Thanks Leo,
Did the trick on my Windows 7 64bit machine.
@Adobe: you should be ashamed to let this go on for such a long time
@Leo: I donated something, but an additional message seems no option. Luckily the header of the payment says: "PDF 64-bit fixes", so your friend should know enough!
Rob
Hey guys,
It's interesting how this problem didn't exist for me until I started using Microsoft Office 2010 Professional Beta. When opening a PDF attachment in Outlook 2010, I get the error message "PDF Handler for Vista." I'm no longer using Vista, but Windows 7. All the Acrobat 9.3x intergration worked fine in Office 2007 prior to ungrading. For kicks I down graded to my Office 2007 Suite and the PDF Handler for Vista worked fine in Windows 7, and all the intergration with the Office Suite too. Below is a screen shot of Outlook 2010's Trust Center/Attachment Handling/Attachment and Document Previewers... window only confirms PDF Preview Handler for Vista is infact installed. Everytime I go to Outlook Options/Add-Ins PDFMOutlook.dll click /Go to activate this item it returns inactive after closing the program to accept changes. If anyone has any ideas, I'm all ears.
Michael
Well,
Here I am answering my own post... After posting, I decided to check out all the other posts as well. Wouldn't you know there's a fix, but not from Adobe. http://www.pretentiousname.com/adobe_pdf_x64_fix/ My PDF Preview Handler for Vista now works with Outlook 2010 using Windows 7 64bit.
thanks
Michael
mschaffer wrote:
Maybe Steve Jobs isn't too far off the mark with his "Adobe is lazy" statement.
For all that I've said about Adobe regarding this PDF issue (and others), I'd choose them over Apple any day. Apple's behaviour when given power over a popular platform is unforgivable -- e.g. arbitrarily banning all programming languages & tools except their own -- makes me side with Adobe on that fight.
For all that's wrong with Adobe in the last few years, I do still *choose* to use several of their software packages. The only Apple code I ever use is what's forced upon me to use their hardware. (Even then, since reinstalling with Windows 7, I've refused to install iTunes on my machine. I'll live with a stale iPod for a while and install it in a virtual machine when the time comes.)
I mean, if we're going to ban inefficient code that's the product of a poor cross-platform porting framework and results in an awful app, Apple should have the decency to ban their own Windows port of iTunes (or let me choose to use other software with their devices).
Anyway, glad the Adobe Reader fixes are working for everyone!
I agree with your statments about Apple,but it does not invalidate Jobs' assertion. Of course, it could just be apathy.
Anyhow, I haven't had any Apple code on my workstations for quite some time (iTunes and QuickTime are but a distant memory) so I find it hard to make a fair comparison. However, I would say that, of all of the software I use daily, I have the most problems with Adobe software---especially Acrobat. This has been the case for a VERY long time.
Also, regarding Apple's software, I am willing to give them a little slack only because, in my mind, they are a hardware vendor. I am a bit surprised that they can get both hardware and software to the level they do provide. However, the crap that Apple does get away with (arbitrarily restricting applications and development tools) is unconscionable! (Where's the DOJ on this one?)
Regardless of what Jobs said about Adobe, I certainly do not believe that Adobe Flash being buggy is the REAL reason Apple doesn't want Flash on their devices. It's all about Adobe's CS5 compliler being a conflict with Apple's edict that you must use thier toys. (http://labs.adobe.com/technologies/flashcs5/appsfor_iphone/)
The good news is that Adobe finally fixed the preview handler in the Adobe Reader 9.3.2 installer.
The bad news is that:
Other good news is that Office 2010 RTM came out and no longer requires the extra registry changes which the Office 2010 beta needed.
That's some progress at least. Still a long way to go, though, Adobe.
I had noticed the fix for the preview viewer after upgrading my laptop to window 7 64-bit (custom install as I was running Vista 32-bit) the other week. I had expected to have to redo the fix for this but discovered it was already working.
Note I am not sure what controls Thumbnails, but some of my PDF documents do get updated thumbnails as well, while others get a generic pdf thumbnail.
Without installing my thumbnail fix, 32-bit apps are still able to generate thumbnails which Windows then caches and provides for 64-bit apps if they ask for thumbnails for the same files. (But 64-bit apps still cannot generate fresh thumbnails for other files without installing my fix (or an alternative PDF tool that supports 64-bit).) So if you see thumbnails for some PDF files and haven't installed any fix or alternative tool, it's probably just because a 32-bit app cached a thumbnail for those files in the past.
By the way, it turns out Adobe didn't quite get the preview handler fix right in the 9.3.2 installer: If you upgraded from Vista to Windows 7 you'll probably still need to run my preview handler fix (but only once, at least if you grab the latest version from my website).
Hi. I have Acrobat Standard v9 installed and not Reader. I was able to fix the PDF Preview Handler issue by doing a registry search and replacing the AppID wherever it was wrong. I am not so sure about the thumbnail preview fix though -- will this work for me or will it only work for Adobe Reader?
matinum2 wrote:
Just installed Reader 9.4.1 and shows a preview in the preview pane now.
Yep, Adobe (more or less*) fixed the preview-handler installation. (*They missed an edge case with Vista->Win7 upgrades, FWIW. My preview handler fix will correct that for anyone who runs into it.)
matinum2 wrote:
At first it was showing thumbnails in my windows folders, (Win7 64b) but now, they disappeard.
They still haven't fixed the thumbnails.
If a 32-bit process caused the thumbnails to be generated and cached, those thumbnails will also show up in 64-bit processes like Explorer. But those 64-bit processes still cannot generate their own thumbnails unless my thumbnail fix is installed. That's probably what you saw.
Hello! I have a new computer with Windows 7 & Outlook 2010, and I just installed the new Acrobat X + Reader X. The Preview Handler has never worked in Outlook 2010, and still doesn't with X.
I used the utility (before and after installing X) to see if it would fix the problem but even though it said the registry was corrected, the Preview Handler still doesn't work in Outlook, nor does the Thumbnail feature work in explorer.
I've re-started, re-booted, and everything else I can think of, and I'm still getting "this file cannot be previewed because of an error with the following previewer: PDF Preview Handler". Do you have suggestions on how to fix this? I am totally willing to donate!
Thank you so much,
Ella
hey Leo,
I went through this post quite fast cause I'm having the same issue as most of the users of this post. I can't get adobe reader X (PDF preview handler) to work with MS Outlook 2007 with SP2 (32 bits). Is there a way to get through this? Does adobe have a patch out? The company just upgraded from 9 to X and since, we've had this issue.
You mentionned an APP for this or any other suggestion will do....
Hey everyone! I'm still not getting it to work properly, even after installing Leo's fix. I'm running Win 7 and access all my files off of a network drive (maybe that's the problem?).
Because I've installed the fix, it is showing thumbnails, but the thumbnails I'm seeing are often for the next, most recent file in the folder. Sometimes the thumbnails are accurate and sometimes not - there doesn't seem to be any rhyme or reason to it.
I've tried everything I can think of. Repaired installations on everything, installed and uninstalled it all, even manually reset the registry so the fix could fix it all over again.
Thoughts, anyone???
Guys,
We are having difficulties with the adobe X prefiev handler on terminal services (remote desktop session host)
When an administrator opens outlook and want to see the preview in Outlook 2010, it goes perfectly. Also the Windows Explorer preview pane does work.
But on a account with normal user rights (non-local admin) the preview handler in outlook as well as Windows Explorer doe not work.
does anybody else experience this problem?
Hope the misery of this problem will end soon, because it never worked properly.....
greetz
I'd been working fine for a while, but then a few months ago again lost the preview functionality. I'm running 64-bit Windows 7 with Office 2010, and Adobe Reader X. I checked the registry, and that's OK, tried repairing Reader & Office, all to no avail. Finally, I uninstalled and reinstalled Reader and now all is well again! Go figure; I haven't had to go the "reload" route in a while
I suppose an update/fix install doesn't go through the whole process necessary to configure the previewer.
Copyright © 2012 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
