I am trying to add a custom check in dialog to Drive 3.0.1.104. I copied the code from the thread "Custom check in dialog" and compiled it into a SWF. I placed the SWF into the resources folder and have verified that the URL passed back in the response is a valid URL. However, the additional fields are not showing up in the Drive check in dialog. Currently I am only including a static mx:Label in the Module just to see if something will appear. I am not passing any context info.
I am currently using Flex 3.5, but have also tried 3.2, 3.3, 3.4 & 3.6. No errors are showing up in the CS5ServiceManager_java.log file. Is there another log file or logging level that I can enable to see what's going on?
Rich
I think you can try the following ways in Flex builder 3 or Flash builder 4 on Windows
1) Put a placehoder file named Debug aligned with Bridge or PS, AI, InDesign executable file
2) Create a empty Flex web application for Debugging.
3) In the Run/Debug setting, create a new configuration, then do the following in it
4) Launch AD and do check-in operation in Bridge or PS, AI, InDesign
Thanks for the tip! When I executed a check in from InDesign, the debugger attached to CS5ServiceManager\plugins\com.adobe.drive.ui.scripting_2.0.0\resource s\BatchSaveVersion.swf. As I said before, I have debugged my GetCustomCheckInUIHandler and it is setting a non-null URL in response.setModuleURL. When I log the URL it looks like: "bundleresource://46.fwk4354460:6/CheckInUI.swf". This leads me to believe there is something wrong with the way I am building my SWF. I've look through the documentation and I don't see anything that documents how to setup FlashBuilder project to properly build the module SWF. It seems pretty basic, but is there something I could be missing?
