aleximp
Need Help
Dec 29, 2011 5:06 AM
I have recentley pruchased and installed adobe premier elements 10. Anyway when the installation was complete I restarted my computer and then tried out the software. I imported some videos into premier elemnts 10 and then dragged them to the timeline. I then played then tried to play the video but just got audio sound but no video playing in the box above the timeline. Does anyone know what the probem might be?
Replies 1 2 Previous Next
    Dec 29, 2011 5:23 AM   in reply to aleximp
    What model of camcorder is your video coming from and what format is it?
    When you started your Premiere Elements project, which project settings did you select? If youv'e selected the proper settings, you will NOT see red lines above the clips as you add them to the timeline. Is that the case in your project?
    Have you ensured you have the latest version of Quicktime, per the program's requirements?
    If you'd like to know how best to set up a project and get video into it, have a look at my free 8-part Basic Training tutorial series at Premiere Elements support site Muvipix.com.
    http://forums.adobe.com/thread/537685
    Dec 29, 2011 8:39 AM   in reply to aleximp
    More file details will help
    Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
    What is a CODEC... a Primer http://forums.adobe.com/thread/546811
    What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
    Report back with the codec details of your file, use the programs below
    For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
    For Mac http://mediainfo.massanti.com/
    Dec 29, 2011 8:40 AM   in reply to aleximp
    Unfortunately non-DSLR still cameras shoot in MJPEG-MOV, a format that's difficult for a number of programs to edit, particularly Premiere Elements. Converting it to WMV only takes you farther from a solution.
    The ideal program for converting this type of video to an editable format (like DV-AVI) is Quicktime Pro, which costs $29 from Apple.com and is a tremendous value.
    You may be able to convert the file with Super, which is free, if you follow the instructions in this FAQ. But you're not likely to be able to edit it without converting it.
    http://forums.adobe.com/thread/415317
    BTW, make sure that any video you do shoot with the camera is 640x480. This is the best format for editing in a standard def video project.
    Dec 30, 2011 4:44 AM   in reply to aleximp
    Did the follow the steps precisely in the article I linked you to?
    Also, when you started your Premiere Elements project, which project settings did you select? If youv'e selected the proper settings, you will NOT see red lines above the clips as you add them to the timeline. Is that the case in your project?
    Dec 30, 2011 6:12 AM   in reply to aleximp
    There's a DV 480p setting?
    I'm not sure what's up. But if your footage matches your project settings for DV, you should never get red lines above the clips on your timeline until you add effects or transitions to them.
    Dec 30, 2011 6:29 AM   in reply to aleximp
    So no red lines above your clips?
    Dec 30, 2011 6:41 AM   in reply to aleximp
    Then you do not have a match between your converted video and your project settings.
    What happens if you select DV 4:3 rather than widescreen as your project settings?
    Dec 30, 2011 7:39 AM   in reply to aleximp
    Sorry. If your file was converted in Super using the steps in the link and it still doesn't work, I'm not sure what else to do. Maybe someone else will have an idea.
    As I said above, Quicktime Pro will most certainly work, but I can understand you're not wanting to spend $29 to find out.
    Dec 30, 2011 8:46 AM   in reply to aleximp
    Go back to my #3 message and use an appropriate program to analyze and then post (screenshot) the details of your file(s) so people here may see what you are doing
    Jan 2, 2012 8:41 AM   in reply to aleximp
    Screen shots are very helpful. Your problem does not seem to be the file format or your project set-up. And I assume you have the latest version of Quicktime, per the program's requirements.
    This solution is for version 9 but is worth a try.
    http://forums.adobe.com/thread/769303
    Going to the ATI or nVidia site and updating your display drivers alone often fixes these problems, by the way!
    Jan 11, 2012 1:58 PM   in reply to aleximp
    What model is your graphics card?
    Jan 11, 2012 2:28 PM   in reply to aleximp
    Then you don't have a graphics card at all. You have in Intel graphics accelerator built into your motherboard.
    So the reason you may see a moment of black is because your card and processor aren't able to keep up. (How fast is your processor?)
    You can try downloading the update from Intel, but it may not make much difference.
    Jan 14, 2012 8:30 AM   in reply to aleximp
    I just don't know, Alex. Sorry. There's no reason this should be happening.
    As I said, you can try downloading the Graphics Media Accelerator Driver from this site. It may help.
    http://downloadcenter.intel.com/
    But beyond that, I'm not sure what to tell you except to uninstall and reinstall the program. Sorry.
    Jan 14, 2012 12:17 PM   in reply to aleximp
    This screen dump shows you are exporting in an NTSC format. But in response 9 you said you were using a PAL preset. This is likely the cause of your red lines. You need both to be PAL (720x576) or both to be NTSC (720x480).
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Jan 14, 2012 12:29 PM   in reply to aleximp
    Disc 1 is the correct one for your system.
    Cheers,
    Neale
    Jan 17, 2012 2:17 PM   in reply to aleximp
    It is most likely an issue with your installed graphics driver.
    I do not recall if you listed your graphics card/Display Adapter, or the installed video driver, but would be where I would start looking.
    Good luck,
    Hunt
    [Edit] Found it - Intel.
    Do you have a desktop, or laptop? If you have a desktop, then I would look into bypassing the integrated Intel graphics chip, and adding either an nVidia, or ATI/AMD graphics card (the power is not really something to worry about, but I would go with a recent card, for best driver support), and install the very latest driver from the mfgr's. Web site.
    Message was edited by: Bill Hunt - Added [Edit] and rec. to add an nVidia, or ATI/AMD card to a desktop.
    Jan 18, 2012 7:48 AM   in reply to aleximp
    I was afraid of that. Other than acquiring a new video driver from Intel, or the computer mfgr., I do not know of any way to get it updated to run PrE.
    Sorry for the bad news, but that total lack of driver support, is why I recommend against trying to use an Intel graphics chip for editing Video, or even Still Images with a program, like Photoshop, or PSElements.
    Good luck,
    Hunt
    Jan 18, 2012 7:54 AM   in reply to Bill Hunt
    And updating the Intel graphics driver is something I recommended above. Have you tried that? (I even linked you to the download page.)
    Jan 18, 2012 9:49 AM   in reply to aleximp
    Go to the page I linked you to above.
    Look at the very first thing listed under Top Recommended Downloads.
    Jan 18, 2012 11:21 AM   in reply to aleximp
    What brand of computer do you have?
    According to the Intel driver utility, you have a custom driver, so you need to go to your computer mfgr. (Dell, HP, Toshiba, etc.) and see if they have issued an updated, custom driver.
    Good luck,
    Hunt
1 2 Previous Next
