I'm trying to set up the latest FMG/FMS to work with our video conferencing/media server. Basic setup is fine, flash phone connects and calls are intitated. G711u audio is good. Video, both at a VGA and CIF resolution doesn't make it through the gateway. A wireshark trace tells me a vidfeo RTP stream (h.264) is arriving. But, nothing on the flashphone.
Some pieces of the config are included here. sip.xml:
<Profile>
<!-- Unique name for the profile. This ID is used in workflow to identify where the call will be placed -->
<profileID> sipVideoPhone </profileID>
<!-- SIP username -->
<userName> FMG </userName>
<!-- SIP password -->
<password> FMG </password>
<!-- SIP display Name, can be same as username -->
<displayName> FMG </displayName>
<!-- Here the client is binded dynamically, in which case the sip phone's ip address is bounded by the register request -->
<remoteSipHost> 192.168.0.125 </remoteSipHost>
<!-- Global Address if the FMG server is on a local network and need to connect to outside network -->
<!--globalAddress> 10.41.60.70 </globalAddress-->
<!-- Context in which incoming calls will be handled, this points to the context in workflow.xml -->
<context> sipPhoneContext </context>
<!-- supported Codecs for this SIP profile
If no codec is specified here then the codecs specified in CodecList would be used.
DTMF is always supported -->
<supportedCodecs>
<codecID> G711u </codecID>
<!-- Video quality level can be optionally selected for H264 codec
using deviceId and qualityLevelId defined in videoqualitylevels.xml.-->
<codecID deviceId="GenericVtcDevice" qualityLevelId="cif"> H264 </codecID>
</supportedCodecs>
</Profile>
workflow.xml:
<Context name="rtmp">
<!-- Diastar extensions -->
<Condition variable="destNum" value="^400$">
<AppNode sequence="1" app="bridge" args="sip|${destNum}@sipVideoPhone"/>
<AppNode sequence="2" app="hangup" args="null"/>
</Condition>
<Condition variable="destNum" value="^506$">
</Condition>
videoqualitylevels.xml:
<device deviceid="GenericVtcDevice">
<!-- The following settings are included for reference and can be used with any device -->
<!-- Max-bitrate=1000kbps, profile-level-id 3.1 -->
<qualityLevel qualityLevelId="vga" fmtp="profile-level-id=42001f;max-br=1000"/>
<!-- Max-bitrate=385kbps, profile-level-id 1.3 -->
<qualityLevel qualityLevelId="cif" fmtp="profile-level-id=42000d;max-br=384"/>
Any help would be appreciated.
John Hermanski
Hi Pankaj,
Thanks. This got me going. I was even able to revive a beta 1 FMS/FMG system. I had moved it from one demo environment to another, and it "broke" (video-wise) when I tried it in its new spot. I guess I must have upgraded my flash player to a non-working version, as a month or so went by.
Both CIF and VGA are working. Not all videos are coming thru well. One, for example - dim and hard to see, but not distorted. They work OK using a Bria SIP phone. I need to investigate this further.
Thanks again,
John
