Hi all 🙂
Is there any way that I can get the IP address of the broadcaster? In know how to get info from the XML file about online channels and online users but I have not yet found the right place on how to get the IP address of the broadcaster. Can you help?
Your question is not very clear. Where do you want get IP of broadcaster - on server or on client ? Also when you broadacaster i hope you mean the publisher of stream - right?
Hi 🙂
I mean the publisher of the stream and I would like to his / her IP address on the server side, where I store it in a DB 🙂
We have different people publishing streams and it could be nice with some statistic about their streams 🙂 The last part I know how to do.
Can you help me with on how to pull the IP of the publisher from a Adobe XML file or another source?
You can use Client object and get Client.ip (http://help.adobe.com/en_US/flashmediaserver/ssaslr/WS5b3ccc516d4fbf351e63e3d11a11afc95e-7ec3SSASLR....) - this should give any client's ip including publisher ip. You can put this code in application.onPublish which is invoked only by publishers. Hope this helps.
Thank you 🙂
But how do I know when I hit the IP of the publisher? I only need this IP 🙂
Anyone?
