Hi, I was trying to build and emulate a PhoneGap project with following environment, but it failed:
The build of application failed to complete successfully. This is the link of the log file I got: log file
Following is my screenshot on Application Setting:
I wonder this may involve in updating PhoneGap to latest version. But could you help me pass this problem?
Same problem here. I've been waiting almost a month for a proper response from Adobe developers along with other users having similar problems. If the process does not work anymore as advertised then at least take the advertisement down from your dreamweaver feature page. At this point it is just false advertisement of a feature that does not work. ![]()
Same here, I get an error "The build of 'pgaptest' failed to complete successfully. Please consult the log..." When i do a get an error "
error: type of property 'returnType' ('unsigned int') does not match type of ivar 'returnType' ('enum DestinationType') [3]
@synthesize returnType;". Tried compiling it in xcode and xcode complains "Check dependencies Unsupported compiler 'GCC 4.2' selected for architecture 'armv7'", Any ideas anyone? Its not anything I've done this is merely compiling the default index page generated by the new document mobile starters, havnt altered a thing, what gives?
Hi Teerasej. I came across the same problem and managed to fix it. The key lies in the log file here:
/Users/teerasej/Documents/DW_NAF/PhoneGapLib/Classes/Camera.m:178:13: error: type of property 'returnType' ('unsigned int') does not match type of ivar 'returnType' ('enum DestinationType') [3]
I had a similar error message in my log file. I fixed it by simply heading over to the Camera.h file from the PhoneGapLib XCode project, and correcting the property of the return type as so:
was:
@property (nonatomic) DestinationType returnType;
change to:
@property (nonatomic) enum DestinationType returnType;
Save file then try again. Fixed it for my anyhow.
Hi Peter, Thank you for your solution.
First of all, it is very good that your error log and mine one is same. But I found the line you mentioned in Camera.h file already code like this:
So I wonder do I need to remove 'enum' or not. Could you give me any suggestion?
Adding the return type does seem to work in the sense that it compiles, so at least we are getting somewhere. Well done Peter. I have tried, (using the phoneGap example routines) some camera functions. The simulator doesnt support this (cant think why!?) So I successfully compiled the projext in xcode to run on my iPhone. The exe runs fine but sadly it crashes when any of the camera functions are envoked. Im not very familiar with Cocoa to know where to go next.
I wonder if anyone at Adobe actually tested any of this stuff?
Haha it would seem not. Are you saying it crashes when you try the camera functions when running on an actual device? Obv it won't work in the simulator. You can get crash reports from a iOS device by connecting it to your computer, then going into XCode - > organizer then you can see all the info for your device, including crash reports.
Yes Im running it on an iPhone. Got the crash report. Heres the relevent bit...
Identifier: phonepic
Version: ??? (???)
Code Type: ARM (Native)
Parent Process: launchd [1]
Date/Time: 2012-01-07 11:11:17.377 +0000
OS Version: iPhone OS 5.0.1 (9A405)
Report Version: 104
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x001e2fff
Crashed Thread: 0
Solved!
My camera.h file looks like this (after days of testing):
@interface CameraPicker : UIImagePickerController
NSString* successCallback;
NSString* errorCallback;
NSInteger quality;
NSString* postUrl;
enum DestinationType;
enum returnType;
@property (assign) NSInteger quality;
@property (copy) NSString* successCallback;
@property (copy) NSString* errorCallback;
@property (copy) NSString* postUrl;
The process of compiling to iphone/ipad goes smooths, without errors.
Hope this helps!
i had same problem i try to follow ur steps but problem is i cant find camera.h in xproject to change anythig there. in phonegap.js i found camera but thats cemra function not look like what u guyz said here could some one help me pls ? i really approciate it.
TNX
