I am getting an error in the Viewer Builder importing the PNS P12 Development Certificate.
I have already made the certificate for PNS Production/Distribution and for Development.
I was successfully able to import the PNS p12 Production/Distribution Certificate.
When I went to the next field to import the certificate for PNS Development - error says "Not finding expected label 'Apple Development IOS Push Services:' or 'Apple Development Push Services:' in this certificate"
I followed the same process for both PNS Distribution and Development Certificates.
Why would one work and one not? The Viewer Builder gives very little feedback?
Dave
hey, thanks so much for getting back to me so quickly.
i'm not sure i follow, you had to re-install the viewer builder itself?
is that what was corrupt?
or you had to cancel your project, and re-build it in the viewer builder you already had installed?
because i've tried that several times, to no avail. but a corrupt viewer builder definitely sounds like it could be the reason.
please, let me know when you can.
thanks again,
>neil
Just that particular project may have become corrupt, have a bug. At least that was my problem, and seems to happen quite often for me.
When I run into an error in the Viewer Builder, I first double-check my information entered. If I still get an error with my info in the Viewer Builder, I start over and create a new Viewer Builder project, that has solved all my problems.
I've been running into this same problem for DAYS now with an app I'm trying to build, except for me it's the production PNS p12 certificate.
I've tried creating a new app several (countless, actually) times. Since I never get to the point where I can save it, I've had to create a totally new app at every attempt—is this what happened to you? And it eventually worked?
I've also installed and uninstalled Viewer Builder a few times now and the same problem occurs.
BTW, I send my certificate to Adobe and they said that it was valid.
