cannot install adobe Premiere elements 9 disc
Jan 9, 2012 3:10 PM
I bought adobe photoshop elments 9 & adobe Premiere elements 9 sotftware from a store.
I have windows 7 on my computer.
I have installed disc 1 (adobe photoshop elements 9).  My computer said it installed sucessfully.
I went to install disc 2 (adobe premiere elements 9) & computer said 'Adobe Premiere elements 9 is not installed on the system or has corrupted. Please install adobe premiere 9 & retry'.
I also disable my antivirus software before I installed disc 1 and when I tried to install disc 2.
How can I install disc 2 ??
yzponyhead.
    Jan 9, 2012 4:11 PM   in reply to yzponyhead
    Did you just purchased Photoshop and Premiere Elements 9?  The current version of both products in 10.
    I would recommend trying to copy the contents of your disc 2 to your desktop and seeing if you receive any disc errors.  This will help tell you if the disc is damaged.  If you do receive an error I would also try copying the files to a second computer to help determine if it is a failure of the optical drive or the installation media.
    Jan 9, 2012 4:56 PM   in reply to yzponyhead
    I am sorry yzponyhead I don't completely understand your post.  What are you opening?
    Jan 9, 2012 5:01 PM   in reply to yzponyhead
    If you copied the files to your desktop you can try to run the Premiere installer from your desktop.
    Jan 10, 2012 10:08 AM   in reply to yzponyhead
    Did you receive any error messages while installing the software? I would recommend running the Adobe Support Advisor to see if it detects any errors.
    Jan 10, 2012 2:37 PM   in reply to yzponyhead
    You receive that error message when you launch setup.exe from disc 2?  Or are you receiving the error message when you try to open Premiere Elements?
    Jan 10, 2012 3:55 PM   in reply to yzponyhead
    If you go to Start>Control Panels>Program & Features does it list Premiere Elements there?  If so I would recommend removing it and then try the installation again.
    Jan 10, 2012 4:57 PM   in reply to yzponyhead
    But does Premiere Elements 9 show up in Programs & Features?  I would also recommend reviewing Troubleshoot install using logs | Premiere Elements, Photoshop Elements to help identify where the failure lies.
    Jan 11, 2012 8:27 AM   in reply to yzponyhead
    You should have received a disc error when copying the install files to your desktop if there was a problem with disc 2.  You could certainly contact the store you just purchased Photoshop and Premiere Elements 9 from to see if you can get a replacement copy.  Since both products are no longer the current version we do not have replacement media available.
    Jan 11, 2012 4:51 PM   in reply to yzponyhead
    Yzponyhead I would recommend you contact our support team.  They can help you diagnose your issue and certainly provide you with a case number if they determine the media is damaged.  For the best assistance, I recommend our chat support at http://adobe.ly/yxj0t6.  Our chat representatives can provide a personalized experience to resolve the issue you have described.
    Aug 6, 2012 12:13 AM   in reply to yzponyhead
    Photoshop and Premiere Elements 9 must be installed from DVD 1. DVD 2 is Premiere Content only.
