FMS 4.5 Installation Help (libcap not found)
Oct 10, 2011 5:00 AM
Tags: #installation #fms_4.5 #libcap
I am trying to install FMS 4.5 on Fedora 15 x64 server. I have downloaded the fms 4.5 development server and extracted the files.
Now, when I type the command:
./installFMS
I get an error message that says:
ERROR: A required package, libcap, was not found on your Linux x86_64 RedHat.
       Please install required package and run Adobe Flash Media Server installer again.
However, when I try to install this package using the following command:
yum -y install libcap
I get a message saying that it is already installed:
Loaded plugins: fastestmirror, langpacks, presto, refresh-packagekit
Loading mirror speeds from cached hostfile
* fedora: ftp.nluug.nl
* updates: ftp.nluug.nl
Setting up Install Process
Package libcap-2.22-1.fc15.x86_64 already installed and latest version
Nothing to do
So I am not sure how to solve this... FMS cannot see this lib for some reason.
Any help is appreciated.
Barjawi
    Oct 10, 2011 5:36 AM   in reply to Barjawi
    Flash Media Gateway is a sister product that's bundled with FMS. It provides SIP connectivity to flash applications.
    More info @ http://labs.adobe.com/wiki/index.php/Flash_Media_Gateway
    FMS does not require FMG to be installed, it is optional for supporting SIP clients. More documentation is also present in the docs folder after FMG is installed.
    Thank you !
    Oct 10, 2011 5:47 AM   in reply to Nikhil Pavan Kalyan
    For your libcap problem, may be the version of the libcap that's installed on your distro is to be updated ? I am not sure , but did you check that already ?
    Thank you !
    Oct 10, 2011 6:24 AM   in reply to Barjawi
    Wherever you untarred your FMS put a symlink libcap.so.1 linking to /lib64/libcap.so.2
    after that try installing FMS again ,let us know the result too
    Oct 10, 2011 7:59 PM   in reply to Barjawi
    Good to know about the progress.
    Turn off SELinux also for a while, to see if that helps.
    You might also want and edit the adminserver.sh and server.sh files to add your distro to the list of supported platforms so that fms will not bother you anymore. Check the fms 4.0 sh files, if you have already made any changes there too.
    Thank you
    Oct 10, 2011 10:41 PM   in reply to Barjawi
    As Nikhil rightly suggested you will be required to modify the server.sh as well as adminserver.sh files and put up the uname of your machine wherever you find the distro list that I believe will be occurring once in each file (so not much work will be required ☺)
    Vivek Gupta
    Extn:36025
    Dec 6, 2011 5:26 AM   in reply to Barjawi
    Thanks for the details.
    the nmap log for 1111 that you mentioned above does not seem to be binding to fmsadmin, it says lmssocialserver ( i am not sure what it is), but it should be 'fmsadmin' if the admin server of FMS is bound to that port. So, you do not have the port available to be bound by the fms admin service.
    There is no change that is made in FMS in terms of binding to ports. It depends on the port availability and how the different distro (of linux) take care of it.
