Precise snapping to guides and points, Smart Guides do not work properly!
Aug 24, 2011 5:45 AM
I'm an architect and use Illustrator to do detail and presentation plans that need to be very precise.
I upgraded to CS5 from Freehand X, due to the fact the in OS Lion, Freehand doesn't work anymore and unfortunatelly finally died.
After more than 20 years using Freehand, I have noticed how hard it is to work with precision guides and snaping in illustrator CS5, instead of drawing precise objects in precise locations, it takes you 3x longer because you cannot snap to guides, the objects you draw are never aligned properly with a big error probability, so you have to double check always, adjust. move, resize and it's a hell!!!
Smart Guides don't work most of the time.
FORGET THE GRID (not the point in this problem).
Example 1:
I have 2 guides one vertical and one horizontal that cross eacother, I want to start a rectangle (Tool M) from the intersection to another intersection of another 2 guides, when you place the cursor near the starting intersection it doesn't snap to the guides, neither on the other intersection where you want the rectangle to end!
So I need to activate the bounding box, zoom in resize on one corner then go to the other and do the same, it's ridiculous.
Example 2:
When you grab a rectangle and want to place it in the corner of a guide intersection, you need to grab the exact corner to do that and drop it very close to the intersection and it does snap to the guides, BUT when you grab the rectangle from the middle (when you don't have the "Object Selection by Path Only" activated) it's impossible to snap it to any guide!!! That is a bum!
In Freehand doing these kind of tasks was so much easier and totally precise when you did that.
You had the option of Snap to Guides, AND Snap to Points.
Can someone tell me if Smart Guides just don't work properly and why do we have such ridiculous precision errors when we want to draw very precise...?
Help would be appreciated.
    Aug 24, 2011 1:00 PM   in reply to elturi
    I second all of that.
    Reading your post my stomach started to turn because I was once again reminded how ludicrous Adobe Illustrator can be.
    I have to use it every single day and every single day I run into absolutely ridiculous limitations.
    And every day my stomach turns.
    I used Corel Draw for 18 years before I had to switch to AI.
    When I used Corel Draw I could just fly with my work. It was so easy and it just made sense.
    Doing anything in Adobe Illustrator really does take three times longer. More steps, hidden features, and a huge list of just plain stupid s**t.
    You're lucky you don't need to work with Type much in your line of work. Type in Illustrator is a nightmare.
    P.S. I really don't think Freehand and Corel users are being irate simply because Illustrator does things differently.
    We're complaining because, without a doubt, Illustrator can really suck.
    Aug 26, 2011 5:52 PM   in reply to John Stanowski
    hello !
    I`ve never used free hand or corel draw but I`m confident they are great programs,
    illustrator can also snap to guides and points, but as you experienced, its a bit slippery when zoomed out, it doesnt snap so easily,
    a quick demo video to show what happens and preferences settings.
    setting preference guides to show measurement labels and smart guides helps me know when the point has snapped when zoomed out, otherwise yes it is hard to tell, and you have to move in slowly when zoomed out, it doesnt give you that solid snap feeling,
    I also set the snap to 8 points tolerance to give me more of a magnet when moving in but that doesnt help much.
    I know even with smart guides are on, the problem there is when your illustration is detailed smart guides snaps to every other objects side and centre so its like driving around in mud a bit as you constantly get stuck from the snapping to different objects.
    I dont think one should have to have smart guides on to get a good solid snap to guides or intersections of guides. they should snap regardless.
    A suggestion would be the option in preferences for 5 check boxes in smart guides or selection & anchor display:
    1. snap to all
    2. snap to guides and guide intersections only
    3. snap to grid only
    4. snap to object centres and sides only
      # a box beside each to enter snapping tolerance for each of the 5 options. so totally customizable. 1-10 px
    5. cursor snap to anchor or point (when it snaps the cursor over that handle or point it demagnetizes instantly, so the snap is just to place the cursor on that point or anchor, then demagnetizes. and sub-option for this: If 2 or more points are all within the same radius of the cursor or eachother the snapping is disabled so as to avoid confusion, labelled : close points disqualify and again a points radius setting box 1-10 px).
      1.
        I`d also like to see the handles and points bigger, even when zoomed out the option in preferences to keep anchor handles and points the same size. this may not work in some instances but is helpful for me to see things
        it might seem like overkill but really with millions of users and a huge variety of needs this more granular choice is certainly worthy and very practical.
        and most importantly the magnetic sensation of snapping and accurately to the object corner point or edge when zoomed out of the objects so you dont have to zoom right in to get a clean visual snap.
      2. Currently Being Moderated
        Aug 29, 2011 7:54 PM   in reply to bluefire777
        my edit:
        apologies, when dragging the point  on the object you want to intersect with the guide or the guide cross intersection;
        a white arrow with no stem  will appear when that point hovers over the guide,
        and a white arrow with cross in it will appear when the point you are dragging is about to snap to the cross section of 2 guides.
        just release your left mouse drag and it will snap to that point,
        again
        in prefs I have preview bounds off, smart guides OFF, path lables off.
        I`ve found this very helpful when aligning objects while zoomed out.
        corrected instructions given
      3. Currently Being Moderated
        Jan 7, 2012 8:41 PM   in reply to elturi
        I find smart guides incredibly difficult to deal with. I don't know how many times I grab the corner of a rectangle, trying to drag it so that it butts-up to another shape, only to have AI try to convince me that it's really the CENTER of the rectangle that i want to align. Every time. Did I grab the center point? -- NO. I grabbed the upper-left-hand corner. If I'd wanted to snap the center of the rectangle I WOULD HAVE DRAGGED FROM THE RECTANGLE'S CENTER. I suppose there have been meetings discussing the whys and ways of smart-guides, but I find them completely illogical. I know there is a better way, because I've used Maya, (not known for its user-friendliness), and I'm never confused or disappointed when trying to snap-align points.
      4. Currently Being Moderated
        Jan 24, 2012 11:34 AM   in reply to scottaelist
        that's interesting scott I have never experienced that, although I admit I have only been using AI for a few weeks.  But for me it always snaps the anchor that I grabbed (CS5.1).  It was annoying at first before I realized that you had to actually grab the anchor, but actually even more annoying is that I can't precisely position the Rotate or Reflect points without zooming all the way in first (there's no way to say hold down the mouse button while you drag the thing to make it snap -- that is, you can drag, but it won't snap)
      5. Currently Being Moderated
        Feb 8, 2012 12:55 PM   in reply to elturi
        Hey guys,
        do not complain that hard about Illustrator. It is actually one of the most versatile program for working with graphics, vectors and type. Yes, for TYPOGRAPHY. I love InDesign for that, but at certain moments, and mostly for Packaging, you've got a whole bunch of tools to make what you need.
        "Align to selection" button. There is the MAGIC!
        For activating the alignments of different graphics and for activating the smart guides, take a look at the top of your screen and switch thereScreen shot 2012-02-08 at 3.41.31 PM.jpg
        All the best!
      6. Currently Being Moderated
        Jul 14, 2012 12:04 PM   in reply to ionutpozitiv
        I'm finding no magic in the "Align to Selection" button. I agree that Illustrator has a lot of great ways to align things, but why can't they add a "Snap to Guides" option that works like the "Snap to Grid" option? If you don't want to use it, you can turn it off and work with guides as you do now...as approximate visual reference guides rather than precision alignment guides. I would also like to see Adobe add a way to change the origin point of the grid. If it's there, I can't find it.
      7. Currently Being Moderated
        Jul 15, 2012 11:46 PM   in reply to the-design-guy2
        under the view menu you can turn on and off smart guides, snap to point, and snap to grid (if using grids like guides)...I created shortcuts for them becasue I turn them on and off so often,
        I`ll agree when I`m zoomed out and run an anchor I`m dragging onto another anchor point, and it reads path or anchor and seems to snap, when I zoom in, sometimes its absolutely not snapped to that point at all. even though it seems to have from a zoomed out view.
        with grid origin points, you can use the artboards tool on the toolbar to place workspaces where ever you want on the grid. once you draw out the artboard and place it, you can position it more accurately by pressing ënter"  and typing in x and y position co-ordinates. and or board size adjustments... not sure if that helps.. each artboard can have its own rulers I believe but ive never used it.
      8. Currently Being Moderated
        Jul 25, 2012 8:25 PM   in reply to bluefire777
        I used AI everyday and had the same issues with Smart Guides. So, I wrote a path editing plugin that allows me to snap in a logical manner. In writing the plugin, I learned that Smart Guide engine is very powerful and configurable at the programming level. The problem is the tool (ex: direct selection tool) that uses this Smart Guides engine does not configure it properly. If you are interested in this plugin send me an email and when it is ready for testing I will send it to you.
      9. Currently Being Moderated
        Sep 14, 2012 3:22 PM   in reply to minimum99
        Snapping is so useful, so often, that it should probably be in a toolbar or, better, a tool palette.
        I'd like to see a palette that had the Align controls and that Reference Point widget we use to pick which corner of the object to use when resizing (I click on that very often).
        The Snapping palette could have expandable options, like other palettes (Transform, for example). Expanding the palette could reveal snapping options that we could set pretty much like we set stroke width or opacity now: number fields for grid snap, point (pixel) snap, a checkbox to toggle each kind of snapping, and a big on/off button in the center of the palette to toggle all snapping.
        I am constantly clicking in the Control Bar up top to pick a corner (or center), then resizing by clicking in an number field and using my arrow keys, or typing a number (mostly, I use the arrow keys to bump the number up/down a tiny bit). That helps me keep the edge or corner of a shape pinned in place while I resize it. My view of the Control Bar's Align controls is blocked by tooltips, though, so a palette would suite me better.
        I should use the Transform panel, but then I'd have to give up a Mac keyboard shortcut I use all day long.
        It would really help me to have more flexibility with setting keyboard shortcuts, in general.
        OK, back to snapping and drawing....
      10. Currently Being Moderated
        Oct 3, 2012 8:34 AM   in reply to mapsnmad
        I am writing a plugin that implement its own snapping engine and it will have a pallete allowing you to turn on/off all snapping or any combination of object, object's bound, page bound, intersection. Plus I am adding distance snapping to the same engine. If you interested in testing this plugin please reply to this post.
        By the way you can configure the snapping engine separately for mouse hover and mouse drag separately with this plugin. This snapping comes with an advanced path editing tool that allow you to copy and replace anchors, segments from one path to another path. Also it allows you to reflect one or more selected anchors or segment with respect to path anchors. I added many more cool features to the path editor tool and too many to mention here.
      11. Currently Being Moderated
        Oct 3, 2012 8:38 AM   in reply to minimum99
        Hey, hook me up. I'd love to see what you've done!
      12. Currently Being Moderated
        Oct 3, 2012 9:43 AM   in reply to minimum99
        I'd love to try it out as well. The standard snapping annoys me daily.
      13. Currently Being Moderated
        Oct 12, 2012 12:10 PM   in reply to elturi
        I often do my preliminary vector work in InDesign because it has more dependable snapping behavior.
        Then I copy my work into Illustrator when I need it's unique features (removing clipping masks as a consequence of cut & paste).
        This is the most pleasant way I've found to work, being an old Freehand user who never fully warmed up to Illustrator.
      14. Currently Being Moderated
        Oct 14, 2012 1:34 PM   in reply to elturi
        I completely agree with everything you said. Just adding my reinforcement here in hopes (*crosses fingers) that Adobe will take a clue from this thread. I wish they would just take a look at AutoCAD. That is my one wish and dream for AI. Adobe, if you are reading this, go use AutoCAD for a little bit and play around with their snapping features. It is so much more polished and refined than AI, I can hardly imagine the two existing simultaneously in the same universe. If I want to snap to something in AutoCAD, all I have to do is press F3, and all of my preset snapping rules come into effect. Clearly recognizable endpoint markers, midpoints, center markers, etc. I can't imagine it being that difficult for Adobe to adapt similar algorithms for AI. Adobe please...
      15. Currently Being Moderated
        Mar 28, 2013 2:11 PM   in reply to Mr Twittles
        I'm so happy that you've brought up this issue.  I thought I was going crazy.  In my expereince the problem started with CS4.  I often jump back into CS3, and I'm amazed at how much better the guides work.  If I compare a working file in CS4,5,6 and CS3, there is a huge difference in craft: the CS3 file is clean, the CS4,5,6 files are sloppy when zoomed in.  I've tried a variety of snapping tolerances, and none seem to correct the issue.  It may be due to the fact that Smart Guides now try to align across the entire artboard, where they only snapped locally near the mouse before.  It may be aligned to an object 3 miles away on the artboard. I find myself checking and double checking art, and it's a real waste of time.  With all of the great improvements to effects and pixel support in CS6, I hate going back now.  If only Adobe would allow you disable long distance snapping, control the radius, or choose CS3 vs CS6 type smart guides the problem could be solved.
      16. Currently Being Moderated
        Apr 14, 2013 8:42 AM   in reply to elturi
        Could not agree more. This is the weakest point of Illustrator, a program I use on a daily basis. I've become so frustrated by its "snapping" that I do much of my vector work in 3d software just to avoid AI!
        The purpose of snapping is to align two points EXACTLY. If it's not exact, it's not a feature. When doing precise vector work at any zoom level, illustrator's "snapping" is maddening. Zoom in enough and your points are never aligned. Align them while at maximum zoom and they magically snap to be a little bit off of where you painstakingly placed them.
        On the same note, there is no point of having a  grid "feature" if it's imprecise. Two useless features that make AI a program of mere approximation.
      17. Currently Being Moderated
        May 2, 2013 1:22 AM   in reply to jashland
        I'm a pretty experienced AI user as of CS3, so I was pissed when I upgraded to CS6 last week and couldn't get an object path to snap to another object path easily. CS3 was perfect. But after a few hours of frustration I think I've figured it out. My settings are below, but read the last paragraph to see what I think the real solution is.
        Preferences > Selection & Anchor Display:
        • Tolerance: 3 px
        • Uncheck "object selection by path only"
        • Check "snap to point" 8 px
        • Check "control click to select objects behind"
        Preferences > Smart Guides:
        • Check Alignment Guides
        • Check Object Highlighting
        • Check Transform Tools
        • Check Construction Guides
        • Check Anchor Path Labels
        • Uncheck Measurement Labels
        • Snapping Tolerance 8 pt
        But here is what I think really matters. Grab your object you want to move with the Selection Tool (V) and begin to move it close to the anchor or path you want to align it with. Then, and only after its close, press and hold Control, while still holding the left mouse. This should result in the desired precision snapping we got with CS3.
      18. Currently Being Moderated
        May 20, 2013 4:16 PM   in reply to mmoore2144
        Thanks for posting this but still not working for me. To clarify: 1) I am often not able to 'micro drag' points - they snap to some location beyond my intended drag point, as if snapping to a grid [Snap to Grid is OFF] 2) segments that are vertical or horizontal behave the same - not able to 'micro drag'.
        Paths with such segments mixed in will also not permit stroke weight adjustment other than a whole number, for example, try to set to 1.5 and it jumps to 2. Fixing requires a lot of search for problem segments, fiddling, tricks and reconstruction.
        I was involved in software design for 12 years and I find it aboslutely unbelieveable that Adobe hasn't addressed this, either with a defect fix (if that's the problem) or with Help instruction. My former employer would never have allowed this kind of thing to continue on and on, ad naseum.
        I hope that it is simply that I am overlooking something, but I don's think so. If there is a defect, fix it, Adobe, or publish to The World the correct settings or workflow. This is greatly affecting my productivity.
        I was unable to connect to my own video example but you can search YouTube "illustrator point snapping problem' or just try this embed code: http://youtu.be/vc1G0O8tsjQ
      19. Currently Being Moderated
        May 20, 2013 4:50 PM   in reply to flying_so_low
        I went from CS3 to CS6, so I can't speak to CS5, but I don't recall what you are attempting to do in your video ever working that well. What I have always done is grab the path (or anchor) I want to snap and move it to an anchor that is inline with where I want to snap. Then as I move it away, Illustrator then knows I want to line it up with the anchor I dragged over.
      20. Currently Being Moderated
        May 21, 2013 8:39 AM   in reply to mmoore2144
        Thanks, I will try that work-around. BTW, this is on CS6. thanks
