Intergalactics
Nested comp targeting element in a layer present in the containing comp..?
Jan 12, 2012 4:27 PM
I am wanting to source the text for a Text layer with the following (as used by the pickwip)
thisComp.layer("Name of Layer")
However I would like to make a text style-template (as a comp, so I can use it in other comps) and then have custom text in those main comps which the template would use for the text in those instances.
So how do I target a layer in the main comp (maybe with a predefined name)?
Or is there a better way to do this?
    Jan 12, 2012 4:38 PM   in reply to Intergalactics
    I'm not sure if this is what you're after:
    comp("Main Comp").layer("Name of Layer").text.sourceText
    Dan
    Jan 12, 2012 4:50 PM   in reply to Intergalactics
    Well, an expression can't figure out what comp its own comp is nested within, if that's what you're asking. What workflow were you envisioning for connecting the template to the appropriate comp?
    Dan
    Jan 12, 2012 8:12 PM   in reply to Intergalactics
    The only thing I can think of is that you could probably do it with a script, where you would select the text layer with the style and text you want to propogate and the script would go through all comps looking for text layers with some identifying tag in their name and copying the text, font, size, color, and tracking from the template to the target layer.
    Dan
