DCSPAO
favicons
Sep 2, 2008 11:46 AM
How can I load a favicon onto my site using dreamweaver? Is it an extension or just a bit of code?
    Sep 3, 2008 8:40 AM   in reply to DCSPAO
    Lots of threads o this in the Dreamweaver general forum:
    http://www.adobe.com/cfusion/webforums/forum/categories.cfm?forumid=12 &catid=189&entercat=y
    Search for "favicon" and you should find plenty of results to get your answer
    Danilo Celic
    | http://blog.extensioneering.com/
    | WebAssist Extensioneer
    | Adobe Community Expert
    Sep 11, 2008 7:35 AM   in reply to DCSPAO
    I think there are better alternative in creating a favicon for use. Try search favicon in google.
    Sep 14, 2008 10:54 PM   in reply to DCSPAO
    favicon is just a type of image format with extension .ico . you can find several free software that can create and save favicons. try http://www.favicon.cc/ or google for free favicon creation. usually image must be 16 by 16 pixels. once you saved the image just upload it to your root folder (in public_html or in www folder). Remember you must save the images as " favicon.ico " (it must have a name "favicon.ico" with out the quote). It shows up in all browsers except internet explorer 6 and older.
    Calculating status...
    Oct 9, 2008 4:40 AM   in reply to DCSPAO
    thanks for information
    Oct 22, 2008 11:07 AM   in reply to hodye
    quote:
    good info thanks
    Oct 31, 2008 11:32 AM   in reply to DCSPAO
    The easy way to to add manual code in the HTML <Head>
    <link rel="shortcut icon" href="/favicon.ico" type="image/x-icon" />
    To create the initial Icon file goto to a website like www.favicon.co.uk
    Note somtimes it can take a while to update as easy solution is to clear the browser cache if required
    or try to save a bookmark of the page as a test trial.
    Mr Daniel Lee
    | http://www.onemegamarket.com
    | CEO - Lead Developer
    | Developer Trainer
    Feb 19, 2009 4:50 AM   in reply to neineicup
    l am sorry l see your topic later,can you give information favicon.
    corian corian
    mutfak dolabı mutfak dolabı
    Mar 6, 2009 8:39 PM   in reply to DCSPAO
    I had problems with the favicon - it was shown on /index.html, but not for the main URL (I uploaded it to both root directory and images directory). I added this code:
    <link rel="shortcut icon" href="/images/favicon.ico" >
    and everything's working just fine!
    Jun 14, 2009 11:11 AM   in reply to kreshorulez
    Thank you i had the same Problem here -> Pokerschule
    Finally have my favicon now. Appreciate the help.
    Andreas
    Dec 23, 2010 7:00 AM   in reply to DCSPAO
    I've also had trouble with favicon implementation in Dreamweaver until I found out it's just one short line:
    <link rel="shortcut icon" href="/nameofthefavicon.ico" type="image/x-icon" />
    Also making something nice out of 16 x 16 is hard, I envy sites that do it right like on free vectors.
    Nov 27, 2011 9:19 AM   in reply to DCSPAO
    easiest way to add favicon go to: http://favicon.htmlkit.com/favicon/ upload your image i think size is 80x80 or 100x100px max, once you browse to image and found it say create favicon, once done image will display if you happy with it, you install the code displayed in block on the right, copy and paste directly after the head on your index page, then download favicon folder once done open folder copy the two favicon items and paste in the root of your site, once you done all this re-upload your index page after saving and upload the two favicon items,
    that should be sorted then, you can validate by clicking on the validate link type in url of site and it will test to make sure you have installed correctly, should be all green ticks indicating correct instalation
  • Claudiu Visan
    Nov 27, 2011
    Nov 27, 2011 11:40 PM   in reply to normedia
    Thank you.
    I will try this.
    Nov 29, 2011 12:55 AM   in reply to DCSPAO
    here is the code.
    <link href='ICO/IMAGE URL' rel='shortcut icon' type='image/x-icon'/>
    http://www.pestcontrol.org.nz
    http://www.carpet-cleaning.org.nz
    Jan 16, 2012 4:54 AM   in reply to DCSPAO
    Hello,
    Try this website http://www.favicon.cc/
    Leonardo Hermoso
    bovespa
    investir na bolsa
    Jul 25, 2012 8:33 PM   in reply to radocon
    I do it manually is not complex, but why not use the functionality of pieces of code?, ie, include in your short codes, then just drag on your document.
    Grettings!
