Dear users,
Based on the feedback provided to us in relation to the recent Print crash issues on Adobe Reader 10.1.2, we are hereby providing the following two workarounds for the problem faced. Please follow the steps below to get rid of this issue:
WORKAROUND 1:
Go to Start menu to Select Devices and Printers to access all Network Printers installed on your machine. Right Click to access Printer Properties. Open the Sharing Tab and give your printer a Share Name. If you wish not to share your printer then you may choose to give it a Share Name and then select “Do not Share” Checkbox. Please make sure that all Network printers have been assigned a Share name otherwise problem will persist. Please find below the screenshot for your reference.
WORKAROUND 2:
The second work around is to turn off the Protected Mode of the Reader and the problem will be resolved right away. However, it is not advised to keep the application in non-protected mode due to security reasons and it is advisable to turn this setting ON once you are done with your printing task. You can access this setting by going to Edit-->Preferences-->General pane and can find “Enable protected mode at start-up” at the bottom of the window. Please re-start the Adobe Reader after you have made changes to this setting.
Atul Agarwal
Dear Atul Agarwal,
I tried workaround 1, but these settings are already present.
Because of the secure environment I'm working in, I think it's not save to turn off the Protection Mode (We receive hundreds of emails with attachments everyday).
Are there any other suggestions and will adobe come up with a permanent solution on short notice?
Thank you in advance,
Dear user,
Workaround1 is sufficient in itself to resolve the issue. You need not apply the workaround 2.
Just ensure that you have applied workaround1 to all your printers and that should work. Message me back if that does not work for you and i will set up an online connect session in oder to resolve the problem.
Atul
Dear user p1800s,
Could you please describe the issue little more as the suggested workaround has worked for all our customers so there might be other issue at your end?
I would await for your reply. If required, I can also set up an online connect session to resolve the problem at your end. My e-mail address is atulagar@adobe.com
Atul
Dear Atul,
we use Windows Server 2008 R2 Terminalserver with Citrix XenApp. On this Server we cant print since the upgrade to 10.1.2.
When i disable the protected mode is the same issue.
The older Version 10.1.1 works fine. So i want install the version 10.1.1 again because i dont have time for testing someting.
Where can i download that version?
If i can not install 10.1.1 i install another pdf viewer. Its too important to wait. Sorry.
Stefan
You can find the 10.1.1 installer here - ftp://ftp.adobe.com/pub/adobe/reader/win/10.x/10.1.1/en_US/
Is there a quick way to push out Workaround 2 to thousands of machines? All of our printers are pushed via group policy and therefore, your Workaround 1 is not an option. I am half tempted to push out FoxIt Reader to fix these issues for good. However, this issues will probably be fixed with Adobe releases yet another update to Reader next week. Maybe 10.1.3 will fix the issues, but 10.1.4 will probably break them again.
Workaround 1 is not a workaround for me - it doesn't work!! Workaround 2 works and I will therefore be keeping the unprotected mode as "normal". Are Adobe going to fix this in the near future. I want to enable protection again asap but because of the inconvenience of this workaround .......... I get many PDFs daily and therefore this is my only option.![]()
Neither workaround 1 nor 2 work for me. I have a very small network, but my printer stands alone on the lan.
I'm running Windows 7 SP 1. My printer is an hp oj pro 8500 hardwired via lan. When I installed Reader 10.1, all printing stopped. It doesn't crash, but finds the printer, starts to process the file, then a "Save As" window pops up and it wants to save the file as a *.pm. If I cancel, nothing happens and nothing prints. If I Save, it takes a long time (> 1min) to process the file (simple text, 1 page), then the status box vanishes and nothing prints. I can't find the .pm file anywhere and there is nothing in the printer's queue.
I installed 10.2.1. Same thing. Tried the patch for 10.2.1 printer crash (even though I'm not really crashing. Just a whole lot of nothing) and same problem.
Reader 10.1.1 on my mac has no problems finding the printer. I'm leery of upgrading it to version 10.2.1 But we only have the one mac, and I'm stuck with the hp pc.
I work from home on a PC with a Lexmark printer. I have never had any problems printing PDF files. My tech guy was here today doing some cleanup and he downloaded the new version of adobe. I now cannot print any PDF files. I select print and nothing happens. My printer is working fine for all other printing. I tried both of the workarounds you mentioned and still nothing.
Could you please uninstall Adobe Reader from your system and then re-install the same?
Mail me at atulagar@adobe.com if you still face any issue. All 10.1.2 print issues have been resolved.
Atul
Things are working fine. Dont be hesitant. Feel free to update your application to 10.1.3
Refer: http://helpx.adobe.com/acrobat/release-note/release-notes-acrobat-read er.html
I cannot really comment unless i know your email id as i reply to a lot of users on daily basis. Your screen name does not really match with any of the user i have received email from or i have replied to.
Also, I would be happy to see the issue on your screen. Could you send me an email at atulagar@adobe.com and i will set up an online meeting right awy to see what is really causing the problem as things are working fine on all our workstations.
Atul Agarwal
Hello, after a lot of searching I have found little information and am still unsure as to whether this issue has been resolved with 10.1.3 or not.
I need to put this on our XenApp 6.5 Farm, and am unwilling to disable protected mode. Will Adobe Reader work or should I be looking at something like PDF Xchange..?!
The printing issue has been addressed in 10.1.3. http://helpx.adobe.com/acrobat/kb/pdf-wont-print-reader-10.html
I went back to Adobe Reader 9.5.1 and the problem still exist. With 9.5.1 I was able to click print, see the printer, after choose the printer, click OK, the whole Adobe Reader disappeared. With 10.3.1 click print, Adobe Reader disappeared. So version 9.5.1 let me go a few steps further. But it still has the same problem of not printing. Anyone has any idea what Adobe is doing about this?
