Hi Christophe --
Becky passed along the log file you generated and I have one idea for you to try. The main error backtrace in the log indicated that Lightroom was unable to create a subfolder in your Preferences directory.
Could you try navigating in Finder to the Library/Application Support/Adobe/Lightroom folder and hit Cmd + I (Get Info) and tell me what it says in the "Sharing and Permissions" section of the info panel. I saw one isolated case of a module switching error like this where (somehow) the Lightroom settings folder had been locked down with read only permissions. Once those permissions were set back so that the user's account had write access to the folder, all was well again.
This may work for others on the thread, though I think there is another bug impacting at least some others. I'm still trying to figure out how the error in the other log file was occurring.
DT
A completely off-the-wall thought... Any or all of you have Nik software installed? I've seen cases in the past where LR launches without modules, and it's turned out to be because Nik's created the Lightroom folder to install its plug-ins long before LR's on the computer. It's probably not related, but worth ruling out anyway.
DanTull wrote:
Aha... if that folder was created by the Nik installer (which is probably run as root), that might explain the one-off case of this I saw with a 3.0 user at one point. I was wondering what could cause that...
Ah, never thought of root! Sounds like you've sussed it for the install problems (you wouldn't believe how many times I've reported that one!) even if not for this issue. Nice one!
Weird. If you go into Lightroom preferences and in the presets tab click the "Show Lightroom Presets Folder...", is it the same (empty) folder?
Maybe I didn't indicate the right folder or wasn't entirely clear. I'd think if there were no folders that it'd be more than just the book module that's failing.
DT
Hi Victoria, I copied over the com.adobe.Lightroom4.plist and the lrcat files from the clean user account to my regular one. (First moved the existing ones to my desktop). When I try to launch LR4 now, I get the error message immediately "An error occurred when attempting to change modules." Before it only happened when trying to access the Book module. *seriously confused*
Hi Victoria, I am having the "An error occurred when attempting to change modules." Book problem and I have no NIK software installed. I have the problem both on my laptop running Lion and my desktop running Snow Leopard. That would indicate that either NIK is not the problem, or at least not the only cause of the problem. I have not tried the new user account trick yet. Julie might need to check the permissions on the plist file and the lrcat file she copied over from the clean account.
BFW
Yep, I received your log and Julie's as well. They have some similar looking errors in them that give me a couple of new leads.
I think we have a few different bugs in the mix. Hopefully with a little more time poring over the logs and the code I can spot what is triggering these errors.
Thanks for the info (and for bearing with us on this!) -- DT
Okay, here's where I'm at. No modules have been loading. I had Nik software installed on my admin account and have since uninstalled it. I made a new user account and loaded LR4 and it loaded all the modules normally. Knowing this, I tried Victoria's fix of copying the said files over to my existing admin account but to no avail. It still refuses to load any modules in my admin acount. I also can't access the preferences.
Can you run this command in Terminal.app?
echo $USER && find ~/Library/Application\ Support/Adobe/Lightroom/ -type d -maxdepth 2 -exec ls -ld {} \;
Basically, it's going to emit your username and the names and permissions of the top few levels of folders in that tree. I suspect that simply moving the folder between accounts could leave things in a state that's likely to be invalid and possibly prevent LR from accessing/modifying the contents.
Thanks -- DT
Here are the resultes from that command.
Last login: Fri Jan 13 13:59:24 on ttys000
xavier-lees-computer:~ xavierlee$ echo $USER && find ~/Library/Application\ Support/Adobe/Lightroom/ -type d -maxdepth 2 -exec ls -ld {} \;
xavierlee
drwxr-xr-x 3 root xavierlee 102 Dec 25 2010 /Users/xavierlee/Library/Application Support/Adobe/Lightroom/
drwxr-xr-x 2 root xavierlee 68 Jan 12 11:10 /Users/xavierlee/Library/Application Support/Adobe/Lightroom//External Editor Presets
Oh, yeah. That's the bug I've seen before all right. Those folders are owned by root with a group matching your username and they are only writable by the user (not the group or other) so Lightroom (which runs with your user permissions) isn't allowed to create anything inside there.
sudo chown -R $USER ~/Library/Application\ Support/Adobe/Lightroom/
sudo chgrp -R staff ~/Library/Application\ Support/Adobe/Lightroom/
This should set the whole tree to be owned by your user account and the (more typical, I think) group "staff". The permissions themselves seem correct, it's the ownership that's messed up. Note that the first one will prompt you for the password for your user account and that account will have to have admin rights to take ownership away from root.
It definitely looks like an installer created the "External Editor Presets" folder with incorrect permissions and left this trap for LR to fall into (which failed to present a useful error message). When I saw it before, I didn't make the connection with the installer (thanks, Victoria for pointing that one out).
DT
Awesome! Note for others on the list, I don't know that these instructions will work for everybody (the logs showed another bug which I think is distinct), but in the case where they don't it shouldn't do any harm. The commands are just setting the owner and group to what they should be anyway.
I'm still hunting for that one. Also, I'm going to work on getting a bug for a better error message, a tech note for correcting the problem, and maybe track down somebody from Nik software to see about tweaking their installer to avoid creating this condition.
DT
