Why does my photo linger on?
Jan 9, 2012 6:32 PM
Hi group;
  I've been working on a documentary for about a year and am close to wrapping it up.  I've encountered a really frustrating issue though.  I have a lot of photos, most run thru Photoshop to size them appropriately and so forth.  In the main the photos are working just fine.
There are two spots however where I need the image to cut off precisely with a cue in the underlying music.  In the CS5 Timeline this works great and is not a problem.  However, twice recently I have rendered the film to put it on DVD to get critiques from colleagues and both of these photos last well beyond the music cue, by nearly a full second.  I rechecked the timeline after seeing this and it is still as it should be.
  What is going on here and how can I fix it?
BTW, the timeline is 1920x1080 29.97; and one of the renders was to H264 VimeoHD format,  The other render attempt was to MPEG II for a standard def DVD.
Thanks for any suggestions...
- Jim G
    Jan 9, 2012 8:47 PM   in reply to jgreeson
    It doesn't make sense that everything else synchs appropriately and one photo will not do so.
    I would experiment with the trimming.
    It should work out.
    Jan 9, 2012 8:58 PM   in reply to jgreeson
    Are you using a black still at the end of the sequence, or just ending with the photo?
    You should transition or cut to black at the end.
  • Cocovanna
    Nov 10, 2008
    Jan 10, 2012 1:42 AM   in reply to jgreeson
    You certainly should. Empty timelines do not always behave like expected.
    Jan 10, 2012 3:10 PM   in reply to jgreeson
    File/New/Black Video
