I tried to create a menu for a custom panel, using the example which David Clark graciously pointed out to me:
http://cssdk.host.adobe.com/sdk/1.0/docs/WebHelp/programmers_guide/cus tomizing_the_ui.htm
However, the nested menu items do not appear. I only see Item 1 and Item 2 (and the separator and Item 3), but not Item 2-1. I was expecting to see Item 2-1 nested under Item 2.
I used the menu structure provided in the example (note that there is an error in the example - one of the closing tags is incorrectly specified as "<MenuItem/>" instead of "</MenuItem>"). Below is the corrected XML and my code:
protected function createMenu():void
var xmlMenu:XML =
<Menu>
<MenuItem Id="item_1" Label="Item 1"/>
<MenuItem Label="Item 2">
<MenuItem Label="Item 2-1"/>
</MenuItem>
<MenuItem Label="---"/>
<MenuItem Label="Item 3"/>
</Menu>;
CSXSInterface.instance.addEventListener(MenuClickEvent.FLYOUT_MENU_CL ICK, menuClickHandler);
var menuAdded:SyncRequestResult = CSXSInterface.getInstance().setPanelMenu(xmlMenu);
if (SyncRequestResult.COMPLETE != menuAdded.status)
trace("Unable to add menu");
public function menuClickHandler(event:MenuClickEvent):void
switch (event.menuName) //you can also use the menuId
case "Item 1":
trace("Item 1 has been clicked");
break;
default:
trace("clicked " + event.menuName);
I'd appreciate it if somebody could tell me what I'm doing wrong.
TIA,
mlavie
