good or bad calibration
Jan 8, 2012 11:17 PM
Hello! I've bought a new calibrator and calibrated my monitor. The colors looks different now. But it seems to me they doesn't look ok. They are too dark and ... pinkish. I don't know what to think. How can I check if my calibrator works right?
    Jan 8, 2012 11:52 PM   in reply to Gulfiya
    Open a grayscale test image full-screen and look for color casts. Take your time and let the eye adapt! It could be that the ambient light is playing tricks on you, or that you're simply used to a previous color cast.
    Next make a black to white gradent. It should be smooth all the way and ideally you should be able to make out all the 256 levels as individual steps. Look for any sudden transistions or color banding.
    What kind of calibrator, what monitor? What are your target settings (gamma, white point temperature, white point luminance, black point)?
    Luminance is a tricky one. In a "normally lit" environment you should aim for 100 - 120 cd/m², whereas most LCDs natively are up in the 300-400 range, IOW far too bright. But this depends on the ambient light. You should adjust brightness in the monitor's OSD controls, but for this the calibrator should have a way to read the value off the screen. If it doesn't, then go for a setting that gives a good match to printed output (where the white point luminance is fixed: the paper).
    Jan 9, 2012 1:16 AM   in reply to Gulfiya
    For a quick visual verification of accurate monitor calibration, use the PDI Test target image:
    Search Google Images for PDI Test and make sure you download a copy that is TAGGED, i.e. that has an embedded color profile.
    ____________
    Wo Tai Lao Le
    我太老了
  • Andrew Rodney
    Apr 16, 2009
    Jan 9, 2012 7:05 AM   in reply to Gulfiya
    In terms of the prints being too dark (or just darker than the calibrated display), see:
    http://www.luminous-landscape.com/tutorials/why_are_my_prints_too_dark .shtml
    In terms of testing the display:
    http://www.ppmag.com/reviews/200412_rodneycm.pdf
    Apr 23, 2012 1:07 AM   in reply to Gulfiya
    Try checking it with online calibration tools. Screencheck, for example,can  help you to determine if your screen is set to the correct brightness and color.
