Maybe it's me, but I'm seeing some peculiar behavior when attempting to use RHCL with RH HTML 9.01 (TCS) to build a CHM file. The sample project, sales builder, builds the CHM as expected when compiling from the RH interface. The RHCL command (run w/ RH closed) sometimes fails and, when it works, always gives a wrong result. I am copying the command from a text file, so it's the same for each trial. When RHCL fails, it gives warning: "no baggage file description." When it produces a CHM, there's no TOC and a wrong default topic. The first topic is "AIR Help Commenting and Rating" and not "What is Salesbuilder?" In project settings, TOC is set to default. The result gives search and glossary tabs (no terms as are in the project), but an index tab is missing. Also, the result omits browse sequences. The forums are reporting various other strange results using RHCL. Does someone have some answers?
Command Line generation is not something I use but my site hosts an article written by Bill Albing. Maybe that has something that will help you.
