snegig
[JS] Delete empty tags InDesign cs4 Help Please
Jan 12, 2012 9:22 PM
Can anyone suggest me how i can delete empty tags in my InDesign cs4 files. Like this
(1) <para></para>
(2) <emphasis></emphasis>
Both tags have no any matter between these tags. Any script you have please help me.
Thank you so much adv.
Regard
snegig
    Jan 14, 2012 2:40 AM   in reply to snegig
    Hi snegig, Try the below script and check.
    var xpath ="//*";
    var root  = app.activeDocument.xmlElements[0];
    var node  = null;
        try {
            var proc  = app.xmlRuleProcessors.add([xpath]);
            var match = proc.startProcessingRuleSet(root);
            while(match!=undefined) {
                node = match.element;
                match = proc.findNextMatch();
                content=node.contents;
                    if(node)
                        app.select(node);
                var myText = app.selection[0];
                var content=myText.contents;
                    if(content.search(/^[\s\r\n]+$/)!=-1){
                        myText.untag();
            }//End of While
        } //End of Try
        catch(ex){
            alert(ex);
        finally {
        proc.endProcessingRuleSet();
        proc.remove();
    Green4ever
    Jan 17, 2012 9:21 PM   in reply to snegig
    Then that tag will not have only the space character inside that, some other character may also be inside. It will work for spaces also. You can test it with some input.
