Tomaspav
How to copy/Paste a table from PDF to Excel using AcrobatX
Jan 13, 2011 11:40 AM
How to copy/Paste a table from PDF to Excel using AcrobatX?
I was able to do this easily using acrobat 9 but cannot do it in Acrobat10.
Has the option fgone or am I missing something?
Tomas
    Jan 13, 2011 12:58 PM   in reply to Tomaspav
    Rather than copy and paste, Acrobat X exports to an Excel workbook from where you can transfer into an existing table if required.
    To save a specific table from a PDF document, draw a selection box around it, right-click the selection and choose Export Selection As, then choose Excel Workbook from the file type menu. You can also run OCR on demand to convert a bitmap image of a table into a real table. All the formatting of the cells will be transferred across, where supported.
    If you have a table alone in a PDF file, you can simply choose File - Save As - Spreadsheet to convert the entire thing.
    Jan 13, 2011 4:44 PM   in reply to Dave Merchant
    That doesn't work for me! What used to copy and paste as a nice table is now a wreck. I have to reconcile several credit card statements in Excel at my job, it used to be so easy to copy and paste as a table. Now some of the rows paste into separate columns but most don't now. I ran the OCR and it made no difference. I've tried saving the file as an Excel spreadsheet and a Word doc, but the columns don't come up correctly. Is there a fix for this?
    Jan 20, 2011 12:48 AM   in reply to Tomaspav
    When you are copying, are you using "Copy with formatting" ?
    Jan 20, 2011 9:46 AM   in reply to AbhigyanModi
    I am using "Copy with formatting". I've tried every different way I can see and nothing works. It's unfortunate because this feature is the reason I upgraded from Reader after doing a trial with version 9. Is there any way to downgrade to Acrobat 9 standard using the same reg key?
    Jan 20, 2011 9:50 AM   in reply to dissipatedfog
    Thank you for the information, I'll give it a try - after spending over $300 on Acrobat Standard X.
    Jan 10, 2012 10:18 PM   in reply to dissipatedfog
    This is a major pain in the neck. I'm working with X and 9 Pro and whilst the latter wasn't perfect, it was easy to extract info from tables.  X exports data imperfectly to Excel.  Formatting looks great but what use is that when stores individual cells with multiple data. Painful painful painful.  I have to downgrade to be productive. This should be a bug or feature fix if anyone at Adobe is listening.
    Jan 12, 2012 7:24 PM   in reply to Tomaspav
    Yes I too found the copy and paste in Acrobat 9 functional , upgraded to X which has been a huge waste of money. I started with Acrobat 4.0 and usually each version provided better features until now hopefully someone at Adobe monitors these posts and will provide a fix in the future. Will probably have to uninstall Version X and reinstall 9
    Jan 12, 2012 7:29 PM   in reply to jstanley5003
    I have the 9 and X installed and they work fine together- got the updaters working in tandem.  Strangely this is one area where Adobe apps can co-exist unlike other vendors
    Jan 12, 2012 7:36 PM   in reply to Bev_Meister
    Had I known that at the time would have been worth it as it was when I went to install X it told me to unistall the old version and when I did and then tried to run X it said I couldn't upgrade because it couldn't find a current version on my computer so had dig out the old copy so that the X would install and give me credit for owning a previous version. So far haven't seen X do anything better than version 9 for the purposes I use it for. I'll try installing 9 back over the top of X , thanks for the tip.
    Jan 19, 2012 8:50 AM   in reply to Bev_Meister
    Can you please share how you created the pdf you are using.
    And if possible could you share the pdf so that i can reproduce the issue at my end.
    Jan 19, 2012 9:02 AM   in reply to atir_husain
    Appreciate the offer but the file is from an insurance company and the client information is protected so I can’t release. But when we use copy or copy format it puts it in an entirely different format in the excel spread sheet either all data in one column or in formatted in several columns but still the data is combined where as when you use copy as a table in Acrobat 9 it lays it out perfectly in excel just like in the pdf. After using Acrobat X now for a couple of weeks definitely wasn’t worth upgrading from 9.0 to X. Thanks for the offer though.
    Feb 6, 2012 10:22 AM   in reply to jstanley5003
    Which version of Microsoft Office are you using?
    If you are using office 2010 make sure that you are not pasting the table with “Keep text only" option.
    Feb 6, 2012 10:37 AM   in reply to Tomaspav
    It's almost certain that the PDF file isn't tagged (either at all, or properly). Accessible, tagged files will export to spreadsheets as Acrobat can understand what's a table, what's a header cell, etc. whereas in an untagged file it has to make guesses based on the separation of each text block (it can't see the page visually as you do, so what looks like a perfectly-obvious table to a human is actually very difficult to detect in code).
    Feb 7, 2012 5:44 AM   in reply to Dave Merchant
    The alternative is to do column or block copies. In the past this was done by using the alt key when selecting the area of interest (works in my AA9). That allows you to copy column by column and generally the lines separations will still be used. Hope that does it.
    Feb 7, 2012 5:56 AM   in reply to Bill@VT
    Thanks for the response however I've tried this and it just doesn't work right, after having worked with Acrobat X even more it just isn't as good as 9.0, documents I used to be able to OCR now have more unrecognized or miss recognized items than 9.0 and the only thing I have changed is going from 9.0 to 10.0. This appears to have been nothing but a profit move from Adobe just a few bells and whistles. This is the first time Adobe has failed to deliver a significant improvement by introducing a new version and I started with 4.0
    Feb 7, 2012 10:30 AM   in reply to jstanley5003
    I am surprised on the OCR. Most folks have reported the OCR in AA X to be a great improvement. It may be that your original copy is just that bad and AA 9 would have done no better.
    Feb 1, 2013 11:17 AM   in reply to Tomaspav
    I have discovered a work around.  Select the table you are trying to copy, right click and select "export selection as" and save it as a .docx file.  Open the word document, copy the table again and paste it into an open excel file.  The columns will be maintained and your data will be in seperate cells instead of all of it in one cell.  It's not one easy step like it used to be, but it does work.
    Apr 4, 2013 4:34 PM   in reply to gfh2009xx
    We too work with Insurance documents where we have to pick the tables from the pdf to excel.
    While googling we found the below and helped us a lot.
    Give it a try , i hope this works for you.
    Not the best , but does the work.
    http://www.w3.org/TR/WCAG20-TECHS/PDF20.html
