x96db0ff3 libTrueTypeScaler.dylib ??? (???) <7601D717-236D-8F4E-91F5-E69BB2920478> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x96ec6000 - 0x96ff4fe7 com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x97084000 - 0x970b7ff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
0x970b8000 - 0x97165fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x97166000 - 0x97514fe3 com.apple.RawCamera.bundle 3.3.0 (533) <05A38D21-8556-434C-8BAA-850A6EC99B37> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
0x975e4000 - 0x975e4ff7 com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x975e5000 - 0x97605fe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
0x97606000 - 0x97732ffb com.apple.MediaToolbox 0.484.11 (484.11) <B93B175A-2039-2FD2-FBE4-22C9F8C9E223> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
0x977a2000 - 0x979a8feb com.apple.AddressBook.framework 5.0.2 (870) <3E9D6CF3-6C41-245D-5343-941A185C8384> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBo ok
0x979a9000 - 0x97a59ff3 com.apple.ColorSync 4.6.3 (4.6.3) <AA1076EA-7665-3005-A837-B661260DBE54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
0x97aa3000 - 0x97ad4ff7 libGLImage.dylib ??? (???) <9340012D-595A-6243-9C97-7D30D76D9D9E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
0x97b18000 - 0x97b19ff7 com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
0x97bec000 - 0x97cc7fe7 com.apple.DesktopServices 1.5.7 (1.5.7) <A69072AD-C47E-A00D-4A69-6E46A7FB2119> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
0x97cc8000 - 0x97d7effb libFontParser.dylib ??? (???) <067DC1A2-764B-41EA-B07E-4205472749B7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x97d7f000 - 0x97d7fff7 com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x97d80000 - 0x97d8efe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
0x97d8f000 - 0x97de0ff7 com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
0x97dfa000 - 0x97e35feb libFontRegistry.dylib ??? (???) <A102F61F-25D5-001A-20C3-56304C585072> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x97e36000 - 0x97e36ff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
0x97e37000 - 0x97e5dfff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
0x97e5e000 - 0x97e7cff7 com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x97e7d000 - 0x97e88ff7 com.apple.CrashReporterSupport 10.6.3 (250) <981124CA-6E89-94C5-C7E9-4E0D6CA06F1D> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Vers ions/A/CrashReporterSupport
0x97e89000 - 0x97ecdff3 com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x97f0f000 - 0x97f51ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
0x97f52000 - 0x97f92fe7 com.apple.IMCore 5.0.4 (746) <9B1CF5CD-7C0D-F29E-2D74-68D79B36789D> /System/Library/Frameworks/IMCore.framework/Versions/A/IMCore
0x97f93000 - 0x97f93ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x97f94000 - 0x98088ff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
0x98096000 - 0x980a2ff7 libkxld.dylib ??? (???) <322A4B52-8305-3081-6B74-813C3A87A56D> /usr/lib/system/libkxld.dylib
0x980a3000 - 0x980a4ff7 com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x980cf000 - 0x98107ff7 com.apple.LDAPFramework 2.0 (120.1) <001A70A8-3984-8E19-77A8-758893CC128C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x98108000 - 0x98108ff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
0x98109000 - 0x9810dff7 IOSurface ??? (???) <66E11D8E-CF4B-EFD0-37F9-20177C647021> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9810e000 - 0x9810eff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9815a000 - 0x9825bfe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
0x9825c000 - 0x9825fffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
0x9826b000 - 0x9858bfeb com.apple.CoreServices.CarbonCore 861.13 (861.13) <52803668-3669-36BD-57DD-078FBA835081> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
0x9858c000 - 0x986c3ff7 com.apple.CoreAUC 6.04.01 (6.04.01) <B6E035A9-8DA2-82FC-9C2F-F57B9B62BE5F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
0x9870b000 - 0x9870fff7 libGFXShared.dylib ??? (???) <2D32BDBF-C941-93FD-E233-F03D28DB9E94> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
0x98710000 - 0x98774ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
0x987f4000 - 0x98806ff7 com.apple.MultitouchSupport.framework 205.34 (205.34) <813475E3-B323-9405-F758-DDA1F5D63B20> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
0x98807000 - 0x98809ff7 com.apple.QuickTimeH264.component 7.6.6 (1742) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/Quic kTimeH264
0x9880a000 - 0x9880fff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
0x98810000 - 0x98853ff7 libGLU.dylib ??? (???) <2093A1FB-67BD-39E0-CDE5-A97A77BDDBCE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
0x98854000 - 0x98946ff7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <D2C86308-F998-C83D-F49B-CD484D4EFE6A> /usr/lib/libcrypto.0.9.8.dylib
0x98947000 - 0x9894eff7 com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9894f000 - 0x98961ff7 com.apple.CoreMediaAuthoring 0.700 (700) <446FBB01-279B-2BED-E5A8-D36241B704B1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versio ns/A/CoreMediaAuthoring
0x98962000 - 0x98b8dff3 com.apple.QuartzComposer 4.1 (156.16) <578A1842-8B62-00BF-B2E8-4C0AA8E6A938> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
0x98b8e000 - 0x98c3cff3 com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
0x98c40000 - 0x98c4afe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
0x98c4b000 - 0x98c88ff7 com.apple.SystemConfiguration 1.10.2 (1.10.2) <398BB007-41FD-1A30-26D8-CB86ED5E467E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
0x98c90000 - 0x98caeff7 com.apple.iChat.IMFoundation 5.0.4 (746) <427B0732-581D-C741-0BFD-A8E4D3AD6F9B> /System/Library/Frameworks/IMCore.framework/Frameworks/IMFoundation.f ramework/Versions/A/IMFoundation
0x98cb7000 - 0x98cd9fef com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
0x98cda000 - 0x98cddff7 libCGXType.A.dylib 543.50.0 (compatibility 64.0.0) <3B49AED9-0DBA-9D21-F9AC-8784363AD762> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dyl ib
0x98cde000 - 0x98de0fef com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Framew orks/MeshKitIO.framework/Versions/A/MeshKitIO
0x98e29000 - 0x98e2cff7 libCoreVMClient.dylib ??? (???) <CA0BA8DC-0159-A808-A300-750358A6970C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
0x98e40000 - 0x98fe6feb libSystem.B.dylib 125.2.0 (compatibility 1.0.0) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
0x9903b000 - 0x9907eff7 com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
0x99129000 - 0x99137ff7 com.apple.opengl 1.6.9 (1.6.9) <4F06C166-00CF-5ACF-77E3-5A960A5E8AD3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x99138000 - 0x991b0fef com.apple.AppleVAFramework 4.9.20 (4.9.20) <D8B544CB-9E32-81C2-59BD-C5DDB66DA621> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
0x991b1000 - 0x991b1ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
0x991b2000 - 0x9928fff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
0x99290000 - 0x99293fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x99294000 - 0x994f8fef com.apple.security 6.1.1 (37594) <3F68A006-6B30-85D5-1A75-8D748F72A6D5> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x994f9000 - 0x99509ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x9950a000 - 0x9950cff7 libRadiance.dylib ??? (???) <AB06F616-E3EA-5966-029A-8AA44BBE5B28> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x99729000 - 0x99733ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
0x99734000 - 0x99748fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x998b5000 - 0x998f6ff7 libRIP.A.dylib 543.50.0 (compatibility 64.0.0) <8BAE1FC1-A478-F151-17C7-2D5DE470AC4F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0xb0000000 - 0xb0006ff8 com.apple.carbonframeworktemplate 1.3 (1.3.11) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0xc0000000 - 0xc0004ff1 +com.mainconcept.mcmpgvout 7.7 (7.7.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcmpgvout.framework/mcmpgvout
0xc1000000 - 0xc1010ff7 +com.mainconcept.mcmpgaout 7.5 (7.5.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcmpgaout.framework/mcmpgaout
0xc2000000 - 0xc2005fff +com.mainconcept.mcpcmaout 7.5 (7.5.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcpcmaout.framework/mcpcmaout
0xc3000000 - 0xc3004fff +com.mainconcept.mcmpgcheck 7.5 (7.5.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcmpgcheck.framework/mcmpgcheck
0xc4000000 - 0xc4056fe7 +com.mainconcept.mcmpegin 7.5 (7.5.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcmpegin.framework/Versions/7.5/mcmpegin
0xca000000 - 0xca037ff7 +com.mainconcept.mcmpgmux 7.5 (7.5.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mcmpgmux.framework/mcmpgmux
0xf0000000 - 0xf0004ffd +com.mainconcept.mch264vout 7.4 (7.4.0.35760) /Applications/Adobe Soundbooth CS5/Adobe Soundbooth CS5.app/Contents/Frameworks/mch264vout.framework/mch264vout
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <3441F338-2218-6D36-3F95-3A16FBF6713D> /usr/lib/libSystem.B.dylib
Model: MacBookPro5,1, BootROM MBP51.007E.B05, 2 processors, Intel Core 2 Duo, 2.53 GHz, 4 GB, SMC 1.33f8
Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.91.27)
Bluetooth: Version 2.3.7f1, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: Hitachi HTS543232L9SA02, 298.09 GB
Serial ATA Device: MATSHITADVD-R UJ-868
USB Device: iPhone, 0x05ac (Apple Inc.), 0x1294, 0x24100000
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24400000
USB Device: Hub, 0x05ac (Apple Inc.), 0x9136, 0x26200000
USB Device: PTK-640, 0x056a (WACOM Co., Ltd.), 0x00b9, 0x26230000
USB Device: Hub, 0x05ac (Apple Inc.), 0x9137, 0x26240000
USB Device: Display iSight, 0x05ac (Apple Inc.), 0x8508, 0x26242000
USB Device: Apple LED Cinema Display, 0x05ac (Apple Inc.), 0x9236, 0x26243000
USB Device: Display Audio, 0x05ac (Apple Inc.), 0x2912, 0x26241000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0236, 0x04600000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06110000
FireWire Device: My Book 1112, WD, Up to 800 Mb/sec
FireWire Device: OEM ATA Device 00, G-TECH, Up to 800 Mb/sec
