Adobe SendNow Desktop App
Jan 3, 2012 11:02 AM
Tags: #adobe #sendnow
I am having a problem downloading the SendNow Desktop Application.   I keep getting a Error 2032 about the installation failing.  I tried uninstalling flash player, and adobe air, but no luck.  I also tried to install it on alternate machines, but no luck.  I suspect that installation files may be blocked by web filtering software, but can ip addresses be provided for where the files are coming from, so I can add those exceptions to the firewall?  I added the adobe domain and anything under it, but no luck.  Thanks.
    Jan 4, 2012 12:42 PM   in reply to dy_it
    There's another discussion here about the same problem. Take a look at responses #4 and 5.
    Check your IE browser and ensure that it is NOT set to "Work Offline." A colleague found that if IE was set to "Work Offline," the SendNow Desktop App would not successfully download using Chrome.
    Jan 4, 2012 2:02 PM   in reply to dy_it
    Which domain did you add? adobe.com or acrobat.com?
    Jan 4, 2012 2:23 PM   in reply to dy_it
    Try adding it and see if that makes a difference. We've not encountered this problem before with the SendNow Desktop App, so we're not sure what will help.
    Jan 5, 2012 7:36 AM   in reply to dy_it
    Hi dy_it - let' try one more thing. Can you attempt to download the SendNow desktop application directly via https://sendnow.acrobat.com/SendNow/SendNowDesktop.air ? Save it somewhere on your computer and once it's downloaded completely double-click to install.
    Hope this works!
    Cheers - Tobias
