HttpService.lastResult returns [B@b041b0
Jan 11, 2012 11:57 AM
    I am trying to send byte[] array that contains image from java to Flex.
Java Code :
PrintWriter out= res.getWriter();
out.print(bytes);
I receive this in Flex as  [B@b041b0.
Flex Code :
var obj:Object = HttpService.lastResult;
Alert.show("obj : "+ obj.toString());
resultFormat in HttpService is specified as "array"
How can I display this Object as image in Flex?
Any Help will be appreciated.
    Jan 17, 2012 5:55 PM   in reply to Anshul108
    immm
    in java you have to use
    DataoutputStream instead of printwriter, you can send data as binary
    then you can
    var data:ByteArray = object as ByteArray;
    data.uncompress();
    var width:int = data.readUnsignedInt(); // first 4 bytes (unsigned integer);
    // after data.uncompress()
    var height:int = ((data.length - 4) / 4) / width;
    // (data.length - 4) ** byte array less the first four bytes gives the representation of the bitmap **
    // ((data.length - 4) / 4) ** length of the representation is divided by four because each pixel takes four bytes **
    // ((data.length - 4) / 4) / width ** remember, it is a rectangle, so we can get the height this way **
    var bmd:BitmapData = new BitmapData(width, height, true, 0); // 32 bit transparent bitmap
    bmd.setPixels(bmd.rect, data); // position of data is now at 5th byte
    var bm:Bitmap = new Bitmap(bmd);
    addChild(bm);
