sanjeevan89
Cannot open Flash Builder 4.5 after updating
Sep 15, 2011 8:13 AM
I have a corporate version of CS5.5 installed on 32bit machine.
Recently, Flash Builder notified me of an available update. It was for some Java but since Eclipse is Java Based I intalled it.
Now when I open it, it freezes on the splash screen. Without closing it, I open a new one. It asks for a new workspace since old used, I gave it new one. Still stuck on splash screen. Tried restarting computer. Now when I open Flash Builder, it is not stuck on splash page but and error popups and program exits. The popup tells me to look at a log file.
Here is the log file contents
!SESSION 2011-09-15 11:03:52.113 -----------------------------------------------
eclipse.buildId=M20110210-1200
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2011-09-15 11:03:53.844
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles
     at org.eclipse.swt.SWT.error(SWT.java:4109)
     at org.eclipse.swt.SWT.error(SWT.java:3998)
     at org.eclipse.swt.SWT.error(SWT.java:3969)
     at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
     at org.eclipse.swt.widgets.Control.createHandle(Control.java:633)
     at org.eclipse.swt.widgets.Composite.createHandle(Composite.java:305)
     at org.eclipse.swt.widgets.Control.createWidget(Control.java:649)
     at org.eclipse.swt.widgets.Scrollable.createWidget(Scrollable.java:134)
     at org.eclipse.swt.widgets.Control.<init>(Control.java:110)
     at org.eclipse.swt.widgets.Scrollable.<init>(Scrollable.java:75)
     at org.eclipse.swt.widgets.Composite.<init>(Composite.java:95)
     at org.eclipse.ui.splash.BasicSplashHandler.getBundleProgressMonitor(BasicSplashHandler.java:159)
     at org.eclipse.ui.splash.BasicSplashHandler.getContent(BasicSplashHandler.java:265)
     at org.eclipse.ui.internal.splash.EclipseSplashHandler.init(EclipseSplashHandler.java:86)
     at org.eclipse.ui.internal.Workbench$8.run(Workbench.java:782)
     at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
     at org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbench.java:798)
     at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2467)
     at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
     at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
     at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
     at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
     at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
     at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.java:108)
     at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
     at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
     at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
     at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
     at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
     at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
     at java.lang.reflect.Method.invoke(Unknown Source)
     at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
     at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
     at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Edit - found another thread with similar issue but still no solution.
    Oct 23, 2011 4:58 PM   in reply to sanjeevan89
    I'm getting the same problem, have you heard of or found a fix for this issue yet?
    Dec 5, 2011 4:32 AM   in reply to sanjeevan89
    I am in the same boat now and OH SO HOSED.  Help, Adobe!
    Jan 7, 2012 10:05 PM   in reply to sanjeevan89
    Hi
    Just did a update in FB4.6 and now have above issue.
    Any word on this.
    Cheers
    Jan 25, 2012 9:28 AM   in reply to jasenm
    Yes, same here. I just upgraded to FB4.6 and now am having this problem. A solution would be great to see.
    Apr 25, 2012 11:52 AM   in reply to sanjeevan89
    Hello, I'm having the same issue with Flash Builder 4.6.
    I got it off freeriatools.adobe.com, after installing I tried to open it and it said "An unexpected runtime error occured : No more handles" with the following errors in the log file :
    !SESSION 2012-04-25 20:40:19.812 -----------------------------------------------
    eclipse.buildId=I20100608-0911
    !ENTRY org.eclipse.ui 2 0 2012-04-25 20:40:36.702
    !MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
    !SUBENTRY 1 org.eclipse.ui 2 0 2012-04-25 20:40:36.702
    !MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter ', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.catego ry.help'
    !ENTRY org.eclipse.osgi 4 0 2012-04-25 20:40:37.412
    !MESSAGE An unexpected runtime error has occurred.
    !STACK 0
        at org.eclipse.swt.SWT.error(SWT.java:4308)
        at org.eclipse.swt.SWT.error(SWT.java:4197)
        at org.eclipse.swt.SWT.error(SWT.java:4168)
        at org.eclipse.swt.widgets.TaskBar.createHandle(TaskBar.java:103)
        at org.eclipse.swt.widgets.TaskBar.<init>(TaskBar.java:96)
        at org.eclipse.swt.widgets.Display.getSystemTaskBar(Display.java:2564)
        at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.ge tTaskItem(Workbench.java:303)
        at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.ha ndleTaskBarProgressUpdated(Workbench.java:319)
        at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.wo rked(Workbench.java:268)
        at org.eclipse.ui.internal.Workbench$StartupProgressBundleListener.bundl eChanged(Workbench.java:420)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEv ent(BundleContextImpl.java:847)
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventM anager.java:230)
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchr onous(ListenerQueue.java:148)
        at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent Privileged(Framework.java:1522)
        at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent (Framework.java:1458)
        at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent (Framework.java:1453)
        at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(Bundl eHost.java:391)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(Abstrac tBundle.java:299)
        at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java: 440)
        at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLo ader.java:268)
        at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFind LocalClass(EclipseLazyStarter.java:107)
        at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(C lasspathManager.java:462)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalCla ss(DefaultClassLoader.java:216)
        at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLo ader.java:400)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Bundl eLoader.java:476)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader. java:429)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader. java:417)
        at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(De faultClassLoader.java:107)
        at java.lang.ClassLoader.loadClass(Unknown Source)
        at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader. java:345)
        at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleH ost.java:229)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(Abs tractBundle.java:1207)
        at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance (ServiceComponent.java:480)
        at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInst ance(ServiceComponentProp.java:271)
        at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(Serv iceComponentProp.java:332)
        at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(Instan ceProcess.java:588)
        at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java :53)
        at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse .java:138)
        at java.security.AccessController.doPrivileged(Native Method)
        at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(Servi ceUse.java:136)
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.get Service(ServiceRegistrationImpl.java:468)
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService( ServiceRegistry.java:467)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService (BundleContextImpl.java:594)
        at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.jav a:450)
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(Service Tracker.java:980)
        at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(Service Tracker.java:1)
        at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.jav a:262)
        at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.ja va:185)
        at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:348)
        at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:283)
        at org.eclipse.core.internal.runtime.InternalPlatform.getBundleGroupProv iders(InternalPlatform.java:225)
        at org.eclipse.core.runtime.Platform.getBundleGroupProviders(Platform.ja va:1261)
        at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.getFeatureInfos(IDEWor kbenchPlugin.java:291)
        at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.makeFeatureDepende ntActions(WorkbenchActionBuilder.java:1217)
        at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.makeActions(Workbe nchActionBuilder.java:1026)
        at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarA dvisor.java:147)
        at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.fillActionBars(Wor kbenchActionBuilder.java:341)
        at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindo w.java:3564)
        at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:4 19)
        at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWor kbenchWindow(Workbench3xImplementation.java:31)
        at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1 920)
        at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1918)
        at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java: 1202)
        at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupT hreading.java:31)
        at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
        at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.ja va:135)
        at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
        at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
        at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvi sor.java:803)
        at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java: 1595)
        at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
        at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
        at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
        at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja va:332)
        at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:667)
        at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashB uilderApplication.java:108)
        at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:196)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110)
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:344)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:179)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
    !ENTRY org.eclipse.ui.workbench 4 0 2012-04-25 20:40:38.511
    !MESSAGE FrameworkEvent ERROR
    !STACK 0
    !ENTRY org.eclipse.osgi 4 0 2012-04-25 20:40:38.974
    !STACK 1
        at org.eclipse.ui.internal.WorkbenchWindow.createProgressIndicator(Workb enchWindow.java:3362)
        at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(Workben chWindow.java:1130)
        at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultConten ts(WorkbenchWindowConfigurer.java:623)
        at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContent s(WorkbenchWindowAdvisor.java:300)
        at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindo w.java:1036)
        at org.eclipse.jface.window.Window.create(Window.java:431)
        at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java: 1211)
    I was wondering if anyone has found a solution to this problem yet? Because I need this software to work on my laptop in order to start working on my school projects.. Thanks in advance.
Bookmarked By (1)
